so2akt
On RPi1 type B is NOT supported official touchscreen?
Mon Jun 19, 2017 7:12 am
I'm trying to use official 7-inch touchscreen on Raspi 1 type B.
connect with DSI cable and 4 pins (red-5V, black-GND, yellow-SCL, blue-SDA), then did following commands,
but no items are displayed on touchscreen...
sudo apt-get update
sudo apt-get install --reinstall libraspberrypi0 libraspberrypi-{bin,dev,doc} raspberrypi-bootloader
sudo reboot
However, on Raspi 2 type B, the touchscreen works!
Does anyone can use the touchscreen on Raspi 1 type B?
On Raspi 1 type B, the touchscreen is NOT supported??
Re: On RPi1 type B is NOT supported official touchscreen?
Mon Jun 19, 2017 8:03 am
On a RPi 1A or 1B you need to use four wires. You need the the I²C connection as well as the power connected before you boot. You need to ensure that the ribbon cable is in the right way round, that's a common failure.
You also need a modern version of Raspbian which includes the hardware support code. Ancient old Wheezy won't drive it.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
6by9
Mon Jun 19, 2017 8:21 am
I'm sure there's a reason that documentation is written, but I'm not sure what it is seeing as people never read it.
https://www.raspberrypi.org/documentati ... /README.md Most of it is but attaching to a model A or B.
Please don't send PMs asking for support - use the forum.
so2akt
Mon Jun 19, 2017 12:03 pm
Thanks for replying,
DougieLawson wrote:Ancient old Wheezy won't drive it.
it is quite simple problem, I'm trying to do on WHEEZY...
download and burn JESSIE img on SD, and according to README on documentation,
official touchscreen was enabled as follows:
so, the touchscreen will not work on other Raspbian WHEEZY based distributions?
6by9
Mon Jun 19, 2017 12:30 pm
If the touchscreen is working on your Pi2 with Wheezy, then it should work on the Pi B too provided you add that extra bit to config.txt.
Mon Jun 19, 2017 5:15 pm
What possible reasons do you have for sticking with "ancient old, unsupported, unsupportable" Wheezy? Note: some of the final versions of Wheezy did have the touch screen support.
The time to upgrade is NOW!
MQTT Evangelist
Who is online
Users browsing this forum: No registered users and 13 guests
