mwh123
How to configure GSM SIM800L in raspberry pi 3 without using serial
Mon Oct 16, 2017 8:59 pm
HOw to configure GSM SIM800L in raspberry pi 3 But not using Gpio Rx & Tx. Because I used Rx&Tx pin for Gps Neo6m in same time Kindly give me suggestion ....Thanks
Re: How to configure GSM SIM800L in raspberry pi 3 without using serial
Tue Oct 17, 2017 6:19 pm
Connect an Arduino Nano using USB, you may need to run SoftwareSerial on the Arduino Nano.
In some cases you can run this blank sketch on the Arduino (using pin#2/pin#3)
void setup() {
void loop() {
in other cases you'll need to run
#include <SoftwareSerial.h>
#define BAUD 152000
SoftwareSerial SerialS(4,5);
void setup() {
  Serial.begin(BAUD);
  SerialS.begin(BAUD);
  Serial.write("Ready");
  delay(1000);
void loop() {
  if (SerialS.available()) {
    byte s1 = SerialS.read();
    Serial.write(s1);
  if (Serial.available()) {
    byte s = Serial.read();
    SerialS.write(s);
with the serial device connected to pin#4/pin#5 on the Arduino.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
Since 2012: 1B*5, 2B*2, B+, A+, Zero*2, 3B*3
Please post ALL technical questions on the forum. Do not send private messages.
Who is online
Users browsing this forum: mattmiller and 15 guests
