thamaeng
Pi camera error
Tue Nov 25, 2014 8:27 pm
I am using camera preview in my program. i am using a condition to stop the preview. after stopping the preview, the red light in the camera remains on. it will not off unless i switch off the Raspberry pi. If i try to run the program again with the red light on in camera, its giving me a error somthing like this.
raise PicameraMMALError (status, prefix)
picamera.exc.picameraMMALError: camera component couldn't be enabled : out of resorrces( other than memory)
im only using the "if distance<2" to stop the preview since i didnt find any other way. when i do the ctrl+c, it only stop the program and camera preview is still there.if there is another way to stop it please let me know. please help me to fix the code.Thank you.
import time
import RPi.GPIO as GPIO
import os
import picamera
GPIO.setmode(GPIO.BCM)
GPIO_TRIGGER = 23
GPIO_ECHO = 24
print "Ultrasonic Measurement"
GPIO.setup(GPIO_TRIGGER,GPIO.OUT)  # Trigger
GPIO.setup(GPIO_ECHO,GPIO.IN)      # Echo
GPIO.output(GPIO_TRIGGER, False)
time.sleep(0.5)
GPIO.output(GPIO_TRIGGER, True)
time.sleep(0.00001)
start = time.time()
while GPIO.input(GPIO_ECHO)==0:
  start = time.time()
while GPIO.input(GPIO_ECHO)==1:
  stop = time.time()
elapsed = stop-start
distance = elapsed * 34000
distance = distance / 2
return distance
camera = picamera.PiCamera()
camera.start_preview()
while True:
	time.sleep(0.3)
	print distance
	if (distance < 2):
		camera.stop_preview()
	if (distance < 5):
		os.system (' omxplayer -o local stop.mp3')
	if (distance < 10):
		os.system (' omxplayer -o local safe.mp3')
Return to “Camera board”
