lewis321
video update rate is too slow when using openCV
Sun Jun 22, 2014 2:03 am
Hi, I buy a camera module from net and install and setup it according to the video:
http://www.raspberrypi.org/help/camera-module-setup/
My camera module is the same as that in this video. After the installation of openCV on Pi, I use following command to start my camera module:
sudo modprobe bcm2835-v4l2
Then, I run the following openCV code:
import cv
cv.NamedWindow("w1", cv.CV_WINDOW_AUTOSIZE)
camera_index = 0
capture = cv.CaptureFromCAM(camera_index)
def repeat():
    global capture #declare as globals since we are assigning to them now
    global camera_index
    frame = cv.QueryFrame(capture)
    cv.ShowImage("w1", frame)
    c = cv.WaitKey(10)
    if(c=="n"): #in "n" key is pressed while the popup window is in focus
        camera_index += 1 #try the next camera index
        if not capture: #if the next camera index didn't work, reset to 0.
            camera_index = 0
while True:
    repeat()
Then, I can see the window displaying video, but its update frequency is too slow, about 0.2Hz. It needs 5 seconds to update one frame!!! I guess it might be the reason of its high resolution. I do not need high resolution. I only need high update frequency, at lest 10Hz. How to solve my problem? Thank you.
lewis321
Re: video update rate is too slow when using openCV
Sun Jun 22, 2014 2:52 am
To show my problem better, I recorded a video and you can watch it here:
https://www.dropbox.com/s/t7n2lwr6ceze9 ... quency.wmv
From this video, you can clearly see that its update frequency is too slow.
Thank you.
lewis321
Sun Jun 22, 2014 3:15 am
This is what I get when using "lsmod" command:
https://www.dropbox.com/s/t3eahyr5skz41qw/lsmod.jpg
6by9
Sun Jun 22, 2014 11:44 am
I did a load of investigation into OpenCV and getting it to work with the V4L2 driver. There are a bundle of posts starting from about http://www.raspberrypi.org/forums/viewt ... 2s#p528389
The main thing was that OpenCV was setting the framerate to 30fps, but was then unable to keep up with the results. Manually setting a lower framerate meant it kept up and significantly reduced the latency. There appeared not to be a way to do that programmatically from OpenCV.
There was also a change to support BGR24 so that OpenCV wasn't doing the conversion from YUV (or worse still MJPEG) on the ARM. Have you done an rpi-update recently to get the latest changes? (These were actually probably about 2 months back, so it isn't that recent in reality). Run the terminal command v4l2-ctl -V will tell you what format V4L2 is delivering to your application.
Return to “Camera board”
