Sairamthummalacharla
Need help!! How to read analog input from current sensor by using Raspberry pi3?
Thu Feb 22, 2018 10:16 am
Dear members,
I wanted to collect the analog voltage from the optical current sensor and give it as a input to pi 3 via ADC(12bit to 24 bit).
The optical current sensor can give
Analog output voltage ranges from ( 0 - 1V)
Analog ouput current ranges from (0- 20mA)
I am also attaching the sensor module outlet overview.
I am new to use the pi. There are lots of them in the forum. I am confused with this. Please anyone give me the detailed way.
Thank you
Sairam
External connections.JPG (64.81 KiB) Viewed 713 times
habropoda
Re: Need help!! How to read analog input from current sensor by using Raspberry pi3?
Thu Feb 22, 2018 9:52 pm
For the voltage side this should work:
https://learn.adafruit.com/adafruit-4-c ... s/overview
And this might work for current:
https://learn.adafruit.com/adafruit-ina ... r-breakout
Look for ina219 raspberry pi tutorials on the internet.
Fri Feb 23, 2018 4:51 am
Thank you habropoda.
I have another doubt. Can I use any USB to serial RS-232/ RS-422/485 adapter. To access the data from the sensor to the raspberry pi through this.
Actually I have one RS485(D suB9 ) analog output ports on the sensor outlet.
If yes . do they have library and any example program codes.
Thank you
Sairam
habropoda
Fri Feb 23, 2018 5:58 am
Ah, it must be part of some industrial control system. Sorry, I know nothing about those. Maybe something like this will work?
https://widgetlords.com/products/raspbe ... -interface
If no one here chimes in you might try on the eevblog forums. I can help you no further.
Fri Feb 23, 2018 8:55 am
No, problem habropoda. Your suggestions are valuable.
Thanks for your help
