trbotha
RPI3 GPIO pin direction resetting
Thu Oct 19, 2017 1:13 pm
I'm using a RPI3 in a circuit using the GPIO for SPI, I2C and general GPIO pins. I'm using WiringPI to set the direction of GPIO4 (Physical pin 7, WiringPi pin 7) to set it as an OUTPUT pin and setting its state as HIGH. After setting the pin either via a C++ program or gpio in command line I verify the state using gpio readall and an oscilloscope. The pin is successfully set as an OUT pin (gpio readall) and the voltage is HIGH. After a few seconds the pin resets to an INPUT pin. This happens irrespective of doing it through the C++ program or via the command line utility gpio.
Driving another pin such as pin 23 succeeds with no resetting of the pin.
The only reason I can think of is that some other function periodically runs and resets the direction of the pin. However setting the state direction in a while loop in C++ does not seem to change its direction. Once the pin resets the program needs to be restarted for it to take action.
Any help is appreciated.
6by9
Re: RPI3 GPIO pin direction resetting
Thu Oct 19, 2017 1:53 pm
WiringPI is going directly to the hardware, bypassing any knowledge of GPIO usage that the Linux kernel may have.
Most likely you have enabled something via config.txt that also thinks it is using GPIO4, and periodically it is checking it. Likely candidates would be a 1-wire interface as that defaults to GPIO4.
"sudo cat /sys/kernel/debug/pinctrl/pinctrl-handles may give you some more information on which driver has claimed the GPIO via Linux. Otherwise quote the whole of your config.txt (using code tags please).
Please don't send PMs asking for support - use the forum.
trbotha
Mon Oct 23, 2017 12:28 pm
Using sudo cat /sys/kernel/debug/pinctrl/pinctrl-handles provided the following
device: [email protected] current state: default
state: default
type: MUX_GROUP controller pinctrl-bcm2835 group: gpio4 (4) function: gpio_i
type: CONFIGS_PIN controller pinctrl-bcm2835 pin gpio4 (4)config 00000000
This meant that the pin was controlled by the onewire interface commenting the following line in /boot/config.txt seems to have fixed the problem
#dtoverlay=w1-gpio
