Camera framerate 1% faster than requested
Posted: Thu Jul 10, 2014 10:59 am
by lwd8cmd
Hi!
I tried to record video with picamera using variable framerate (camera.framerate=0, exposure_mode='night') and detect real fps using motion vectors stream. For some reason calculated fps were higher than they should be. Here is a test script to find real framerate when camera.framerate is set to 90.
import picamera
import picamera.array
import time
fps	= 30
class DetectMotion(picamera.array.PiMotionAnalysis):
	def analyse(self, a):# method is called for each frame
		self.i	+= 1
		if self.i > self.fpsUpdate:
			curTime	= time.time()
			self.fps	= float(self.fpsUpdate) / (curTime - self.lastTime)
			print(self.fps, self.i, curTime)
			self.i	= 0
			self.lastTime	= curTime
			self.fpsUpdate	= int(self.fps * 10)
	def setI(self, fps):
		self.i	= 0
		self.fpsUpdate	= fps * 10
		self.lastTime	= time.time()
	camera.resolution	= (80, 60)
	camera.framerate	= fps
	with DetectMotion(camera) as motionDetector:
		motionDetector.setI(fps)
		camera.start_recording('/dev/null', format='h264', motion_output=motionDetector)
		camera.wait_recording(300)
and screen output:
(90.64054710017014, 901, 1404987424.683723)
(91.1498060304278, 907, 1404987434.623404)
(91.11016823524258, 912, 1404987444.622288)
(91.09151915592423, 912, 1404987454.623219)
(91.11739475477107, 911, 1404987464.610335)
(91.11531729942031, 912, 1404987474.608654)
(91.09084596834764, 912, 1404987484.609659)
(91.12406443833711, 911, 1404987494.596044)
Calculated fps is off more than 1%. Camera is able to record video faster than 90 fps? Same script with fps=30 gives real framerate 30.363121614197492, which is again 1% larger.
It's not a problem with picamera, because raspivid gives similar results:
raspivid -w 320 -h 240 -fps 90 -qp 40 -t 300000 -o test_fps90.h264
MP4Box -add test_fps90.h264 -fps 90 test_fps90.mp4
AVC-H264 import - frame size 320 x 240 at 90.000 FPS
AVC Import results: 27395 samples - Slices: 457 I 26938 P 0 B - 0 SEI - 457 IDR
Saving to /mnt/usbdrive/test_fps90.mp4: 0.500 secs Interleaving
Created video length is 05:04 although it should be 5 minutes. Number of I frames+P frames is 457+26938, fps=(457+26938)/300=91.317. Is camera clock running faster than raspi clock?
Re: Camera framerate 1% faster than requested
Posted: Thu Jul 10, 2014 11:09 am
by jamesh
lwd8cmd wrote:Hi!
import picamera
import time
fps	= 30
		self.i	+= 1
			self.i	= 0
		self.i	= 0
and screen output:
I think this might be partially down to the clock setting for the camera being defined to a slightly different value (a bit lower) to the incoming clock as supplied by the crystal on the board. It needs tweaking, but I haven't had time to look at it.
Posted: Thu Jul 10, 2014 11:40 am
by 6by9
The register settings from Ominvision were for a 24.8MHz clock. The oscillator fitted by Farnell and RS is 25MHz. Difference is 0.8%, so the sensor is framing 0.8% too fast, hence a slight difference in framerate.
Is 1% really that big a deal to you? It may be possible to tweak the sensor PLL settings to get exactly the desired pixel rate, but I wouldn't say it was the highest priority ever.
Posted: Thu Jul 10, 2014 11:51 am
by lwd8cmd
Getting slightly faster framerate is not a problem. I thought my code (calculating fps using motion vectors callback) was wrong and spent some time figuring out why it's giving values outside of the limits.
