silviodelgado70
Questions about Picam
Sat Jun 14, 2014 1:09 pm
I have been working with sources of raspistill and raspivid, trying to get an image from raspi-camera to opencv. I'm aplying OpenGL shader to preprocess the image, and then I use glReadPixels to get the rendered image to OpenCV. My code is still in development of course, and I have a lot of questions. So if anyone out there could help me, please answer the ones you can.
1- What are the differences between the three ports of camera component?
2- Is 30 the max frame rate of the camera preview port?
3- Which of the three ports outputs is the best choice to be passed to OpenGL?
4- Is it possible to make multiple shader passes? Can I render to a texture to use it again in rendering but with other shader?
5- Is there a way to avoid using glReadPixels to get the rendered image to OpenCV (I mean render to shared memory for example)?
silviodelgado70
Re: Questions about Picam
Mon Jul 28, 2014 7:25 pm
I have answered some of my own questions but i need help.
Can someone give me a link to an example of rendering with multiple shader passes using opengles in rpi?
lagurus
Thu Jul 31, 2014 10:52 am
silviodelgado70 wrote:I have answered some of my own questions but i need help.
Try to look at https://github.com/lagurus/userland_bgs.
silviodelgado70
Thu Jul 31, 2014 12:45 pm
This is very good stuff. Thank you very much, I really apreciate it.
Return to “Camera board”
