xulander
Motion-Mmal: I want to disable live stream capabilities
Tue Dec 23, 2014 4:39 am
I have a few questions about Motion-MMAL for the Raspberry Pi B+ model, running on Raspbian: Sorry if these are noob questions.
1) I want to disable the live stream capability completely; however, i can only find information on how to keep the live stream local
2) If I do not visit the local address for the live stream, is it still technically uploading data and live streaming?
dozencrows
Re: Motion-Mmal: I want to disable live stream capabilities
Tue Dec 23, 2014 6:13 pm
As per the comments in the supplied config file's 'Live Stream Server' section, you can disable streaming by setting stream_port to zero.
If streaming is enabled but no client (e.g. web browser) is connected, then it doesn't stream - and consequently doesn't use up processing power. If you watch the CPU load before and after connecting to the stream port, you can see the difference.
Return to “Camera board”
