6by9
Re: Remove metering
Tue Jun 23, 2015 6:19 pm
Patch just released that corrects the digital gain initialisation.
sudo rpi-update to get it for those wanting to test.
ethanol100
Re: Remove metering
Wed Jul 01, 2015 9:27 am
6by9 wrote:Patch just released that corrects the digital gain initialisation.
Thanks for the patch! Now the gains are both set to 1 if exposure mode is initial set to MMAL_PARAM_EXPOSUREMODE_OFF. And the exposure time is set to ~10ms if not specified. It works for both raspistill and raspivid. I think it is now a really useful feature.
6by9
Re: Remove metering
Wed Jul 01, 2015 10:54 am
I know ISO doesn't work though. I don't want to have to duplicate lots of code to compute A & D gains from ISO values, but also getting it to run the once on a change of ISO isn't simple.
What I might look at doing is exposing the default digital gain value that will be set if we hit this condition of needing to set defaults. I might be able to expose analogue gain too, but other things are occupying my time at present.
Pidestrian
Re: Remove metering
Thu Jul 02, 2015 11:49 am
Hi, I updated the firmware and tried to run
raspivid -k -t 0 -ex off -ss 10000 -set
however the exposure mode "off" is not found.
"RaspiVid: Unknown exposure mode: off"
Have i missed something?
The patch is applied to the firmware itself? So in case that I use my own code to interface with the camera and set the exposure mode with :
mmal_port_parameter_set (...)
the camera will now have fixed analog /digital gains?
Is it possible to set those gains manually?
Are these gain values related to AWB gains?
6by9
Re: Remove metering
Thu Jul 02, 2015 12:36 pm
-ex off was removed (or never added) due to this bug existing in the first place. Someone needs to create a patch and make a pull request for it to get merged into the main userland repo now that the bug is (hopefully) fixed).
I think it should be as simple as
diff --git a/host_applications/linux/apps/raspicam/RaspiCamControl.c b/host_applications/linux/apps/raspicam/RaspiCamControl.c
index 1f4e8b7..3d0157c 100755
--- a/host_applications/linux/apps/raspicam/RaspiCamControl.c
+++ b/host_applications/linux/apps/raspicam/RaspiCamControl.c
@@ -55,7 +55,8 @@ static XREF_T  exposure_map[] =
    {"verylong",      MMAL_PARAM_EXPOSUREMODE_VERYLONG},
    {"fixedfps",      MMAL_PARAM_EXPOSUREMODE_FIXEDFPS},
    {"antishake",     MMAL_PARAM_EXPOSUREMODE_ANTISHAKE},
-   {"fireworks",     MMAL_PARAM_EXPOSUREMODE_FIREWORKS}
+   {"fireworks",     MMAL_PARAM_EXPOSUREMODE_FIREWORKS},
+   {"off",           MMAL_PARAM_EXPOSUREMODE_OFF}
and then use "-ex off" on the command line, but I'm not in a place to test it at the moment. ethanol100 appears to have tested it, so I guess he already has a patch that he could push.
This is purely setting analogue and overall digital gains for AE/AGC control. Set exposure mode off at start, and you will get both set to x1.0. At present it is not possible to get user specified values - that is my comment about ISO not working.
AWB gains can already be specified by setting awb mode to off, and using -awbg to set the desired red and blue gains. Covered originally under viewtopic.php?f=43&t=58803&start=75#p525733
ethanol100
Re: Remove metering
Thu Jul 02, 2015 12:59 pm
6by9 wrote:ethanol100 appears to have tested it, so I guess he already has a patch that he could push.
Yes it is only the one additional entry and there is still the pull request https://github.com/raspberrypi/userland/pull/171 which could now be accepted.
6by9
Re: Remove metering
Thu Jul 02, 2015 1:23 pm
Thanks. I've just commented on that PR and pinged popcornmix and Jamesh.
waveform80
Re: Remove metering
Tue Jul 28, 2015 7:24 am
Fantastic news! Only just saw this, but many thanks to everyone involved - this'll come in very handy in future :)
Dave.
Author of / contributor to a few pi related things (picamera, Sense HAT emulator, gpio-zero, piwheels, etc.), and currently a software engineer at Canonical responsible for Ubuntu Server and Core on the Raspberry Pi.
Joan Carles
Re: Remove metering
Fri Oct 16, 2015 5:21 pm
I did it, it's working fantastic!!!
Thank you so much!!!!
jbeale
Re: Remove metering
Fri Oct 16, 2015 7:49 pm
I look forward to trying this- true fixed gain makes the difference between "useful" and "not useful" in a lot of measurement applications.
namorK
Re: Remove metering
Wed Dec 02, 2015 11:12 am
dear all. i'm also trying to get rid off auto exposure and i'm confused if "-ex off" is now implemented in the official raspbian wheezy mai 2015, of if i need to do the patch described in the thread. thanks for any help.
(raspivid -o b-h264 -w 1920 -h 1080 -ex off -awb sun -fps 25 -ISO 100 -ss 2500 -sh -100 -b 750000 -t 21600000)
6by9
Re: Remove metering
Wed Dec 02, 2015 11:52 am
namorK wrote:dear all. i'm also trying to get rid off auto exposure and i'm confused if "-ex off" is now implemented in the official raspbian wheezy mai 2015, of if i need to do the patch described in the thread. thanks for any help.
https://github.com/raspberrypi/userland/pull/171 (referenced earlier) was merged 2 July, so as long as your Pi is running a more recent release then yes it is there.
Add -set to your command and it will print out shutter speed and gains used.
namorK
Re: Remove metering
Wed Dec 02, 2015 12:22 pm
thank you very much!
namorK
Re: Remove metering
Thu Dec 03, 2015 6:12 pm
dear 6by9. thanks a lot. i couldn't find out where the -set command is documented and how to get it to work. could you elaborate a little how to see the gain used while video capturing?
6by9
Re: Remove metering
Thu Dec 03, 2015 8:20 pm
Er, literally add "-set" to the end of your command, so based on what you quoted it'll end up as
raspivid -o b-h264 -w 1920 -h 1080 -ex off -awb sun -fps 25 -ISO 100 -ss 2500 -sh -100 -b 750000 -t 21600000 -set
For me, I get
pi@raspberrypi ~ $ raspivid -o b-h264 -w 1920 -h 1080 -ex off -awb sun -fps 25 -ISO 100 -ss 2500 -sh -100 -b 750000 -t 21600000 -set
mmal: Exposure now 9985, analog gain 256/256, digital gain 0/256
mmal: AWB R=0/256, B=0/256
mmal: Exposure now 2500, analog gain 304/256, digital gain 601/256
mmal: AWB R=428/256, B=284/256
mmal: Exposure now 2500, analog gain 304/256, digital gain 429/256
Ignore the error on unknown exposure mode - I'm on an old raspivid as I was working on something else.
Documentation: run "raspivid --help"
pi@raspberrypi ~ $ raspivid --help
Display camera output to display, and optionally saves an H264 capture at requested bitrate
usage: raspivid [options]
Image parameter commands
-?, --help      : This help information
-cs, --camselect        : Select camera <number>. Default 0
-set, --settings        : Retrieve camera settings and write to stdout
-md, --mode     : Force sensor mode. 0=auto. See docs for other modes available
Return to “Camera board”
