Mettauk
Using DateTime as a file name with timelapse -tl
Thu May 08, 2014 11:36 am
the top code works fine
raspistill -w 1280 -h 720 -x -n -tl 1000 -t 7200000 -o /media/KINGSTON/tlCAP/tl_%05d.jpg
But this fails..
raspistill -w 1280 -h 720 -x -n -tl 1000 -t 7200000 -o /media/KINGSTON/tlCAP/tl$(date +"%d%m%Y_%H%M-%S").jpg
Is there a way to use datetime rather than just numbers as datetime would mak image hunting much easier?
As humans we have been the same for a very very long time, technology changes how we do... not who we are as people.
achrn
Re: Using DateTime as a file name with timelapse -tl
Thu May 08, 2014 11:48 am
I don't know whether there's a shortcut specific to raspistill, but in general you can use backwards-single-quote marks (which might be on the key to the left of your '1' key). They generally cause the command inside the quotes to be executed and the result substituted before processing whatever is outside the quotes.
so:
raspistill -w 1280 -h 720 -x -n -tl 1000 -t 7200000 -o /media/KINGSTON/tlCAP/tl_`date +%d%m%Y_%H%M-%S`.jpg
is worth a try.
Mettauk
Thu May 08, 2014 12:46 pm
achrn wrote:I don't know whether there's a shortcut specific to raspistill, but in general you can use backwards-single-quote marks (which might be on the key to the left of your '1' key). They generally cause the command inside the quotes to be executed and the result substituted before processing whatever is outside the quotes.
so:
is worth a try.
It produces the same problem, one image only rather than a rolling quantity of jpg images with datetime names.
My guess is the video core will only output images as name/number. Using date messes with output as date is coming from the processor???? :?
algorithm
Thu May 08, 2014 12:54 pm
Backticks is the same as $(). The difference between your 2 examples is the first one provides a template to raspistill to use for numbering, while the second just runs the date command first so doesn't provide any template to raspistill. If you want raspistill to tag images by date rather than number, you need to modify the C code and compile your own version. Otherwise, you need to wrap the raspistill command in a script (bash/python/php/whatever) that takes care of the renaming by date.
Mettauk
Thu May 08, 2014 1:19 pm
snip...
An example of HOW to do this would be very welcome
Thu May 08, 2014 1:23 pm
Thu May 08, 2014 1:24 pm
Indeed - get dates in to the timelapse filenames would require a change to the C code of Raspivid - at the moment it just has the ability to use a file number. Sorry, I don't have time to do that right now.
Failing that, as mentioned above, write a script that does the timelapse stuff for you, and provide the dated filename. I think there is documentation on this here http://www.raspberrypi.org/learning/timelapse-setup/
M_P
Sun Oct 19, 2014 7:27 am
I'm next to useless when it comes to programming but here's what I did. It doesn't set a date on the filenames but instead creates a directory with the date and time and dumps the timelapse images into it. Makes it a little easier to sort through them at least.
import time
import os
getthetime = time.strftime("%Y%m%d-%H%M%S")
#Create the folder with the full path
mydir = "/mnt/"+getthetime
os.makedirs(mydir)
#Put together the line to run Raspistill
runstill = ("raspistill -tl 2000 -t 60000 -o "+mydir+"/pic%04d.jpg")
os.system(runstill)
There's a "/mnt" in front of the date because that's where I've got a USB drive mounted to hold the pictures.
tallika_fan
Wed Jul 08, 2015 8:07 am
M_P wrote:I'm next to useless when it comes to programming but here's what I did. It doesn't set a date on the filenames but instead creates a directory with the date and time and dumps the timelapse images into it. Makes it a little easier to sort through them at least.
import time
import os
os.makedirs(mydir)
os.system(runstill)
I've just implemented this code on my machine swapping out the /mnt for the local system. so far so good.
Cheers
Pete
marciano
Tue Oct 24, 2017 4:37 pm
Using exiftool it is possible to get dataTime from metadata and rename files
Return to “Camera board”
