benderman
Camera not working
Mon Jan 05, 2015 12:45 pm
Hi Guys,
I have recently got the camera module to go with my B+ and when I try and take a picture like using the following command
I get the red light on (stays on) and I get an unexpected callback message.
I have googled it and tried:
Checking the cable (both ends)
Amending etc/modules as per a tutorial on github
Pressing the beige part of the camera
Is there anything else I could try or is it dead?
Cheers,
Ben
Re: Camera not working
Mon Jan 05, 2015 12:49 pm
Check the small "SUNNY" connector between the camera and the camera board. Use thumb & forefinger pressure to ensure it's clicked all the way into it's socket.
benderman
Mon Jan 05, 2015 2:49 pm
Thanks I'll try that tonight.
pluggy
Mon Jan 05, 2015 3:21 pm
You could try a beefier power supply, the camera (and pi while its running it) use a lot of power and it can cause problems if the power supply isn't up to it.
didzan
Wed Jan 07, 2015 8:44 pm
Hi all,
I'm having an issue with the Pi Camera. I want to stream video and detect faces with OpenCV. I have found some tutorial and work in my Ubuntu. However when I try to run the same file.py on Raspberry Pi doesn't work.
My code is like that:
import cv2
import numpy
import sys
faceCascade = cv2.CascadeClassifier(filename='haarcascade_frontalface_default.xml')
video_capture = cv2.VideoCapture(0)
video_capture.open(0)
while True:
    ret, frame = video_capture.read()
    gray = cv2.cvtColor(frame, cv2.COLOR_BGR2GRAY)
    faces = faceCascade.detectMultiScale(
        gray,
        scaleFactor=1.1,
        minNeighbors=5,
        minSize=(30, 30),
        flags=cv2.cv.CV_HAAR_SCALE_IMAGE
    # Draw a rectangle around the faces
    for (x, y, w, h) in faces:
        cv2.rectangle(frame, (x, y), (x+w, y+h), (0, 255, 0), 2)
    # Display the resulting frame
    cv2.imshow('Video', frame)
    if cv2.waitKey(1) & 0xFF == ord('q'):
        break
# When everything is done, release the capture
video_capture.release()
cv2.destroyAllWindows()
I'm using a Pi NoIR Camera Board.
The terminal shows in cv2.COLOR_BGR2GRAY
Please help, and excuse my English
Wed Jan 07, 2015 9:26 pm
http://www.raspberrypi.org/forums/viewt ... 37&t=91269
Also take a look at
http://www.themagpi.com/issue/issue-28/
http://www.themagpi.com/issue/issue-29/
There's a couple of articles and some sample code from Derek "Guzunty" Campbell on this exact subject.
Return to “Camera board”
