Skasi7
Logic level translator 1V8 MEMS Sensor RPI compute module
Tue May 08, 2018 7:33 pm
I am interfacing a MEMS sensor with the RPI compute module 3 - FIS1100 from ON Semi
The logic level for this IC is 1.8V.Do I have to use a IC like TI TXB0108 bidirectional Level Translator(1.8-3.3V) to communicate with the PI via SPI?
FIS1100- https://media.digikey.com/pdf/Data%20Sh ... asheet.pdf
I am interfacing with a raspberry Pi compute module 3 and in the schematic for the IO board I see voltage select bank 0/1 for 3.3 and 1.8V what is the purpose of this voltage select header?
io board.png (62.11 KiB) Viewed 489 times
Do I have to use a level translator ?
~Skasi
KnarfB
Re: Logic level translator 1V8 MEMS Sensor RPI compute module
Wed May 09, 2018 4:08 pm
If you set the jumper to 1V8 the corresponding group of GPIO pins will have 1.8 V levels, and you dont need a level converter.
See here for some explanation: http://www.seeedstudio.com/document/pdf ... uction.pdf
Only change the jumper settings when completely switched off.
The only caveat is, that the GPIO levels can only be set in 2 large GPIO groups.
If you have other 3.3V peripherals connected, you have to split the GPIOs accordingly.
Skasi7
Thu May 17, 2018 12:01 am
Thank you for answering my question.I will have to use a 3.3V logic as Vref for IO for the compute module to work with other peripherals I am interfacing.
Do I have to use a logic level translator if I use 3.3V logic or can the raspberry pi recognize 1.8V as a low threshold without a logic level converter?
Regards,
Skasi
es_pi_user
Thu May 17, 2018 12:49 pm
Regards,
Skasi
According to the datasheet the absolute maximum IO Leves of the Sensor is 2.05V so you should use a level translator because the Raspi will drive the lines with 3.3V.
