Page 1 of 4
B+ Camera is not detected (workaround available)
Posted: Thu Aug 07, 2014 11:38 pm
by k6rtm
I moved a (Raspberry Pi) camera module from a working Raspberry Pi model B to a new B+. Software is current (3.12.26+ #702) on both B and B+ systems. Camera module is enabled using raspi-config (how do I confirm this?). Running raspistill -o click.jpg returns:
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
mmal: Failed to create camera component
mmal: main: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly
Moved camera module back to its old model B home -- works fine (powering systems off, observing ESD precautions for each move, carefully seating ribbon cable). Moved to B+ again, along with the micro-SD card from the model B -- boot it up, and get the same failure, camera not detected. Rebooted with the B+ micro-SD again, same thing, camera not detected.
Tried on my second B+ with same results, camera not detected.
Running the diagnostic suggested for camera issues: (hostname is moander; bonus points if you recognize the SF story)
16:14 pi@moander ~ $ vcgencmd get_mem arm
arm=384M
16:15 pi@moander ~ $ vcgencmd get_mem gpu
gpu=128M
16:15 pi@moander ~ $ free -h
total used free shared buffers cached
Mem: 373M 149M 224M 0B 13M 102M
-/+ buffers/cache: 33M 340M
Swap: 99M 0B 99M
16:15 pi@moander ~ $ raspistill -d
reboot and try again, no camera detected.
Moved the camera module to a B again, and it still works.
Yet it doesn't work on
either of my Raspberry Pi B+ systems. Am I detecting a pattern here?
I'm stumped. Where do I go from here? I don't suspect power supply issues; using well filtered 5VDC 2A supplies that have run Model B + camera packages for months, and USB cables used for those systems so IR losses from the USB cables not suspected (but then again I haven't actually checked the voltage on the B+ board -- you took away my TP1 and TP2 test points and haven't given me schematics enough for me to put in new test points).
Many thanks -- most of the time my Raspberry Pi menagerie is very well behaved!
Re: B+ Camera is not detected
Posted: Fri Aug 08, 2014 1:24 am
by AndrewS
How weird!
On my B+ the camera works fine both before and after the very-latest rpi-update.
vcgencmd get_camera
You can also use 'vcgencmd version' to get the exact version of the firmware.
As long as the red PWR led is lit solidly (and not off or flickering) then that indicates your voltage is fine.
Posted: Fri Aug 08, 2014 1:39 am
by k6rtm
thanks for the diagnostic tips --
16:26 pi@moander ~ $ vcgencmd get_camera
supported=1 detected=0
18:37 pi@moander ~ $ vcgencmd version
Aug 6 2014 17:51:37
Copyright (c) 2012 Broadcom
version 3da89bd3cdef7980b684f48fe60944aff4502f50 (tainted) (release)
Other than being unclean (tainted), the camera is listed as supported but not detected. I'll check the connector again, but I'm pretty sure I know how to seat flex cables in these things...
--bob
Posted: Fri Aug 08, 2014 8:57 am
by ShiftPlusOne
The fact that it's not detected indicates that the i2c communication with the camera failed.
If you have wiringpi installed, what's the output of gpio readall?
Posted: Fri Aug 08, 2014 1:35 pm
by togusa
Had the same issue with two B+. The issue appears when I'm enabling I2C support. By disabling it camera is working again. So check your /etc/modules file and disable any i2c module you may have, reboot and check. Must be a bug do you know where we can report it?
Posted: Fri Aug 08, 2014 2:43 pm
by ShiftPlusOne
The camera's I2C port is reserved for videocore. So trying to fiddle with it from ARM, will cause problems. In a way, it's user error, since you're doing something you shouldn't be doing. But my vote is that it's actually a problem with the driver. It really shouldn't touch VC's I2C port at all. If it needs to be reported somewhere, I'm thinking it should be an issue on the raspberry pi linux github repo.
Posted: Fri Aug 08, 2014 2:51 pm
by ShiftPlusOne
One problem with people jumping in on threads like this with "me too" is that it might not have anything at all to do with OP's problem. For example, in another thread, a guy had a bad power supply, which prevented the camera from working. Another guy jumped in claiming he has the same problem, but his power supply was fine, so the two issues were completly unrelated. The thread was somewhat difficult to follow as a result.
I'm thinking there should be a camera Troubleshooting/FAQ thread which gives you a checklist of things to run through before starting a camera support thread and what information you should provide when you do. Not sure that I know enough to do that though.
Posted: Fri Aug 08, 2014 2:58 pm
by AndrewS
ShiftPlusOne wrote:I'm thinking there should be a camera Troubleshooting/FAQ thread which gives you a checklist of things to run through before starting a camera support thread and what information you should provide when you do. Not sure that I know enough to do that though.
Rather than create a specific thread, you could simply add more info to
http://www.raspberrypi.org/documentatio ... /camera.md ?
Posted: Fri Aug 08, 2014 3:02 pm
by ShiftPlusOne
Good call
Posted: Fri Aug 08, 2014 3:13 pm
by AndrewS
ShiftPlusOne wrote:The camera's I2C port is reserved for videocore. So trying to fiddle with it from ARM, will cause problems. In a way, it's user error, since you're doing something you shouldn't be doing. But my vote is that it's actually a problem with the driver. It really shouldn't touch VC's I2C port at all. If it needs to be reported somewhere, I'm thinking it should be an issue on the raspberry pi linux github repo.
Confirmed with my B+ and camera. If I comment-out "blacklist i2c-bcm2708" in /etc/modprobe.d/raspi-blacklist.conf and reboot, then I get the same camera errors as described above. If I un-comment it again (so i2c-bcm2708
is blacklisted) and then reboot, then the camera works again. But as soon as I "sudo modprobe i2c_bcm2708" then the camera stops working again. And "sudo rmmod i2c_bcm2708" doesn't 're-enable' the camera
So definitely seems to be a bug in the I2C driver when running on the Model B+. I'm sure there's probably many projects on the Model B that use both the camera and I2C (via I2C-1) at the same time?
Posted: Fri Aug 08, 2014 3:19 pm
by ShiftPlusOne
Hm, it should be fixable on the firmware end as well. I am working on something else right now, but I could come back to the cameras if this turns out to be a common problem (which it may, by the sounds of it).
AndrewS, does the firmware version have any effect on it? For example, does the camera work with the pre-gpioman or pre-dualcam firmware?
d1f2609959e435c61db8fc2d27f82fd3bce7e9ef
d9eb023ba98317d81fc53a3f9d6752b127a8dbbf
Posted: Fri Aug 08, 2014 4:00 pm
by AndrewS
ShiftPlusOne wrote:AndrewS, does the firmware version have any effect on it? For example, does the camera work with the pre-gpioman or pre-dualcam firmware?
Jul 20 2014 16:03:57
version d8cfa5ccd979ca458fef97e87c14eb804c93762b (clean) (release)
Camera stops working after "sudo modprobe i2c_bcm2708"
Jul 5 2014 19:03:42
version cb433d55f9f5b29b59968019e3b54802894af489 (clean) (release)
Camera keeps working after "sudo modprobe i2c_bcm2708"
I'm afraid I don't have time to bisect in which versions it works / breaks, and I'm going to be away for the next few days (Pi-less).
Hmmm, now I'm
really confused!!! After the last test above I then did a regular rpi-update to get me back to the bleeding-edge firmware (followed by a reboot) which brought me back to
Aug 6 2014 17:51:37
And then the camera
did still keep working after "sudo modprobe i2c_bcm2708" ?! So I rebooted, and it still kept working after "sudo modprobe i2c_bcm2708"! So then I did a power-off and physically removed and reconnected power, and this time after booting up (with
no other changes to the previous test) it goes back to the camera
not working after "sudo modprobe i2c_bcm2708"
Posted: Fri Aug 08, 2014 4:05 pm
by ShiftPlusOne
You don't have a dt-blob.bin, do you?
Posted: Fri Aug 08, 2014 4:14 pm
by AndrewS
ShiftPlusOne wrote:You don't have a dt-blob.bin, do you?
$ ls -l /boot
total 9784
-rwxr-xr-x 1 root root 17840 Aug 8 15:44 bootcode.bin
-rwxr-xr-x 1 root root 120 Jun 20 06:51 cmdline.txt
-rwxr-xr-x 1 root root 1202 Jun 20 09:35 config.txt
-rwxr-xr-x 1 root root 2279 Aug 8 15:44 fixup_cd.dat
-rwxr-xr-x 1 root root 6066 Aug 8 15:44 fixup.dat
-rwxr-xr-x 1 root root 9114 Aug 8 15:44 fixup_x.dat
-rwxr-xr-x 1 root root 137 Jun 20 10:33 issue.txt
-rwxr-xr-x 1 root root 3223744 Aug 8 15:44 kernel.img
-rwxr-xr-x 1 root root 18974 Sep 25 2013 LICENSE.oracle
-rwxr-xr-x 1 root root 528696 Aug 8 15:44 start_cd.elf
-rwxr-xr-x 1 root root 2595064 Aug 8 15:44 start.elf
-rwxr-xr-x 1 root root 3550344 Aug 8 15:44 start_x.elf
It's a bog-standard 2014-06-20-wheezy-raspbian.img that I wrote to a (64GB) microSD card just last night.
Posted: Fri Aug 08, 2014 4:15 pm
by ShiftPlusOne
Ah okay. If you have wiringpi installed, the gpio tool could be very handy here. I suspect that the camera isn't working because of the way the pins are set up when the i2c module loads. So gpio readall should be insightful.
Posted: Fri Aug 08, 2014 4:47 pm
by k6rtm
On my older model B with the camera, I have blacklist entries:
blacklist spi-bcm2708
Which is interesting as I have the AdaFruit PiTFT display running on that one, and IIRC it uses both I2C and SPI, and the camera works fine
The other B, the one I pulled the camera from, definitely has I2C in use, and has both the blacklist entries commented out, and the camera works fine on that one.
On my B+, when I comment out the blacklist lines:
# blacklist spi and i2c by default (many users don't need them)
# blacklist spi-bcm2708
# blacklist i2c-bcm2708
and /etc/modules has: (the same /etc/modules file is used on all systems)
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
# Parameters can be specified after the module name.
snd-bcm2835
# k6rtm 2013/03/13
ipv6
i2c-bcm2708
i2c-dev
after rebooting, the camera still isn't detected.
And I'm off to work -- let me know what else to try!
Posted: Fri Aug 08, 2014 4:49 pm
by k6rtm
gpio readall probes with the system as it started, no camera connected, and then with blacklists pulled and camera connected--
09:04 pi@moander ~/wiringPi $ gpio readall
+-----+-----+---------+------+---+--B Plus--+---+------+---------+-----+-----+
| BCM | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | BCM |
| | | 3.3v | | | 1 || 2 | | | 5v | | |
| 2 | 8 | SDA.1 | ALT0 | 1 | 3 || 4 | | | 5V | | |
| 3 | 9 | SCL.1 | ALT0 | 1 | 5 || 6 | | | 0v | | |
| 4 | 7 | GPIO. 7 | IN | 1 | 7 || 8 | 1 | ALT0 | TxD | 15 | 14 |
| | | 0v | | | 9 || 10 | 1 | ALT0 | RxD | 16 | 15 |
| 17 | 0 | GPIO. 0 | IN | 0 | 11 || 12 | 0 | IN | GPIO. 1 | 1 | 18 |
| 27 | 2 | GPIO. 2 | IN | 0 | 13 || 14 | | | 0v | | |
| 22 | 3 | GPIO. 3 | IN | 0 | 15 || 16 | 0 | IN | GPIO. 4 | 4 | 23 |
| | | 3.3v | | | 17 || 18 | 0 | IN | GPIO. 5 | 5 | 24 |
| 10 | 12 | MOSI | IN | 0 | 19 || 20 | | | 0v | | |
| 9 | 13 | MISO | IN | 0 | 21 || 22 | 0 | IN | GPIO. 6 | 6 | 25 |
| 11 | 14 | SCLK | IN | 0 | 23 || 24 | 1 | IN | CE0 | 10 | 8 |
| | | 0v | | | 25 || 26 | 1 | IN | CE1 | 11 | 7 |
| 0 | 30 | SDA.0 | ALT0 | 1 | 27 || 28 | 1 | ALT0 | SCL.0 | 31 | 1 |
| 5 | 21 | GPIO.21 | IN | 1 | 29 || 30 | | | 0v | | |
| 6 | 22 | GPIO.22 | IN | 1 | 31 || 32 | 0 | IN | GPIO.26 | 26 | 12 |
| 13 | 23 | GPIO.23 | IN | 0 | 33 || 34 | | | 0v | | |
| 19 | 24 | GPIO.24 | IN | 0 | 35 || 36 | 0 | IN | GPIO.27 | 27 | 16 |
| 26 | 25 | GPIO.25 | IN | 0 | 37 || 38 | 0 | IN | GPIO.28 | 28 | 20 |
| | | 0v | | | 39 || 40 | 0 | IN | GPIO.29 | 29 | 21 |
09:05 pi@moander ~/wiringPi $ echo "No camera connected" && gpio readall
No camera connected
changed blacklist, camera connected but not detected
09:33 pi@moander ~ $ gpio readall
| 10 | 12 | MOSI | ALT0 | 0 | 19 || 20 | | | 0v | | |
| 9 | 13 | MISO | ALT0 | 0 | 21 || 22 | 0 | IN | GPIO. 6 | 6 | 25 |
| 11 | 14 | SCLK | ALT0 | 0 | 23 || 24 | 1 | ALT0 | CE0 | 10 | 8 |
| | | 0v | | | 25 || 26 | 1 | ALT0 | CE1 | 11 | 7 |
now off to the salt mines!
Posted: Fri Aug 08, 2014 5:04 pm
by AndrewS
Okay, wiringPi built and installed. Here we go... (from a cold power-on)
$ vcgencmd version
Aug 6 2014 17:51:37
$ gpio readall
| 2 | 8 | SDA.1 | IN | 1 | 3 || 4 | | | 5V | | |
| 3 | 9 | SCL.1 | IN | 0 | 5 || 6 | | | 0v | | |
| 0 | 30 | SDA.0 | IN | 1 | 27 || 28 | 1 | IN | SCL.0 | 31 | 1 |
$ raspistill -v
raspistill Camera App v1.3.8
Width 2592, Height 1944, quality 85, filename (null)
Time delay 5000, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Link to latest frame enabled no
Full resolution preview No
Capture method : Single capture
Preview Yes, Full screen Yes
Preview window 0,0,1024,768
Opacity 255
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
Camera component done
Encoder component done
Starting component connection stage
Connecting camera preview port to video render.
Connecting camera stills port to encoder input port
Closing down
Close down completed, all components disconnected, disabled and destroyed
$ sudo modprobe i2c_bcm2708
$ raspistill -v
Opacity 255
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: Failed to run camera app. Please check for firmware updates
$ gpio readall
| 3 | 9 | SCL.1 | ALT0 | 0 | 5 || 6 | | | 0v | | |
$ sudo rpi-update d9eb023ba98317d81fc53a3f9d6752b127a8dbbf
*** Raspberry Pi firmware updater by Hexxeh, enhanced by AndrewS and Dom
*** Performing self-update
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 7037 100 7037 0 0 22461 0 --:--:-- --:--:-- --:--:-- 33831
*** Relaunching after update
*** Downloading specific firmware revision (this will take a few minutes)
100 168 100 168 0 0 237 0 --:--:-- --:--:-- --:--:-- 336
0 0 0 21.1M 0 0 833k 0 --:--:-- 0:00:26 --:--:-- 408k
*** Updating firmware
*** Updating kernel modules
*** depmod 3.12.24+
*** Updating VideoCore libraries
*** Using HardFP libraries
*** Updating SDK
*** Running ldconfig
*** Storing current firmware revision
*** Deleting downloaded files
*** Syncing changes to disk
*** If no errors appeared, your firmware was successfully updated to d9eb023ba98317d81fc53a3f9d6752b127a8dbbf
*** A reboot is needed to activate the new firmware
$ sudo reboot
$ vcgencmd version
Jul 5 2014 19:03:42
$ raspistill -v
(works fine)
$ gpio readall
| 4 | 7 | GPIO. 7 | IN | 0 | 7 || 8 | 1 | ALT0 | TxD | 15 | 14 |
| 11 | 14 | SCLK | IN | 0 | 23 || 24 | 0 | IN | CE0 | 10 | 8 |
| | | 0v | | | 25 || 26 | 0 | IN | CE1 | 11 | 7 |
| 0 | 30 | SDA.0 | IN | 0 | 27 || 28 | 0 | IN | SCL.0 | 31 | 1 |
| 5 | 21 | GPIO.21 | IN | 0 | 29 || 30 | | | 0v | | |
| 6 | 22 | GPIO.22 | IN | 0 | 31 || 32 | 0 | IN | GPIO.26 | 26 | 12 |
$ sudo modprobe i2c-bcm2708
$ gpio readall
| 0 | 30 | SDA.0 | ALT0 | 0 | 27 || 28 | 0 | ALT0 | SCL.0 | 31 | 1 |
$ raspistill -v
(works fine)
$ sudo rpi-update
100 7037 100 7037 0 0 12102 0 --:--:-- --:--:-- --:--:-- 13480
100 168 0 168 0 0 311 0 --:--:-- --:--:-- --:--:-- 437
100 21.2M 100 21.2M 0 0 687k 0 0:00:31 0:00:31 --:--:-- 358k
*** depmod 3.12.26+
*** Updating SDK
*** If no errors appeared, your firmware was successfully updated to e38850519c56b835dbd1c81e04d9307e154c36ed
$ sudo reboot
$ vcgencmd version
Aug 6 2014 17:51:37
$ raspistill -v
(works fine)
$ gpio readall
$ gpio readall
$ raspistill -v
(works fine)
$ sudo reboot
$ raspistill -v
(works fine)
$ gpio readall
$ gpio readall
$ raspistill -v
(works fine)
$ sudo poweroff
(disconnect and then reconnect power)
$ gpio readall
$ raspistill -v
(works fine)
$ gpio readall
$ raspistill -v
Opacity 255
...and with that, I'm signing off for the day!
Posted: Fri Aug 08, 2014 7:27 pm
by DirkS
k6rtm wrote:Which is interesting as I have the AdaFruit PiTFT display running on that one, and IIRC it uses both I2C and SPI, and the camera works fine
IIRC PiTFT only uses SPI
Gr.
Dr.
Posted: Fri Aug 08, 2014 7:46 pm
by ShiftPlusOne
I think I know what the problem is on the firmware side, but I'm not sure if it should be addressed there or in the i2c driver. Ah well, I'll play around with it on Monday.
Posted: Fri Aug 08, 2014 9:10 pm
by LetHopeItsSnowing
I have just come across exactly the same problem. Camera fails to be detected when using i2c on a B+.
Posted: Fri Aug 08, 2014 9:26 pm
by ShiftPlusOne
Pretty safe to call this one 100% confirmed then. Will get it sorted.
Posted: Sat Aug 09, 2014 1:51 am
by k6rtm
Look forward to a solution, and prior to that, any workarounds that don't involve the ritual sacrifice of small animals...
(thanks for working on this!)
Posted: Sat Aug 09, 2014 7:15 pm
by redlegoman
Looking forward to a fix/workaround. I'm using the camera and a realtime clock that uses i2c. Or rather I'm not, because I can have one or the other!
Posted: Sat Aug 09, 2014 11:51 pm
by skypi
guess arch has i2c enabled as default then, cam worked on raspbian but not arch
