bl392-ak
Pigpio I2C read has erratic speed
Mon Mar 20, 2017 1:34 pm
I am using an MPU 6000 chip and I am aiming to read it at ~1kHz. Most of the time this is absolutely fine. However sometimes the read time jumps to 1-10ms instead of the normal 0.4ms. I am using the pigpio library for the I2C communication.
t1 = gpioTick();
result = i2cReadI2CBlockData(m_currentI2C, regAddr, reinterpret_cast<char*>(data) + position, getLength);
t2 = gpioTick();
Most of the results of this are in the range 200-400, but I get occasional (1 in 1000) spikes in the 1000-10000 range. Any suggestions on ways to avoid this would be appreciated. Is it just the MPU chip being unreliable? The above code is in a loop that is triggered by an interrupt from the MPU.
joan
Re: Pigpio I2C read has erratic speed
Mon Mar 20, 2017 1:39 pm
The pigpio i2c* calls are just wrappers around the underlying Linux SMBus/I2C implementation. It may just be normal Linux scheduling delays.
r3bpy
Mon Jun 19, 2017 6:53 pm
This might be clock stretching issue, the slave does not respond in time and Pi reads incorrect data - I have observed it multiple times (Pi 3B), exactly as described bellow:
http://www.advamation.com/knowhow/raspb ... c-bug.html
Since pigpio i2c* calls rely on Pi's implementation of I2C you sill can be affected by this bug. I switched to pigpio bit-banging I2C implementation (set of bb_i2c* calls) and can confirm that it works more reliably than the native SMBus/I2C implementation.
Who is online
Users browsing this forum: No registered users and 22 guests
