PieHead
raspivid - h264 video doesnt have any duration data when pl
Wed Jan 21, 2015 11:11 pm
I have a rasp pi B+ model with the camera module installed. When I use the following basic cmd
raspivid -o v.h264 -t 10000
If I export v.h264 to my windows machine and play it back with VLC, I see that the video timebar remains at 00:00 throughout the whole video, also the end timer is always fixed at 00:00, when usually this end timer shows the total runtime of the video file.(which in this case should be 00:10)
Is there a way to get this information up, or tell raspivid to store the data in the file without taking the raw footage and encoding it with ffmpeg and the likes.
Re: raspivid - h264 video doesnt have any duration data when
Thu Jan 22, 2015 8:46 am
The H264 stream is exactly that, a stream of H264 data, and H264 data has no time stamping, for example, it doesn't know what frame rate it was recorded at or it's duration.
To add that information you need to encapsulate the stream in a container such as MP4 or MKV which contains this extra information. This can be done using the avconv program, Google that and raspberry pi to find instructions. Once encapsulated you should get the information you need and it will play back on anything.
ghans
Thu Jan 22, 2015 8:56 am
sudo apt-get install gpac
MP4Box -fps 30 -add infile.h264 outfile.mp4
No re-encoding necessary , just "muxing" .
ghans
EDIT: typo corrected , thanks lbendlin
lbendlin
Sun Jan 25, 2015 6:24 pm
small correction - it's MP4Box with a capital B.
BorisS
Mon Jan 26, 2015 4:31 pm
I don't know if it is still an issue but in the past you couldn't be sure that #fps that have been recorded was that one cam was configured for. Especially in low light conditions, instantaneous fps rate dropped down to lower values.
My workarround was to record only segments, then compute the effective #fps by counting frames (using the real ffmpeg) and extracting segment duration by file time stamps. A little bit annoying and not perfect, but the best solution I could find.
Return to “Camera board”
