Sun Mar 19, 2017 9:20 pm
Hi PhilBot,
please have it.
I got this driver working!
* FB driver for the SSD1289 LCD Controller
* Copyright (C) 2013 Noralf Tronnes
* Init sequence taken from ITDB02_Graph16.cpp - (C)2010-2011 Henning Karlsen
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
#include <linux/module.h>
#include <linux/kernel.h>
#include <linux/init.h>
#include <linux/gpio.h>
#include "fbtft.h"
#define DRVNAME "fb_ssd1289"
#define WIDTH 320
#define HEIGHT 240
#define DEFAULT_GAMMA "02 03 2 5 7 7 4 2 4 2\n" \
"02 03 2 5 7 5 4 2 4 2"
// color definitions
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
static unsigned reg11 = 0x6040;
module_param(reg11, uint, 0);
MODULE_PARM_DESC(reg11, "Register 11h value");
static int init_display(struct fbtft_par *par)
fbtft_par_dbg(DEBUG_INIT_DISPLAY, par, "%s()\n", __func__);
par->fbtftops.reset(par);
if (par->gpio.cs != -1)
gpio_set_value(par->gpio.cs, 0); /* Activate chip */
// SSD2119 - START INIT
write_reg(par, 0x0028, 0x0006);
//write_command(0x0028); // VCOM OTP
//write_data(0x0006); // Page 55-56 of SSD2119 datasheet
write_reg(par, 0x0000, 0x0001);
//write_command(0x0000); // start Oscillator
//write_data(0x0001); // Page 36 of SSD2119 datasheet
write_reg(par, 0x0010, 0x0000);
//write_command(0x0010); // Sleep mode
//write_data(0x0000); // Page 49 of SSD2119 datasheet
write_reg(par, 0x0001, 0x30EF);//32EF
//write_command(0x0001); // Driver Output Control
//write_data(0x72EF); // Page 36-39 of SSD2119 datasheet
write_reg(par, 0x0002, 0x0600);
//write_command(0x0002); // LCD Driving Waveform Control
//write_data(0x0600); // Page 40-42 of SSD2119 datasheet
write_reg(par, 0x0003, 0x6A38);
//write_command(0x0003); // Power Control 1
//write_data(0x6A38); // Page 43-44 of SSD2119 datasheet
write_reg(par, 0x0011, 0x6870);
//write_command(0x0011); // Entry Mode
//write_data(0x6870); // Page 50-52 of SSD2119 datasheet
write_reg(par, 0x000F, 0x0000);
//write_command(0X000F); // Gate Scan Position
write_reg(par, 0X000B, 0x5308);
//write_command(0X000B); // Frame Cycle Control
//write_data(0x5308); // Page 45 of SSD2119 datasheet
write_reg(par, 0X000C, 0x0003);
//write_command(0x000C); // Power Control 2
//write_data(0x0003); // Page 47 of SSD2119 datasheet
write_reg(par, 0X000D, 0x000A);
//write_command(0x000D); // Power Control 3
//write_data(0x000A); // Page 48 of SSD2119 datasheet
write_reg(par, 0x000E, 0x2E00);
//write_command(0x000E); // Power Control 4
//write_data(0x2E00); // Page 48 of SSD2119 datasheet
write_reg(par, 0x001E, 0x00BE);
//write_command(0x001E); // Power Control 5
//write_data(0x00BE); // Page 53 of SSD2119 datasheet
write_reg(par, 0x0025, 0x8000);
//write_command(0x0025); // Frame Frequency Control
//write_data(0x8000); // Page 53 of SSD2119 datasheet
write_reg(par, 0x0026, 0x7800);
//write_command(0x0026); // Analog setting
//write_data(0x7800); // Page 54 of SSD2119 datasheet
write_reg(par, 0x004E, 0x0000);
//write_command(0x004E); // Ram Address Set
//write_data(0x0000); // Page 58 of SSD2119 datasheet
write_reg(par, 0x004F, 0x0000);
//write_command(0x004F); // Ram Address Set
write_reg(par, 0x0012, 0x08D9);
//write_command(0x0012); // Sleep mode
//write_data(0x08D9); // Page 49 of SSD2119 datasheet
// Gamma Control (R30h to R3Bh) -- Page 56 of SSD2119 datasheet
write_reg(par, 0x0030, 0x0000);
//write_command(0x0030);
write_reg(par, 0x0031, 0x0104);
//write_command(0x0031);
//write_data(0x0104);
write_reg(par, 0x0032, 0x0100);
//write_command(0x0032);
//write_data(0x0100);
write_reg(par, 0x0033, 0x0305);
//write_command(0x0033);
//write_data(0x0305);
write_reg(par, 0x0034, 0x0505);
//write_command(0x0034);
//write_data(0x0505);
write_reg(par, 0x0035, 0x0305);
//write_command(0x0035);
write_reg(par, 0x0036, 0x0707);
//write_command(0x0036);
//write_data(0x0707);
write_reg(par, 0x0037, 0x0300);
//write_command(0x0037);
//write_data(0x0300);
write_reg(par, 0x003A, 0x1200);
//write_command(0x003A);
//write_data(0x1200);
write_reg(par, 0x003B, 0x0800);
//write_command(0x003B);
//write_data(0x0800);
write_reg(par, 0x0007, 0x0033);
//write_command(0x0007); // Display Control
//write_data(0x0033); // Page 45 of SSD2119 datasheet
//delay(150);
write_reg(par, 0x0044, 0xEF00);
//write_command(0x0044); // Vertical RAM address position
//write_data(0xEF00); // Page 57 of SSD2119 datasheet
write_reg(par, 0x0045, 0x0000);
//write_command(0x0045); // Horizontal RAM address position
//write_data(0x0000); // Page 57 of SSD2119 datasheet
write_reg(par, 0x0046, 0x013F);
//write_command(0x0046); // Horizontal RAM address position
//write_data(0x013F); // Page 57 of SSD2119 datasheet
write_reg(par, 0x0022);
//write_command(0x0022); // RAM data write/read
// SSD2119 - END
write_reg(par, 0x00, 0x0001);
write_reg(par, 0x03, 0xA8A4);
write_reg(par, 0x0C, 0x0000);
write_reg(par, 0x0D, 0x080C);
write_reg(par, 0x0E, 0x2B00);
write_reg(par, 0x1E, 0x00B7);
write_reg(par, 0x01,
(1 << 13) | (par->bgr << 11) | (1 << 9) | (HEIGHT - 1));
write_reg(par, 0x02, 0x0600);
write_reg(par, 0x10, 0x0000);
write_reg(par, 0x05, 0x0000);
write_reg(par, 0x06, 0x0000);
write_reg(par, 0x16, 0xEF1C);
write_reg(par, 0x17, 0x0003);
write_reg(par, 0x07, 0x0233);
write_reg(par, 0x0B, 0x0000);
write_reg(par, 0x0F, 0x0000);
write_reg(par, 0x41, 0x0000);
write_reg(par, 0x42, 0x0000);
write_reg(par, 0x48, 0x0000);
write_reg(par, 0x49, 0x013F);
write_reg(par, 0x4A, 0x0000);
write_reg(par, 0x4B, 0x0000);
write_reg(par, 0x44, 0xEF00);
write_reg(par, 0x45, 0x0000);
write_reg(par, 0x46, 0x013F);
write_reg(par, 0x23, 0x0000);
write_reg(par, 0x24, 0x0000);
write_reg(par, 0x25, 0x8000);
write_reg(par, 0x4f, 0x0000);
write_reg(par, 0x4e, 0x0000);
write_reg(par, 0x22);
return 0;
static void set_addr_win(struct fbtft_par *par, int xs, int ys, int xe, int ye)
fbtft_par_dbg(DEBUG_SET_ADDR_WIN, par,
"%s(xs=%d, ys=%d, xe=%d, ye=%d)\n", __func__, xs, ys, xe, ye);
switch (par->info->var.rotate) {
/* R4Eh - Set GDDRAM X address counter */
/* R4Fh - Set GDDRAM Y address counter */
case 0:
write_reg(par, 0x4e, xs);
write_reg(par, 0x4f, ys);
break;
case 180:
write_reg(par, 0x4e, par->info->var.xres - 1 - xs);
write_reg(par, 0x4f, par->info->var.yres - 1 - ys);
break;
case 270:
write_reg(par, 0x4e, par->info->var.yres - 1 - ys);
write_reg(par, 0x4f, xs);
break;
case 90:
write_reg(par, 0x4e, ys);
write_reg(par, 0x4f, par->info->var.xres - 1 - xs);
break;
/* R22h - RAM data write */
static int set_var(struct fbtft_par *par)
unsigned int aa,bb;// temp
if (par->fbtftops.init_display != init_display) {
/* don't risk messing up register 11h */
"%s: skipping since custom init_display() is used\n",
__func__);
return 0;
case 0:
write_reg(par, 0x11, reg11 | 0b110000);
break;
case 270:
write_reg(par, 0x11, reg11 | 0b101000);
break;
case 180:
write_reg(par, 0x11, reg11 | 0b000000);
break;
case 90:
write_reg(par, 0x11, reg11 | 0b011000);
break;
for(aa=0;aa<320;aa++)
for(bb=0;bb<240;bb++)
if(aa>279)write_reg(par,BLACK);
else if(aa>239)write_reg(par,BLUE);
else if(aa>199)write_reg(par,GREEN);
else if(aa>159)write_reg(par,CYAN);
else if(aa>119)write_reg(par,RED);
else if(aa>79)write_reg(par,MAGENTA);
else if(aa>39)write_reg(par,YELLOW);
else write_reg(par,WHITE);
return 0;
Gamma string format:
VRP0 VRP1 PRP0 PRP1 PKP0 PKP1 PKP2 PKP3 PKP4 PKP5
VRN0 VRN1 PRN0 PRN1 PKN0 PKN1 PKN2 PKN3 PKN4 PKN5
#define CURVE(num, idx) curves[num*par->gamma.num_values + idx]
static int set_gamma(struct fbtft_par *par, unsigned long *curves)
unsigned long mask[] = {
0b11111, 0b11111, 0b111, 0b111, 0b111,
0b111, 0b111, 0b111, 0b111, 0b111,
0b111, 0b111, 0b111, 0b111, 0b111 };
int i, j;
/* apply mask */
for (i = 0; i < 2; i++)
for (j = 0; j < 10; j++)
CURVE(i, j) &= mask[i*par->gamma.num_values + j];
write_reg(par, 0x0030, CURVE(0, 5) << 8 | CURVE(0, 4));
write_reg(par, 0x0031, CURVE(0, 7) << 8 | CURVE(0, 6));
write_reg(par, 0x0032, CURVE(0, 9) << 8 | CURVE(0, 8));
write_reg(par, 0x0033, CURVE(0, 3) << 8 | CURVE(0, 2));
write_reg(par, 0x0034, CURVE(1, 5) << 8 | CURVE(1, 4));
write_reg(par, 0x0035, CURVE(1, 7) << 8 | CURVE(1, 6));
write_reg(par, 0x0036, CURVE(1, 9) << 8 | CURVE(1, 8));
write_reg(par, 0x0037, CURVE(1, 3) << 8 | CURVE(1, 2));
write_reg(par, 0x003A, CURVE(0, 1) << 8 | CURVE(0, 0));
write_reg(par, 0x003B, CURVE(1, 1) << 8 | CURVE(1, 0));
return 0;
#undef CURVE
static struct fbtft_display display = {
.regwidth = 16,
.width = WIDTH,
.height = HEIGHT,
.gamma_num = 2,
.gamma_len = 10,
.gamma = DEFAULT_GAMMA,
.fbtftops = {
.init_display = init_display,
.set_addr_win = set_addr_win,
.set_var = set_var,
.set_gamma = set_gamma,
FBTFT_REGISTER_DRIVER(DRVNAME, "solomon,ssd1289", &display);
MODULE_ALIAS("spi:" DRVNAME);
MODULE_ALIAS("platform:" DRVNAME);
MODULE_ALIAS("spi:ssd1289");
MODULE_ALIAS("platform:ssd1289");
MODULE_DESCRIPTION("FB driver for the SSD1289 LCD Controller");
MODULE_AUTHOR("Noralf Tronnes");
MODULE_LICENSE("GPL");
- IMAG1126_small.jpg (59.54 KiB) Viewed 1506 times
