dqpi
ffmpeg split video
Tue Apr 01, 2014 4:35 pm
I want to split a 50 seconds video from the camera and save second 10 till 40. I use the following ffmpeg command:
ffmpeg -i test1.h264 -acodec copy -vcodec copy -ss 00:00:10 -t 00:00:30 splittedvid.mp4
I get more than 2 seconds of black frames in the beginning, which is weird. When I use -ss 00:00:00 everything works just fine.
Any ideas?
Re: ffmpeg split video
Tue Apr 01, 2014 4:45 pm
I'm guessing, but it may be the time from the point you specified to the first I-frame (the first complete frame). You generally cannot just start anywhere when splitting. (unless the code back tracks to the last I-frame, then scans forward to the start point).
You can increase the number of I-frames inserted using raspivid -g I think, but check the docs. So the more you have, the less delay before the next one.
dqpi
Tue Apr 01, 2014 4:54 pm
Thank you for that!
For reference of others with the same question, here the part from the documentation:
--intra, -g Specify the intra refresh period (key frame rate/GoP)
Sets the intra refresh period (GoP) rate for the recorded video. H264 video uses a complete frame (I-frame) every intra refresh period from which subsequent frames are based. This options specifies the numbers of frames between each I-frame. Larger numbers here will reduce the size of the resulting video, smaller numbers make the stream more robust to error.
Tue Apr 01, 2014 8:14 pm
Was that actually the problem?
dqpi
Sat Apr 05, 2014 5:16 pm
yes:)
Return to “Camera board”
