gordon77
raspistill BMP format
Wed Apr 23, 2014 10:42 am
I saved some pics in bmp format with raspistill but I can't get any other PC, with windows, to read them, anyone know why ?
Gordon77
Re: raspistill BMP format
Wed Apr 23, 2014 10:49 am
Have you checked the magic numbers? Are you sure they are BMPs?
The file command can do that stuff for you. Unix doesn't rely on filenames to identify things unlike some inferior operating systems.
itsmedoofer
Contact: AOL
Wed Apr 23, 2014 11:33 am
Open the file in notepad on the PeeCee and you should be able to tell what it is, right at the beginning if the file is where you want to look...
ÿØÿà JFIF ` ` ÿáExif MM <- Would be a JPG
BMˆ– 6 <- Would be an example of a BMP
Crude method but should tell you.....
hk1963
Wed Apr 23, 2014 12:21 pm
How do you produce the BMP file?
What do you get in a terminal when you run the command
What is the output of
od -c picture.bmp | head
towolf
Wed Apr 23, 2014 6:30 pm
Or just use
The file command has a database of magic numbers that define file types.
gordon77
Thu Apr 24, 2014 9:44 am
hk1963 wrote:How do you produce the BMP file?
I just used the raspistill option to save bmp.
Gordon77
mikerr
Thu Apr 24, 2014 11:37 am
Note just setting the extension won't work:
you have to set the encoding (-e) too:
gordon77
Fri Apr 25, 2014 6:27 am
Gordon77
Return to “Camera board”
