nickneubrand
Pygame Camera
Mon Jun 09, 2014 1:10 am
Hey Guys,
Its been a while since I have used my Raspi because the last thing I worked on involved the camera unit when there was no driver. I was wondering if there have been any developments in a driver that works with pygame? I looked all around to find out if there was, with no success. This is what I am trying to run/was trying to run about a year ago. The issue then and now seems to still be the "/dev/video0". Is there a device name that I am unaware of that will allow me to access the camera or will I have to find another way such as an alternative driver such as a UV4L? If so can you link the website for it because the last one I had is no longer working.
pygame.init()
pygame.camera.init()
screen = pygame.display.set_mode([640,480])
cam = pygame.camera.Camera("/dev/video0", (640,480))
cam.start()
Thanks!
-Nick
nickneubrand
Re: Pygame Camera
Mon Jun 09, 2014 2:40 am
On the topic of cameras not working I tried then to stop using Pygame and just use Python
import picamera
import time
with picamera.Picamera() as camera:
    camera.resolution = (640,480)
    camera.start_preview()
after running the whole sudo apt - get install python-picamera, now I just keep getting errors saying that there is "No module named picamera"
Getting really frustrated with this camera again because there is no easy way to access it through a python script. (Which is why i bought it over a year ago) and it still just gaining dust
ghans
Re: Pygame Camera
Mon Jun 09, 2014 9:13 am
The foundation has released the official V4L2 driver some time
ago :
http://www.raspberrypi.org/forums/viewt ... 43&t=62364
It should work with PyGame as-is , but many people are using
picamera already.
Is there a typo in your code ? The example says
with picamera.PiCamera() as camera:
instead of
ghans
nickneubrand
Re: Pygame Camera
Mon Jun 09, 2014 7:16 pm
Thanks for the info!
I accidentally typed in the code incorrectly when uploading.
When you say "It should work with PyGame as-is" do you mean with the name "/dev/video0" or is there a completely separate format that I am unaware of?
Also, what is the benefit of using picamera over this driver? I eventually did get picamera to work, but cannot get it within a windowed application with the camera.start_preview() . I later found out that it cannot be put in a window (as of now). So why would I want to use picamera?
ghans
Re: Pygame Camera
Mon Jun 09, 2014 8:18 pm
Yes , the foundation driver creates a /dev/video0 device.
So it works directly with any V4L2-enabled piece of software ,
including PyGame.
ghans
Return to “Camera board”
