paphko
Re: MMAL Motion - tuning & optimisations
Mon Aug 18, 2014 7:18 pm
These optimizations really sound great :D
And it also seems to work - to some extend.
I would like to switch off the screen after 2min of inactivity and to switch it back on when there is motion in front of it. The first part is easy: call tvservice -o after 2 minutes.
The second part should call tvservice -p if the screen is off and motion was detected. This should be done via a shell script that is called by the on_motion_detected event of motion.
Furthermore, a (single) image should be saved when motion is detected.
All this seems to work if the screen is permanently on. However, after experimenting with motion and the screen settings, it seems as if motion is not working at all when the screen is off! Log says:
[-1242765664] [NTC] [ALL] [Aug 18 20:17:26] motion_startup: Using log type (ALL) log level (WRN)
[1] [ALR] [VID] [Aug 18 20:17:26] mmalcam_start: MMAL Camera thread starting... for camera (vc.ril.camera) of 256 x 144 at 2 fps
[1] [ALR] [VID] [Aug 18 20:17:26] mmalcam_start: MMAL Camera using video capture
[0] [ERR] [ALL] [Aug 18 20:17:56] main: Thread 1 - Watchdog timeout, trying to do a graceful restart
[0] [ERR] [ALL] [Aug 18 20:18:56] main: Thread 1 - Watchdog timeout, did NOT restart graceful,killing it!
[0] [ALR] [VID] [Aug 18 20:18:56] MMAL Camera cleanup
[-1242442080] [NTC] [ALL] [Aug 18 20:43:15] motion_startup: Using log type (ALL) log level (WRN)
[1] [ALR] [VID] [Aug 18 20:43:15] mmalcam_start: MMAL Camera thread starting... for camera (vc.ril.camera) of 256 x 144 at 2 fps
[1] [ALR] [VID] [Aug 18 20:43:15] mmalcam_start: MMAL Camera using video capture
[0] [ERR] [ALL] [Aug 18 20:43:45] main: Thread 1 - Watchdog timeout, trying to do a graceful restart
The screen is attached via HDMI. Can anyone confirm this behavior?
Edit: this problem also occurs with raspistill, so I created a new thread: http://www.raspberrypi.org/forums/viewt ... 43&t=84889
lingon
Sat Aug 30, 2014 6:03 pm
Would it be possible to use the 2x2 binning modes with MMAL Motion with the new parameter MMAL_PARAMETER_CAMERA_CUSTOM_SENSOR_CONFIG ?
http://www.raspberrypi.org/forums/viewt ... 43&t=85714
This would be great for low light situations...
dozencrows
Sun Aug 31, 2014 9:38 am
In theory, not a lot of work to add - but would require some careful testing.
I'll add it to the TODO list for when it's available in the firmware.
6by9
Sun Aug 31, 2014 8:10 pm
Firmware is already out with commit https://github.com/Hexxeh/rpi-firmware/ ... 55035adf85
The likelihood is that you're already running the binned modes as they will be automatically selected if you're asking for 30fps - I wouldn't fret about getting that in as a new feature.
JumpMaster
Mon Sep 01, 2014 6:33 am
Is it possible to use this as a 24/7 recording software and to disable the motion tracking? I want an old-school style CCTV system where it's always recording and I can also get a live preview through a webpage.
The refresh rate on the webpage is fairly slow but could this be improved by writing the images to /dev/shm/ as RaspiMJPEG does?
Thanks for your help,
Kev
siyb
Tue Sep 02, 2014 1:26 pm
Just downloaded the latest version this morning and the high red images are lovely.
I've set mine up to 2560x1920 using the upscale of 5.
Images are working well using secondary, but video isn't, I've switched video output on and enabled secondary but I'm only getting the low resolution images from the primary.
Have I missed something here?
--UPDATE, FOUND THAT I HAD 2ND BUFFER QUALITY SET TO 50 - DROPPED IT DOWN TO 0 AND I'M FINE WITH 4FPS
Simon
lingon
Tue Sep 09, 2014 2:50 pm
6by9 wrote:Firmware is already out with commit https://github.com/Hexxeh/rpi-firmware/ ... 55035adf85
I'm running motion-mmal with a resolution of 1152*864 pixels and a framerate of 2 Hz. Is the 2*2 binning only available for the high framerates or can it be enabled also for lower framerates?
jbeale
Mon Sep 15, 2014 12:59 am
Following the instructions in https://github.com/dozencrows/motion/bl ... UILD-HOWTO I did this:
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get install libjpeg62 libjpeg62-dev libavformat53 libavformat-dev libavcodec53 libavcodec-dev libavutil51 libavutil-dev libc6-dev zlib1g-dev libmysqlclient18 libmysqlclient-dev libpq5 libpq-dev
cd /home/pi
git clone https://github.com/raspberrypi/userland.git
git clone https://github.com/dozencrows/motion.git --branch mmal-test --single-branch
cd motion
USERLANDPATH=/home/pi/userland cmake .
make
sudo cp configs/motion-mmalcam.conf /etc/motion.conf
./motion
and can confirm that it works. Just playing with my motion.conf now.
By the way, is there any hope of getting access to the new MMAL features, for example text annotation, or time of day? Although I suppose you'd have to mask off that part of the image from 'motion' so it wouldn't detect the constantly changing time-of-day readout as actual motion. Unless you could get the time/date selectively shown only in the scaled-up JPEG, and not the low-res JPEG that is processed by motion.
...also, as I understand it the current video output option from MMAL-Motion is MJPEG only. Is it possible to get H264 format output via MMAL (GPU, not ARM) for better storage efficiency than MJPEG?
pippip
Mon Oct 13, 2014 9:35 am
hello dozencrows,
Outstanding work.
getting back to the original thoughts around reducing image processing (motion detection) load, are there optimisation avenues to explore around scaling back the frame comparison 'rate' once motion has been detected i.e. once motion is detected only compare frame x against frame x + N where N is number of frames according to fps and a user defined period used?
I am making this suggestion without any idea around how the software glues together, but it seems logical that it could offer some additional processing capacity to increase fps for recording movie?
Apologies in advance if its stupid idea from someone with very limited programming background.
Regards
PP
dozencrows
Wed Oct 15, 2014 12:37 pm
Interesting idea - many thanks, pippip!
With a bit more memory use for temporarily holding onto frames x to x + 2N, there would be the opportunity to balance the motion detection load between frame x and frame x + N during the period x + N to x + 2N. Then if motion was detected, that would trigger a save of frames x to x + N, and the whole process would step on to frames x + N to x + 2N, and so on.
The benefits would be to allow higher frame rates for the recorded video, and motion detection on higher resolution source images as the effort would be amortised over time, rather than attempted in a single iteration of the app's main loop (i.e. a single 'frame').
I think there would be some challenges and limitations:
* This is effectively reducing the 'sample rate' at which motion is detected - so objects moving at high speeds might not trigger motion detection (e.g. if only captured on some frames between x and x + N, but not in x or x + N). How exactly this pans out would depend upon the image capture frame rate and the value of N.
* Encoding/saving of N frames would also need to be carefully load balanced to avoid causing stalls. Motion-mmal can suffer from this already (depending on the storage method), but I think this could make it worse without some effort to address it. The end result would be a more balanced system, performance-wise.
Would that my day job wasn't so demanding right now... this would be fun to at least try!
dozencrows
Wed Oct 15, 2014 12:38 pm
Oh, and there would be greater latency between motion happening and detection of that motion, of N frames.
subzer0
Mon Nov 10, 2014 10:17 pm
I have follow jbeale instruction but I can not find any movies files just jpegs in /home/pi. Have I missed something in the config?
I can see the smaller motion stream on :8085 can i access the larger stream?
hydra3333
Fri Dec 12, 2014 9:49 am
Hello.
I had it working without the secondary buffering in the .conf, then tried to add the buffering stuff and it stopped working.
Any suggestions ?
[-1242610824] [NTC] [ALL] [Dec 12 20:00:28] motion_startup: Using log type (ALL) log level (NTC)
[-1242610824] [NTC] [ALL] [Dec 12 20:00:28] become_daemon: Created process id file /var/run/motion/motion.pid. Process ID is 2109
[-1242610824] [NTC] [ALL] [Dec 12 20:00:28] motion_startup: Motion running as daemon process
[-1242610824] [NTC] [ENC] [Dec 12 20:00:28] ffmpeg_init: ffmpeg LIBAVCODEC_BUILD 3482368 LIBAVFORMAT_BUILD 3478785
[-1242610824] [NTC] [ALL] [Dec 12 20:00:28] become_daemon: Motion going to daemon mode
[0] [NTC] [ALL] [Dec 12 20:00:28] main: Thread 1 is from /etc/motion.conf
[0] [NTC] [ALL] [Dec 12 20:00:28] main: Thread 1 is device: /dev/video0 input -1
[0] [NTC] [ALL] [Dec 12 20:00:28] main: Stream port 8081
[0] [NTC] [ALL] [Dec 12 20:00:28] main: Waiting for threads to finish, pid: 2109
[1] [NTC] [ALL] [Dec 12 20:00:28] motion_init: Thread 1 started , motion detection Enabled
[1] [ALR] [VID] [Dec 12 20:00:28] mmalcam_start: MMAL Camera thread starting... for camera (vc.ril.camera) of 320 x 180 at 4 fps
[1] [ALR] [VID] [Dec 12 20:00:28] mmalcam_start: MMAL Camera using video capture
[0] [NTC] [STR] [Dec 12 20:00:28] httpd_run: motion-httpd testing : IPV4 addr: 0.0.0.0 port: 8080
[0] [NTC] [STR] [Dec 12 20:00:28] httpd_run: motion-httpd Bound : IPV4 addr: 0.0.0.0 port: 8080
[0] [NTC] [STR] [Dec 12 20:00:28] httpd_run: motion-httpd/mmaltest running, accepting connections
[0] [NTC] [STR] [Dec 12 20:00:28] httpd_run: motion-httpd: waiting for data on 0.0.0.0 port TCP 8080
[1] [NTC] [VID] [Dec 12 20:00:28] MMAL camera component created
[1] [NTC] [ALL] [Dec 12 20:00:28] image_ring_resize: Resizing pre_capture buffer to 1 items
[1] [NTC] [STR] [Dec 12 20:00:28] http_bindsock: motion-stream testing : IPV4 addr: 0.0.0.0 port: 8081
[1] [NTC] [STR] [Dec 12 20:00:28] http_bindsock: motion-stream Bound : IPV4 addr: 0.0.0.0 port: 8081
[1] [NTC] [ALL] [Dec 12 20:00:28] motion_init: Started motion-stream server in port 8081 auth Disabled
[1] [NTC] [ALL] [Dec 12 20:00:28] image_ring_resize: Resizing pre_capture buffer to 3 items
[0] [ERR] [ALL] [Dec 12 20:01:44] main: Thread 1 - Watchdog timeout, trying to do a graceful restart
[0] [NTC] [STR] [Dec 12 20:01:44] httpd_run: motion-httpd - Finishing
[0] [NTC] [STR] [Dec 12 20:01:44] httpd_run: motion-httpd Closing
[0] [NTC] [STR] [Dec 12 20:01:44] motion_web_control: motion-httpd thread exit
[0] [ERR] [ALL] [Dec 12 20:02:44] main: Thread 1 - Watchdog timeout, did NOT restart graceful,killing it!
[0] [NTC] [STR] [Dec 12 20:02:44] stream_stop: Closing motion-stream listen socket & active motion-stream sockets
[0] [NTC] [STR] [Dec 12 20:02:44] stream_stop: Closed motion-stream listen socket & active motion-stream sockets
[0] [ALR] [VID] [Dec 12 20:02:44] MMAL Camera cleanup
[0] [NTC] [ALL] [Dec 12 20:02:45] main: Motion thread 1 restart
[1] [NTC] [ALL] [Dec 12 20:02:45] motion_init: Thread 1 started , motion detection Enabled
[1] [ALR] [VID] [Dec 12 20:02:45] mmalcam_start: MMAL Camera thread starting... for camera (vc.ril.camera) of 320 x 180 at 4 fps
[1] [ALR] [VID] [Dec 12 20:02:45] mmalcam_start: MMAL Camera using video capture
[1] [NTC] [VID] [Dec 12 20:02:45] MMAL camera component created
[1] [NTC] [ALL] [Dec 12 20:02:45] image_ring_resize: Resizing pre_capture buffer to 1 items
[1] [NTC] [STR] [Dec 12 20:02:45] http_bindsock: motion-stream testing : IPV4 addr: 0.0.0.0 port: 8081
[1] [NTC] [STR] [Dec 12 20:02:45] http_bindsock: motion-stream Bound : IPV4 addr: 0.0.0.0 port: 8081
[1] [NTC] [ALL] [Dec 12 20:02:45] motion_init: Started motion-stream server in port 8081 auth Disabled
[0] [ERR] [ALL] [Dec 12 20:03:15] main: Thread 1 - Watchdog timeout, trying to do a graceful restart
# these were changed
width 320
height 180
# these were added
mmalcam_secondary_buffer_upscale 4
mmalcam_secondary_buffer_jpeg	50
ffmpeg_output_secondary_movies on
extpipe_secondary off
stream_secondary on
# these were already in place
ffmpeg_output_movies on
ffmpeg_output_debug_movies off
ffmpeg_video_codec msmpeg4
ffmpeg_deinterlace off
target_dir /home/pi/capture
hydra3333
Fri Dec 12, 2014 10:11 am
PS I commented out these
stream_secondary on
and it worked...
dozencrows
Sat Dec 13, 2014 11:14 am
If you want ffmpeg_output_secondary_movies to be on, I don't think you can have mmalcam_secondary_buffer_jpeg set to anything other than zero.
mmalcam_secondary_buffer_jpeg causes the Pi's GPU to encode the secondary buffer as a JPEG image before it reaches the motion code; this will not be understood by motion's movie encoding of the secondary buffer and might cause the problem you're seeing.
Try again with 'mmalcam_secondary_buffer_jpeg 0' and see if that helps.
However I think you'll get a very low frame rate, as by far the biggest load on the Pi CPU is motion's movie encoding. As motion is predominantly a cross-platform piece of software, it doesn't take advantage of any hardware to assist with the encoding.
hydra3333
Sat Dec 13, 2014 9:03 pm
OK Thanks. Low fps it is, unless I can find a way to later stitch jpg files into a movie and instead use jpeg output from motion-mmal-test.
The result I'm after is movie files; not fussed about streaming, so I guess this must be it to produce a .avi file -
# 4x upscale gives 1280 x 720
width 320
height 180
# per advice above
stream_secondary off
OK, I just saw this http://www.raspberrypi.org/forums/viewt ... 74#p597574 so I will take timeout to read all the posts.
edit: <snip>
edit 2: apparently this is the latest for windows:
#ffmpeg -framerate 25 -pattern_type glob -i ".\*.jpg" -c:v h264 -preset fast -profile:v high -level 4.1 -crf 16 -coder 0 -movflags +faststart -vf fps=25 -pix_fmt yuv420p -coder 0 -y out.mp4
ffmpeg -framerate 25 -pattern_type glob -i ".\*.jpg" -c:v h264 -preset fast -profile:v high -level 4.1 -crf 16 -coder 0 -movflags +faststart -vf "fps=25,format=yuv420p" -coder 0 -y out.mp4
where the framerate and fps values match the motion-mmal-test jpeg capture rate. The mp4 will play on a wdtv media player, and will be compatible with most devices.[/i]
hydra3333
Sat Dec 13, 2014 10:11 pm
Thank you a lot, Dozencrows, I will start with the config below and iterate it to something that works for me to output jpegs.
(hoping mmalcam_secondary_buffer_jpeg 100 will work)
# These proposed Raspberry Pi config settings are for motion-mmal-test using secondary buffering.
# sudo nano /etc/motion.conf and add/change settings to the values below.
# These settings are for jpeg pic outputs from the secondary buffer,
# resulting in lower cpu usage since small primary buffer is used for motion detection.
# No .avi is output although settings are prepared for it if secondary movies are
# turned on later instead of jpegs.
# Also note the stream is low-res (stream_secondary off).
# See
# http://www.raspberrypi.org/forums/viewtopic.php?f=43&t=75240&start=75
# http://www.raspberrypi.org/forums/viewtopic.php?f=43&t=75240&p=654280#p654280
# which as at 2014.12.13 say
# At the moment, this version of motion performs best when using secondary buffers for picture output only,
# *** with the mmalcam_secondary_buffer_jpeg option set to a non-zero value to make the GPU do the JPEG encoding ***
# with ffmpeg output turned off completely.
# As soon as you turn on ffmpeg output, motion starts making much heavier use of the CPU
# which really reduces the framerate on the Pi (as it's not a very powerful device).
# If you use the secondary buffer for ffmpeg output, the slowdown will be
# worse because the image is much higher resolution.
# 4x upscale gives 1280 x 720; this works, unsure which other resolutions work
width 320
height 180
# if this were output movies, framerate 2 up to maybe 3 or 4 could be achievable
framerate 10
pre_capture 2
post_capture 2
output_pictures off
output_secondary_pictures on
quality 100
picture_type jpeg
# for movie output, turn on both of these and set output_secondary_pictures off
ffmpeg_output_movies off
ffmpeg_output_secondary_movies off
# settings in case we ever output movies
ffmpeg_timelapse_mode monthly
ffmpeg_bps 500000
ffmpeg_variable_bitrate 0
# no secondary buffer piping nor streaming
# track the motion
locate_motion_mode on
locate_motion_style redbox
# allow full control of motion from other PCs
stream_localhost off
stream_auth_method 0
webcontrol_localhost off
# tell where to put the jpegs
# This ffmpeg commandline on Windows is supposed to turn the the 10fps jpegs into a movie.
ffmpeg -framerate 10 -pattern_type glob -i ".\*.jpg" -c:v h264 -preset fast -profile:v high -level 4.1 -crf 16 -coder 0 -movflags +faststart -vf "fps=10,format=yuv420p" -coder 0 -y out.mp4
# Windows ffmpeg builds available from http://ffmpeg.zeranoe.com/builds/
# I use Samba to share the Pi's capture folder with a Windows PC, you can't beat ease of use even if it's a tad slow.
edit: didn't work. :(
edit 2: turned off all secondary buffering, turned on "ordinary" jpeg output, framerate 10, pre_capture 5, post_capture 10, but don't get 10 jpeg frames/sec ... all else failed so I guess I need to read the manual
Dozencrows, just to be really clear - is the camera image captured at width 320 height 180 and the secondary buffer just upscaled from it by the GPU, or is the secondary image actually a full-res original image ?
hydra3333
Sun Dec 14, 2014 12:24 am
What a twit I am. I didn't read the dropbox download strings properly and used the github link.
There are plenty of "guides" specifying the "old" build link, including on github.
circa ? 12/may/14
http://www.codeproject.com/Articles/665 ... nce-camera
references
https://www.dropbox.com/s/xdfcxm5hu71s9 ... mal.tar.gz
Same "old" link is on the github front page
https://github.com/dozencrows/motion/tree/mmal-test
references
The build date for that motion in the .gz is 18/11/2013
newer post ? 02/Jul/14
http://www.raspberrypi.org/forums/viewt ... 13#p572313
says "s97d" is out of date, and references "binary at"
https://www.dropbox.com/s/jw5r1wss32tdi ... opt.tar.gz
newest post ? 12/08/2014
http://www.raspberrypi.org/forums/viewt ... 21#p596321
definitely says
The build date for that motion in the .gz is 11/05/2014
dozencrows
Sun Dec 14, 2014 12:07 pm
I've updated the link in the github README - my apologies, meant to do that ages ago. I don't have control over other links, so inevitably some of the tutorials referencing my work are going to age.
Regarding how the secondary buffer works - it isn't in fact upscaling the image. My choice of parameter names is a bit misleading in that respect. What my MMAL code does is take the resolution values for the primary buffer, multiply them by the upscale factor, then configure the camera to capture at that higher resolution.
It sets up a stage in the GPU image processing to make a copy of the image downscaled back to the primary buffer size settings, which is used by the motion detection algorithm. The original higher resolution image is passed on to motion's output code if motion is detected.
The end result is that the Pi has less work to do detecting motion in a lower res image, so can produce a higher frame rate with higher quality output.
dozencrows
Sun Dec 14, 2014 12:16 pm
Also note that with the latest version of the binary on DropBox, you need to ensure the width and height you set are multiples of 16. In the example config file you quote, the height is 180 which is not a multiple of 16 - try 192 instead.
Also make sure you have up-to-date Raspbian and firmware; there have been problems in the past with suspected camera firmware bugs (e.g. http://www.raspberrypi.org/forums/viewt ... 00#p571300).
andies
Sun Dec 14, 2014 1:41 pm
dozencrows wrote:Also note that with the latest version of the binary on DropBox, you need to ensure the width and height you set are multiples of 16.
Haven't you solved this "bug" recently by falling back to the number that is nearest to mod 16?
raspberry B, Noir camera, Mac Book Air, iPhone, Bezzera
dozencrows
Sun Dec 14, 2014 3:15 pm
Yes, but I haven't updated the Dropbox binary with that fix :oops: ;)
abishur
Mon Dec 15, 2014 4:16 am
Just read through this thread and I was wondering if there was ever a fix released to be able to rotate the video 180 degrees, I saw the suggestion of using -vflip, but that doesn't seem to affect my images :(
Edit: Nevermind, I just realized that I needed a second dash for it to flip things correctly. I.e.
--vflip
instead of
-vflip
Dear forum: Play nice ;-)
hydra3333
Mon Dec 15, 2014 4:56 am
OK. As at 2014.12.15 ... for absolute beginners like me, here's the .sh file I used to build the latest version of motion-mmal-test from the GIThub source, on the Pi. In the following post is a working motion.conf file which you can tailor your needs and save as /etc/motion.conf (it saves jpg files, not a video, using secondary buffers for lower cpu usage).
(beginner "Windows users": careful when editing text files on Windows and putting them back onto the Pi, Lunix it doesn't like windows text file formatting, so review the example SED command in the top of the .sh file for an example of how to fix that on the Pi).
#!/bin/bash
# also fix scripts, turning them from MS-DOS format to unix format
# to get rid of MSDOS format do this to this file: sudo sed -i s/\\r//g ./filename
# or, open in nano, control-o and then then alt-M a few times to toggle msdos format off and then save
# make the file executable by doing the following:
echo "Turn bash scripts from MS-DOS format to unix format ..."
set -x
sudo sed -i s/\\r//g /home/pi/000-build-mmal-test.sh
sudo chmod +x /home/pi/000-build-mmal-test.sh
set -x
cd /home/pi
sudo apt-get install rpi-update
sudo rpi-update
sudo apt-get update
sudo apt-get upgrade
echo "About to create folders"
read -p "Press Enter to continue..."
cd /home/pi
mkdir capture
sudo chmod 777 /home/pi/capture
mkdir build-motion-mmal
sudo chmod 777 /home/pi/build-motion-mmal
cd /home/pi/build-motion-mmal
rm -rf userland
mkdir userland
sudo chmod 777 /home/pi/build-motion-mmal/userland
rm -rf motion
mkdir motion
sudo chmod 777 /home/pi/build-motion-mmal/motion
sudo chmod 777 /etc/motion/motion.conf
sudo chmod 777 /etc/motion.conf
sudo chmod 777 /usr/bin/motion
sudo touch /home/pi/capture/motion.log
sudo chmod 777 /home/pi/capture/motion.log
echo "About to Install dependencies"
sudo apt-get install -y libjpeg62 libjpeg62-dev
sudo apt-get install -y libavformat53 libavformat-dev
sudo apt-get install -y libavcodec53 libavcodec-dev
sudo apt-get install -y libavutil51 libavutil-dev
sudo apt-get install -y libc6-dev
sudo apt-get install -y zlib1g-dev
sudo apt-get install -y libmysqlclient18 libmysqlclient-dev
sudo apt-get install -y libpq5 libpq-dev
sudo apt-get install -y libbz2-dev
sudo apt-get install -y fftw3-dev
sudo apt-get install -y libfftw3-dev
sudo apt-get install -y wget
sudo apt-get install -y git-core
#sudo apt-get install -y git
sudo apt-get install -y build-essential
sudo apt-get install -y cmake
#sudo apt-get install -y gcc
echo "About to clone userland"
echo "About to clone mmal-test branch"
#https://github.com/dozencrows/motion.git
#https://github.com/dozencrows/motion/tree/mmal-test
echo "About to build"
cd /home/pi/build-motion-mmal/motion
USERLANDPATH=/home/pi/build-motion-mmal/userland cmake .
make
echo  "About to install the 'normal' motion so as to use it's daemon startup"
sudo apt-get install -y motion
set +x
echo  ""
echo  "OK you MUST now use nano to edit the normal /etc/motion/motion.conf "
echo  "and find/change one line  from    daemon off   to   daemon on"
echo  ""
echo  "remember, use control X to exit and save your change"
echo  ""
read -p "Press Enter to start nano and make that change ..."
set -x
sudo nano /etc/motion/motion.conf
echo  ""
echo "OK. About to copy the newly built executable to target folder"
ps -ef | grep motion | awk '{print $2}' | xargs kill
sudo cp ./motion /usr/bin/motion
set +x
echo ""
echo "OK.  Now you must do the final steps on your own ... "
echo ""
echo "1. Grab a working motion.conf fron somewhere"
echo "    eg an example one from this thread"
echo "    http://www.raspberrypi.org/forums/viewtopic.php?f=43&t=75240&start=100"
echo "2. Add/change your own settings in it eg set target path to /home/pi/capture"
echo "    be sure to set the daemon to on in this config file too"
echo "3. Copy the new motion.conf to the corrrect place (not the same place a normal motion.conf) eg"
echo "    sudo cp ./motion.conf /etc/motion.conf"
echo "4. Reboot"
echo ""
hydra3333
Mon Dec 15, 2014 4:57 am
... and the promised motion.conf
# Daemon
# Start in daemon (background) mode and release terminal (default: off)
daemon on
# File to store the process ID, also called pid file. (default: not defined)
process_id_file /home/pi/capture/motion.pid
# Basic Setup Mode
# Start in Setup-Mode, daemon disabled. (default: off)
setup_mode off
# Use a file to save logs messages, if not defined stderr and syslog is used. (default: not defined)
logfile /home/pi/capture/motion.log
# Level of log messages [1..9] (EMR, ALR, CRT, ERR, WRN, NTC, INF, DBG, ALL). (default: 6 / NTC)
log_level 6
# Filter to log messages by type (COR, STR, ENC, NET, DBL, EVT, TRK, VID, ALL). (default: ALL)
log_type all
# Capture device options
# Videodevice to be used for capturing  (default /dev/video0)
# for FreeBSD default is /dev/bktr0
#videodevice /dev/video0
# v4l2_palette allows to choose preferable palette to be use by motion
# to capture from those supported by your videodevice. (default: 17)
# E.g. if your videodevice supports both V4L2_PIX_FMT_SBGGR8 and
# V4L2_PIX_FMT_MJPEG then motion will by default use V4L2_PIX_FMT_MJPEG.
# Setting v4l2_palette to 2 forces motion to use V4L2_PIX_FMT_SBGGR8
# instead.
# Values :
# V4L2_PIX_FMT_SN9C10X : 0  'S910'
# V4L2_PIX_FMT_SBGGR16 : 1  'BYR2'
# V4L2_PIX_FMT_SBGGR8  : 2  'BA81'
# V4L2_PIX_FMT_SPCA561 : 3  'S561'
# V4L2_PIX_FMT_SGBRG8  : 4  'GBRG'
# V4L2_PIX_FMT_SGRBG8  : 5  'GRBG'
# V4L2_PIX_FMT_PAC207  : 6  'P207'
# V4L2_PIX_FMT_PJPG    : 7  'PJPG'
# V4L2_PIX_FMT_MJPEG   : 8  'MJPEG'
# V4L2_PIX_FMT_JPEG    : 9  'JPEG'
# V4L2_PIX_FMT_RGB24   : 10 'RGB3'
# V4L2_PIX_FMT_SPCA501 : 11 'S501'
# V4L2_PIX_FMT_SPCA505 : 12 'S505'
# V4L2_PIX_FMT_SPCA508 : 13 'S508'
# V4L2_PIX_FMT_UYVY    : 14 'UYVY'
# V4L2_PIX_FMT_YUYV    : 15 'YUYV'
# V4L2_PIX_FMT_YUV422P : 16 '422P'
# V4L2_PIX_FMT_YUV420  : 17 'YU12'
v4l2_palette 17
# Tuner device to be used for capturing using tuner as source (default /dev/tuner0)
# This is ONLY used for FreeBSD. Leave it commented out for Linux
; tunerdevice /dev/tuner0
# The video input to be used (default: -1)
# Should normally be set to 0 or 1 for video/TV cards, and -1 for USB cameras
input -1
# The video norm to use (only for video capture and TV tuner cards)
# Values: 0 (PAL), 1 (NTSC), 2 (SECAM), 3 (PAL NC no colour). Default: 0 (PAL)
norm 0
# The frequency to set the tuner to (kHz) (only for TV tuner cards) (default: 0)
frequency 0
# Rotate image this number of degrees. The rotation affects all saved images as
# well as movies. Valid values: 0 (default = no rotation), 90, 180 and 270.
rotate 0
# Image width (pixels). Valid range: Camera dependent, default: 352
width 256
# 256*4=1024
#width 320
# 324*4=1280
# Image height (pixels). Valid range: Camera dependent, default: 288
height 144
# 144*4=576
#height 180
# 180*4=720
#width 320
#height 180
# Maximum number of frames to be captured per second.
# Valid range: 2-100. Default: 100 (almost no limit).
framerate 10
# Minimum time in seconds between capturing picture frames from the camera.
# Default: 0 = disabled - the capture rate is given by the camera framerate.
# This option is used when you want to capture images at a rate lower than 2 per second.
minimum_frame_time 0
# URL to use if you are using a network camera, size will be autodetected (incl http:// ftp:// mjpg:// or file:///)
# Must be a URL that returns single jpeg pictures or a raw mjpeg stream. Default: Not defined
;netcam_url http://127.0.0.1/cgi-bin/raspicam.sh
# Username and password for network camera (only if required). Default: not defined
# Syntax is user:password
; netcam_userpass value
# The setting for keep-alive of network socket, should improve performance on compatible net cameras.
# off:   The historical implementation using HTTP/1.0, closing the socket after each http request.
# force: Use HTTP/1.0 requests with keep alive header to reuse the same connection.
# on:    Use HTTP/1.1 requests that support keep alive as default.
# Default: off
netcam_keepalive off
# URL to use for a netcam proxy server, if required, e.g. "http://myproxy".
# If a port number other than 80 is needed, use "http://myproxy:1234".
# Default: not defined
; netcam_proxy value
# Set less strict jpeg checks for network cameras with a poor/buggy firmware.
# Default: off
netcam_tolerant_check off
# Let motion regulate the brightness of a video device (default: off).
# The auto_brightness feature uses the brightness option as its target value.
# If brightness is zero auto_brightness will adjust to average brightness value 128.
# Only recommended for cameras without auto brightness
auto_brightness off
# Set the initial brightness of a video device.
# If auto_brightness is enabled, this value defines the average brightness level
# which Motion will try and adjust to.
# Valid range 0-255, default 0 = disabled
brightness 0
# Set the contrast of a video device.
contrast 0
# Set the saturation of a video device.
saturation 0
# Set the hue of a video device (NTSC feature).
hue 0
# File "camera" support - read raw YUV data from a file
#filecam_path /home/pi/test-cap/motion-mmal.capture
# OpenMax/MMAL camera support for Raspberry Pi
mmalcam_name vc.ril.camera
#mmalcam_control_params
#mmalcam_raw_capture_file /home/pi/motion-mmal.capture
# Switch this setting to "on" to use the still image mode of the Pi's camera
# instead of video. This gives a wider field of view, but requires
# a much slower frame-rate to achieve exposure stability
# (e.g. 0.25 fps or slower). You can use the minimum_frame_time
# parameter above to achieve this
mmalcam_use_still off
# Set this to non-zero value to enable a secondary buffer used for outputting results
# This value is used to multiply the original width & height settings to decide the
# secondary buffer size, so you can use it to capture a high-res image as well as a
# normal (low) resolution one for the primary.
# Use the options output_secondary_pictures, ffmpeg_output_secondary_movies, stream_secondary
# to use this high-res secondary image as the source for picture, movie and web stream output,
# while the actual motion detection is performed on the lower-resolution primary image (and
# thus use less CPU power).
# Pre-encode the secondary buffer to this jpeg quality
# Note that overlaid text or motion location markers will NOT be drawn into a pre-encoded buffer
# as encoding is done on the MMAL side before the image is passed to motion.
# Default: 0 (off), range 1-100
mmalcam_secondary_buffer_jpeg	75
# Round Robin (multiple inputs on same video device name)
# Number of frames to capture in each roundrobin step (default: 1)
roundrobin_frames 1
# Number of frames to skip before each roundrobin step (default: 1)
roundrobin_skip 1
# Try to filter out noise generated by roundrobin (default: off)
switchfilter off
# Motion Detection Settings:
# Threshold for number of changed pixels in an image that
# triggers motion detection (default: 1500)
#threshold 1500
$threshold 1000
threshold 750
#threshold 350
# Automatically tune the threshold down if possible (default: off)
threshold_tune off
# Noise threshold for the motion detection (default: 32)
noise_level 32
# Automatically tune the noise threshold (default: on)
noise_tune on
# Despeckle motion image using (e)rode or (d)ilate or (l)abel (Default: not defined)
# Recommended value is EedDl. Any combination (and number of) of E, e, d, and D is valid.
# (l)abeling must only be used once and the 'l' must be the last letter.
# Comment out to disable
despeckle_filter EedDl
# Detect motion in predefined areas (1 - 9). Areas are numbered like that:  1 2 3
# A script (on_area_detected) is started immediately when motion is         4 5 6
# detected in one of the given areas, but only once during an event.        7 8 9
# One or more areas can be specified with this option. Take care: This option
# does NOT restrict detection to these areas! (Default: not defined)
; area_detect value
# PGM file to use as a sensitivity mask.
# Full path name to. (Default: not defined)
; mask_file value
# Dynamically create a mask file during operation (default: 0)
# Adjust speed of mask changes from 0 (off) to 10 (fast)
smart_mask_speed 0
# Ignore sudden massive light intensity changes given as a percentage of the picture
# area that changed intensity. Valid range: 0 - 100 , default: 0 = disabled
lightswitch 0
# Picture frames must contain motion at least the specified number of frames
# in a row before they are detected as true motion. At the default of 1, all
# motion is detected. Valid range: 1 to thousands, recommended 1-5
minimum_motion_frames 1
# Specifies the number of pre-captured (buffered) pictures from before motion
# was detected that will be output at motion detection.
# Recommended range: 0 to 5 (default: 0)
# Do not use large values! Large values will cause Motion to skip video frames and
# cause unsmooth movies. To smooth movies use larger values of post_capture instead.
#pre_capture 0
pre_capture 5
# Number of frames to capture after motion is no longer detected (default: 0)
#post_capture 0
post_capture 10
# Event Gap is the seconds of no motion detection that triggers the end of an event.
# An event is defined as a series of motion images taken within a short timeframe.
# Recommended value is 60 seconds (Default). The value -1 is allowed and disables
# events causing all Motion to be written to one single movie file and no pre_capture.
# If set to 0, motion is running in gapless mode. Movies don't have gaps anymore. An
# event ends right after no more motion is detected and post_capture is over.
event_gap 60
# Maximum length in seconds of a movie
# When value is exceeded a new movie file is created. (Default: 0 = infinite)
max_movie_time 0
# Always save images even if there was no motion (default: off)
emulate_motion off
# Image File Output
# Output 'normal' pictures when motion is detected (default: on)
# Valid values: on, off, first, best, center
# When set to 'first', only the first picture of an event is saved.
# Picture with most motion of an event is saved when set to 'best'.
# Picture with motion nearest center of picture is saved when set to 'center'.
# Can be used as preview shot for the corresponding movie.
output_pictures on
#output_pictures off
# Output pictures with only the pixels moving object (ghost images) (default: off)
output_debug_pictures off
# Output pictures from secondary capture (see mmalcam_secondary_buffer_upscale above)
# Use this to perform motion detection on a low-res image and record a high-res output
# The quality (in percent) to be used by the jpeg compression (default: 75)
#quality 50
quality 75
# Type of output images
# Valid values: jpeg, ppm (default: jpeg)
picture_type jpeg
# FFMPEG related options
# Film (movies) file output, and deinterlacing of the video input
# The options movie_filename and timelapse_filename are also used
# by the ffmpeg feature
# Use ffmpeg to encode movies in realtime (default: off)
# Use ffmpeg to make movies with only the pixels moving
# object (ghost images) (default: off)
# Use ffmpeg to make movies using any enabled secondary buffer (default: off)
#ffmpeg_output_secondary_movies on
# Use ffmpeg to encode a timelapse movie
# Default value 0 = off - else save frame every Nth second
ffmpeg_timelapse 0
# The file rollover mode of the timelapse video
# Valid values: hourly, daily (default), weekly-sunday, weekly-monday, monthly, manual
# Bitrate to be used by the ffmpeg encoder (default: 400000)
# This option is ignored if ffmpeg_variable_bitrate is not 0 (disabled)
ffmpeg_bps 500000
# Enables and defines variable bitrate for the ffmpeg encoder.
# ffmpeg_bps is ignored if variable bitrate is enabled.
# Valid values: 0 (default) = fixed bitrate defined by ffmpeg_bps,
# or the range 2 - 31 where 2 means best quality and 31 is worst.
# Codec to used by ffmpeg for the video compression.
# Timelapse mpegs are always made in mpeg1 format independent from this option.
# Supported formats are: mpeg1 (ffmpeg-0.4.8 only), mpeg4 (default), and msmpeg4.
# mpeg1 - gives you files with extension .mpg
# mpeg4 or msmpeg4 - gives you files with extension .avi
# msmpeg4 is recommended for use with Windows Media Player because
# it requires no installation of codec on the Windows client.
# swf - gives you a flash film with extension .swf
# flv - gives you a flash video with extension .flv
# ffv1 - FF video codec 1 for Lossless Encoding ( experimental )
# mov - QuickTime ( testing )
# ogg - Ogg/Theora ( testing )
#ffmpeg_video_codec mpeg4
# Use ffmpeg to deinterlace video. Necessary if you use an analog camera
# and see horizontal combing on moving objects in video or pictures.
# (default: off)
# SDL Window
# Number of motion thread to show in SDL Window (default: 0 = disabled)
#sdl_threadnr 0
# External pipe to video encoder
# Replacement for FFMPEG builtin encoder for ffmpeg_output_movies only.
# Bool to enable or disable extpipe (default: off)
use_extpipe off
#extpipe_secondary on
# External program (full path and opts) to pipe raw video to
# Generally, use '-' for STDIN...
;extpipe mencoder -demuxer rawvideo -rawvideo w=320:h=240:i420 -ovc x264 -x264encopts bframes=4:frameref=1:subq=1:scenecut=-1:nob_adapt:threads=1:keyint=1000:8x8dct:vbv_bufsize=4000:crf=24:partitions=i8x8,i4x4:vbv_maxrate=800:no-chroma-me -vf denoise3d=16:12:48:4,pp=lb -of   avi -o %f.avi - -fps %fps
#extpipe mencoder -demuxer rawvideo -rawvideo w=1024:h=576 -ovc raw -of avi -o %f.avi - -fps 15 -noskip
# Snapshots (Traditional Periodic Webcam File Output)
# Make automated snapshot every N seconds (default: 0 = disabled)
snapshot_interval 0
# Text Display
# %Y = year, %m = month, %d = date,
# %H = hour, %M = minute, %S = second, %T = HH:MM:SS,
# %v = event, %q = frame number, %t = thread (camera) number,
# %D = changed pixels, %N = noise level, \n = new line,
# %i and %J = width and height of motion area,
# %K and %L = X and Y coordinates of motion center
# %C = value defined by text_event - do not use with text_event!
# You can put quotation marks around the text to allow
# leading spaces
# Locate and draw a box around the moving object.
# Valid values: on, off, preview (default: off)
# Set to 'preview' will only draw a box in preview_shot pictures.
# Set the look and style of the locate box if enabled.
# Valid values: box, redbox, cross, redcross (default: box)
# Set to 'box' will draw the traditional box.
# Set to 'redbox' will draw a red box.
# Set to 'cross' will draw a little cross to mark center.
# Set to 'redcross' will draw a little red cross to mark center.
# Draws the timestamp using same options as C function strftime(3)
# Default: %Y-%m-%d\n%T = date in ISO format and time in 24 hour clock
# Text is placed in lower right corner
text_right %Y-%m-%d\n%T-%q
# Draw a user defined text on the images using same options as C function strftime(3)
# Default: Not defined = no text
# Text is placed in lower left corner
;text_left CAMERA %t
# Draw the number of changed pixed on the images (default: off)
# Will normally be set to off except when you setup and adjust the motion settings
# Text is placed in upper right corner
text_changes off
# This option defines the value of the special event conversion specifier %C
# You can use any conversion specifier in this option except %C. Date and time
# values are from the timestamp of the first image in the current event.
# Default: %Y%m%d%H%M%S
# The idea is that %C can be used filenames and text_left/right for creating
# a unique identifier for each event.
text_event %Y%m%d%H%M%S
# Draw characters at twice normal size on images. (default: off)
#text_double on
text_double off
# Text to include in a JPEG EXIF comment
# May be any text, including conversion specifiers.
# The EXIF timestamp is included independent of this text.
;exif_text %i%J/%K%L
# Target Directories and filenames For Images And Films
# For the options snapshot_, picture_, movie_ and timelapse_filename
# you can use conversion specifiers
# Quotation marks round string are allowed.
# Target base directory for pictures and films
# Recommended to use absolute path. (Default: current working directory)
# File path for snapshots (jpeg or ppm) relative to target_dir
# Default: %v-%Y%m%d%H%M%S-snapshot
# Default value is equivalent to legacy oldlayout option
# For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-snapshot
# File extension .jpg or .ppm is automatically added so do not include this.
# Note: A symbolic link called lastsnap.jpg created in the target_dir will always
# point to the latest snapshot, unless snapshot_filename is exactly 'lastsnap'
snapshot_filename %v-%Y%m%d%H%M%S-snapshot
# File path for motion triggered images (jpeg or ppm) relative to target_dir
# Default: %v-%Y%m%d%H%M%S-%q
# For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-%q
# Set to 'preview' together with best-preview feature enables special naming
# convention for preview shots. See motion guide for details
picture_filename %v-%Y%m%d%H%M%S-%q
# File path for motion triggered ffmpeg films (movies) relative to target_dir
# For Motion 3.0 compatible mode choose: %Y/%m/%d/%H%M%S
# File extension .mpg or .avi is automatically added so do not include this
# This option was previously called ffmpeg_filename
movie_filename %v-%Y%m%d%H%M%S
# File path for timelapse movies relative to target_dir
# Default: %Y%m%d-timelapse
# Default value is near equivalent to legacy oldlayout option
# For Motion 3.0 compatible mode choose: %Y/%m/%d-timelapse
# File extension .mpg is automatically added so do not include this
timelapse_filename %Y%m%d-timelapse
# Global Network Options
# Enable or disable IPV6 for http control and stream (default: off )
ipv6_enabled off
# Live Stream Server
# The mini-http server listens to this port for requests (default: 0 = disabled)
stream_port 8081
# Quality of the jpeg (in percent) images produced (default: 50)
stream_quality 50
# Output frames at 1 fps when no motion is detected and increase to the
# rate given by stream_maxrate when motion is detected (default: off)
stream_motion off
# Use secondary buffer as stream image source (default: off)
#stream_secondary on
# Maximum framerate for stream streams (default: 1)
stream_maxrate 10
# Restrict stream connections to localhost only (default: on)
# Limits the number of images per connection (default: 0 = unlimited)
# Number can be defined by multiplying actual stream rate by desired number of seconds
# Actual stream rate is the smallest of the numbers framerate and stream_maxrate
stream_limit 0
# Set the authentication method (default: 0)
# 0 = disabled
# 1 = Basic authentication
# 2 = MD5 digest (the safer authentication)
# Authentication for the stream. Syntax username:password
# Default: not defined (Disabled)
; stream_authentication username:password
# HTTP Based Control
# TCP/IP port for the http server to listen on (default: 0 = disabled)
webcontrol_port 8080
# Restrict control connections to localhost only (default: on)
# Output for http server, select off to choose raw text plain (default: on)
webcontrol_html_output on
# Authentication for the http based control. Syntax username:password
; webcontrol_authentication username:password
# Tracking (Pan/Tilt)
# Type of tracker (0=none (default), 1=stepper, 2=iomojo, 3=pwc, 4=generic, 5=uvcvideo, 6=servo)
# The generic type enables the definition of motion center and motion size to
# be used with the conversion specifiers for options like on_motion_detected
track_type 0
# Enable auto tracking (default: off)
track_auto off
# Serial port of motor (default: none)
;track_port /dev/ttyS0
# Motor number for x-axis (default: 0)
;track_motorx 0
# Set motorx reverse (default: 0)
;track_motorx_reverse 0
# Motor number for y-axis (default: 0)
;track_motory 1
# Set motory reverse (default: 0)
;track_motory_reverse 0
# Maximum value on x-axis (default: 0)
;track_maxx 200
# Minimum value on x-axis (default: 0)
;track_minx 50
# Maximum value on y-axis (default: 0)
;track_maxy 200
# Minimum value on y-axis (default: 0)
;track_miny 50
# Center value on x-axis (default: 0)
;track_homex 128
# Center value on y-axis (default: 0)
;track_homey 128
# ID of an iomojo camera if used (default: 0)
track_iomojo_id 0
# Angle in degrees the camera moves per step on the X-axis
# with auto-track (default: 10)
# Currently only used with pwc type cameras
track_step_angle_x 10
# Angle in degrees the camera moves per step on the Y-axis
track_step_angle_y 10
# Delay to wait for after tracking movement as number
# of picture frames (default: 10)
track_move_wait 10
# Speed to set the motor to (stepper motor option) (default: 255)
track_speed 255
# Number of steps to make (stepper motor option) (default: 40)
track_stepsize 40
# External Commands, Warnings and Logging:
# You can use conversion specifiers for the on_xxxx commands
# %f = filename with full path
# %n = number indicating filetype
# Both %f and %n are only defined for on_picture_save,
# on_movie_start and on_movie_end
# Do not sound beeps when detecting motion (default: on)
# Note: Motion never beeps when running in daemon mode.
quiet on
# Command to be executed when an event starts. (default: none)
# An event starts at first motion detected after a period of no motion defined by event_gap
; on_event_start value
# Command to be executed when an event ends after a period of no motion
# (default: none). The period of no motion is defined by option event_gap.
; on_event_end value
# Command to be executed when a picture (.ppm|.jpg) is saved (default: none)
# To give the filename as an argument to a command append it with %f
; on_picture_save value
# Command to be executed when a motion frame is detected (default: none)
; on_motion_detected value
# Command to be executed when motion in a predefined area is detected
# Check option 'area_detect'.   (default: none)
; on_area_detected value
# Command to be executed when a movie file (.mpg|.avi) is created. (default: none)
; on_movie_start value
# Command to be executed when a movie file (.mpg|.avi) is closed. (default: none)
; on_movie_end value
# Command to be executed when a camera can't be opened or if it is lost
# NOTE: There is situations when motion don't detect a lost camera!
# It depends on the driver, some drivers dosn't detect a lost camera at all
# Some hangs the motion thread. Some even hangs the PC! (default: none)
; on_camera_lost value
# Common Options for database features.
# Options require database options to be active also.
# Log to the database when creating motion triggered picture file  (default: on)
; sql_log_picture on
# Log to the database when creating a snapshot image file (default: on)
; sql_log_snapshot on
# Log to the database when creating motion triggered movie file (default: off)
; sql_log_movie off
# Log to the database when creating timelapse movies file (default: off)
; sql_log_timelapse off
# SQL query string that is sent to the database
# Use same conversion specifiers has for text features
# Additional special conversion specifiers are
# %n = the number representing the file_type
# Default value:
# Create tables :
# Mysql
# CREATE TABLE security (camera int, filename char(80) not null, frame int, file_type int, time_stamp timestamp(14), event_time_stamp timestamp(14));
# Postgresql
# CREATE TABLE security (camera int, filename char(80) not null, frame int, file_type int, time_stamp timestamp without time zone, event_time_stamp timestamp without time zone);
# insert into security(camera, filename, frame, file_type, time_stamp, text_event) values('%t', '%f', '%q', '%n', '%Y-%m-%d %T', '%C')
; sql_query insert into security(camera, filename, frame, file_type, time_stamp, event_time_stamp) values('%t', '%f', '%q', '%n', '%Y-%m-%d %T', '%C')
# Database Options
# database type : mysql, postgresql, sqlite3 (default : not defined)
; database_type value
# database to log to (default: not defined)
; database_dbname value
# The host on which the database is located (default: localhost)
; database_host value
# User account name for database (default: not defined)
; database_user value
# User password for database (default: not defined)
; database_password value
# Port on which the database is located
#  mysql 3306 , postgresql 5432 (default: not defined)
; database_port value
# Database Options For SQLite3
# SQLite3 database (file path) (default: not defined)
; sqlite3_db value
# Video Loopback Device (vloopback project)
# Output images to a video4linux loopback device
# The value '-' means next available (default: not defined)
; video_pipe value
# Output motion images to a video4linux loopback device
; motion_video_pipe value
# Thread config files - One for each camera.
# Except if only one camera - You only need this config file.
# If you have more than one camera you MUST define one thread
# config file for each camera in addition to this config file.
# Remember: If you have more than one camera you must have one
# thread file for each camera. E.g. 2 cameras requires 3 files:
# This motion.conf file AND thread1.conf and thread2.conf.
# Only put the options that are unique to each camera in the
# thread config files.
; thread /usr/local/etc/thread1.conf
; thread /usr/local/etc/thread2.conf
; thread /usr/local/etc/thread3.conf
; thread /usr/local/etc/thread4.conf
The reason I use .JPG output instead of movie output is that "using the secondary buffer" prevents capture timestamps being imprinted on both video or JPG - hence I
1. capture to jpg and rely on the filenames for the timestamps
2. copy the jpgs to a Windows PC
3. run a batch script to imprint the timestamps and turn them into a .mp4 movie (using ffmpeg)
Return to “Camera board”
