Page 3 of 4
Re: B+ Camera is not detected (workaround available)
Posted: Fri Aug 15, 2014 5:29 pm
by ShiftPlusOne
Yup, I have been meaning to get more photos up there, but haven't been able to get a hold of the camera.
Posted: Fri Aug 15, 2014 5:46 pm
by RichShumaker
ShiftPlusOne wrote:Yup, I have been meaning to get more photos up there, but haven't been able to get a hold of the camera.
I have had the issues and I have a camera and cable.
I will strip down a camera rig tonight and take the images.
Good and bad connections on both sides and a broken connector on the board. I have broken two so far, not quite sure how I will 'fix' them yet.
I will make them 'web friendly png's' and post them on my site for download.
You can grab and post on github, is that cool with you @ShiftPlusOne?
Posted: Fri Aug 15, 2014 5:56 pm
by ShiftPlusOne
That sort of thing is not up to me. But I can send a pull request for you if the images are good.
Posted: Sat Aug 16, 2014 12:55 pm
by AndrewS
RichShumaker wrote:Being a github noob I didn't know how to add an inline image without hosting it and linking the image when embedding it.
https://github.com/raspberrypilearning/ ... .md#images
Unfortunately you can't add files to github using the webinterface, AFAIK you have to use a local git client.
Posted: Sun Aug 17, 2014 6:01 pm
by RichShumaker
Thanks AndrewS and ShiftPlusOne - I ran out of time last night to strip the camera, will do that hopefully today. I will webize the images I take and see what I can do with GIT. Thanks for all your help.
Posted: Thu Aug 21, 2014 1:04 am
by RichShumaker
Images are available, next step is making them more web friendly and githubbin' them.
http://richshumaker.com/raspi/images/
I noticed it is hard to see the difference at the camera when it is loosely connected.
Posted: Thu Aug 21, 2014 1:31 am
by k6rtm
I notice there's a firmware update available today, to 3.12.26+ #704
I would hope that someone will post an update on this thread when a firmware update eliminates the necessity to run camerafix on startup.
Many thanks--
Posted: Thu Aug 21, 2014 6:36 am
by ShiftPlusOne
As explained earlier, this is a kernel bug. The firmware doesn't do anything wrong.
Posted: Thu Aug 21, 2014 11:48 am
by sKooTtr
So who is responsible for fixing the kernel and is this underway?
Looking forward to having a working product soon :-) .
Scott
Posted: Tue Sep 02, 2014 10:45 pm
by k6rtm
It seems the recently release 3.12.26 #707 does not require running the camerafix.sh hack after reboot -- at least that's the case on my B+
cheers--
bob
Posted: Tue Sep 02, 2014 11:33 pm
by AndrewS
k6rtm wrote:It seems the recently release 3.12.26 #707 does not require running the camerafix.sh hack after reboot -- at least that's the case on my B+
Are you sure? I just checked and even with 3.12.26+ #707 I still get the same behaviour as in http://www.raspberrypi.org/forums/viewt ... 83#p594883 (and I couldn't see any recent kernel or firmware commits mentioning I2C either :geek: )
Maybe camerafix.sh is just being run automatically and you're not realising? ;)
Posted: Wed Sep 03, 2014 12:00 am
by k6rtm
I did the firmware update to 3.12.26+ #707, rebooted, and did a raspistill capture without running the camerafix script -- and the raspistill capture worked. In prior lives, rebooting and trying a raspistill capture elicited error messages (requiring yet another reboot and running the raspistill script prior to accessing the camera).
I didn't do a full power cycle of the device, but I did reboot, and the little sucker seems to work, capturing images on an aperiodic basis.
As we say over here in the (former) Colonies, "your mileage may vary."
--bob
Posted: Wed Sep 03, 2014 12:50 am
by AndrewS
And does lsmod show that i2c_bcm2708 is loaded?
Posted: Wed Sep 03, 2014 3:45 am
by k6rtm
20:43 [email protected] ~ $ lsmod
Module                  Size  Used by
md4                     3311  0
md5                     1784  1
hmac                    2602  1
nls_utf8                1235  2
cifs                  287100  3
i2c_dev                 5769  0
ipv6                  315765  31
snd_bcm2835            19584  0
snd_soc_wm8804          7932  0
snd_soc_pcm512x         9034  0
snd_soc_bcm2708_i2s     6202  0
regmap_mmio             2818  1 snd_soc_bcm2708_i2s
snd_soc_core          127841  3 snd_soc_pcm512x,snd_soc_wm8804,snd_soc_bcm2708_i2s
snd_compress            8259  1 snd_soc_core
regmap_i2c              1661  3 snd_soc_pcm512x,snd_soc_wm8804,snd_soc_core
snd_pcm_dmaengine       5505  1 snd_soc_core
regmap_spi              1913  3 snd_soc_pcm512x,snd_soc_wm8804,snd_soc_core
snd_pcm                83845  3 snd_bcm2835,snd_soc_core,snd_pcm_dmaengine
snd_page_alloc          5132  1 snd_pcm
snd_seq                55484  0
snd_seq_device          6469  1 snd_seq
snd_timer              20998  2 snd_pcm,snd_seq
8192cu                550797  0
leds_gpio               2079  0
led_class               4118  1 leds_gpio
snd                    62252  7 snd_bcm2835,snd_soc_core,snd_timer,snd_pcm,snd_seq,snd_seq_device,snd_compress
spi_bcm2708             4960  0
i2c_bcm2708             4943  0
Posted: Wed Sep 03, 2014 8:43 am
by ShiftPlusOne
sKooTtr wrote:So who is responsible for fixing the kernel and is this underway?
Scott
I've asked and got the strong impression that it might be me. Of course once it's "fixed" (a dirty workaround is put into the kernel), there will be a wave of complaints from people currently using the videocore's i2c peripheral. I'll take a look and keep you folks posted.
For testing, would you prefer a patch, a forked github repo or a compiled kernel+modules package?
Posted: Thu Sep 04, 2014 3:49 pm
by ShiftPlusOne
rpi-update should fix the problem now.
https://github.com/raspberrypi/linux/co ... 6467c7a86f
https://github.com/raspberrypi/firmware ... 8d5cc81180
If, for whatever reason, you need to override the new behaviour, add bcm2708.vc_i2c_override=1 to cmdline.txt
Posted: Thu Sep 04, 2014 4:39 pm
by k6rtm
Many thanks!
--bob
Posted: Fri Sep 05, 2014 9:33 am
by ShiftPlusOne
No worries, sorry I didn't do this straight away. Didn't think it would be that simple.
Posted: Fri Sep 05, 2014 10:39 am
by gregeric
ShiftPlusOne wrote:rpi-update should fix the problem now.
One reason would be to write a B+ HAT's id eeprom - perhaps some mention of this new behaviour/cmdline.txt option should go there, & in the HAT forum.
Posted: Fri Sep 05, 2014 11:05 am
by ShiftPlusOne
gregeric wrote: One reason would be to write a B+ HAT's id eeprom - perhaps some mention of this new behaviour/cmdline.txt option should go there, & in the HAT forum.
Yup, good point. Either that, or add a mailbox interface to handle the flashing and reading. I've passed it on to the powers that be.
Posted: Tue Sep 09, 2014 3:45 pm
by AndrewS
Hmmm, comparing https://github.com/raspberrypi/linux/co ... a026878ee5 and https://github.com/raspberrypi/linux/co ... 6467c7a86f shows two different Pi-specific kernel modules checking for the Pi's revision in two slightly different ways - one by checking (system_rev & 0xffffff) and the other by checking (boardrev & 0xffffff).
Is one method "more correct" than the other (and if so should the "less correct" version be edited to match, for consistency?), or are both methods equally valid?
And just to be awkward, how does the ComputeModule (and http://www.raspberrypi.org/documentatio ... uration.md ) fit into all this? ;)
Posted: Tue Sep 09, 2014 4:13 pm
by ShiftPlusOne
AndrewS wrote:Hmmm, comparing https://github.com/raspberrypi/linux/co ... a026878ee5 and https://github.com/raspberrypi/linux/co ... 6467c7a86f shows two different Pi-specific kernel modules checking for the Pi's revision in two slightly different ways - one by checking (system_rev & 0xffffff) and the other by checking (boardrev & 0xffffff).
I don't think that either is more correct, it's just used in different context. boardrev is a module parameter which belongs to the platform. system_rev is a generic ARM thing. Since I'm checking the revision from the platform file itself, it made sense to use boardrev and system_rev isn't even defined until near the end of the function. I could've moved it up, but why? It could be argued that using system_rev would be more consistent, but meh.
On the i2s module end, boardrev does not belong to it, and system_rev exists exactly for this sort of purpose. Leaving system_rev as the only sensible option.
Not sure I understand what you mean by the CM question though.
Posted: Tue Sep 09, 2014 4:59 pm
by AndrewS
ShiftPlusOne wrote:I don't think that either is more correct, it's just used in different context.
Since I'm checking the revision from the platform file itself...
Oh yeah, I'd missed that one block of code was from a kernel module, and the other block of code was from the platform file! Whoops, mea culpa.
I meant that with the change you've made to the platform file, you've asserted that for boadrevs 0x2 and 0x3 (i.e. RPi rev 1.0) the "user i2c" is I2C-0 (bcm2708_bsc0_device), and for every other boardrev the "user i2c" is I2C-1 (bcm2708_bsc1_device). I guess what I was trying to ask is is this assumption also true for the Compute Module, or should the code also automatically expose both i2c channels on the CM (without needing to edit cmdline.txt)? Or will that cause problems when people then try to use the RPi camera on the CM?
Or (more likely) am I just getting confused? ;)
Posted: Tue Sep 09, 2014 9:42 pm
by ShiftPlusOne
AndrewS wrote: I meant that with the change you've made to the platform file, you've asserted that for boadrevs 0x2 and 0x3 (i.e. RPi rev 1.0) the "user i2c" is I2C-0 (bcm2708_bsc0_device), and for every other boardrev the "user i2c" is I2C-1 (bcm2708_bsc1_device). I guess what I was trying to ask is is this assumption also true for the Compute Module, or should the code also automatically expose both i2c channels on the CM (without needing to edit cmdline.txt)? Or will that cause problems when people then try to use the RPi camera on the CM?
I think this one can be easily argued both ways too. In the end, it will probably be defined using a device tree file and industrial users will be able to configure the hardware to suit their needs that way. It seems to me that the override parameter has all use cases covered until then.
Posted: Tue Sep 09, 2014 10:05 pm
by AndrewS
ShiftPlusOne wrote:I think this one can be easily argued both ways too. In the end, it will probably be defined using a device tree file and industrial users will be able to configure the hardware to suit their needs that way. It seems to me that the override parameter has all use cases covered until then.
I've just double-checked http://www.raspberrypi.org/documentatio ... -camera.md and whether one or two cameras are attached, the cameras always talk to the GPU via I2C-0 (leaving I2C-1 free for use by the user).
In which case your fix does make sense on the CM too, and so I was probably getting confused/concerned about nothing ;)
