355/113
Is new pi-cam compatible with PiTFT?
Thu Mar 20, 2014 5:07 pm
I tried "sudo rpi-update" and after it ran, my system was left in a broken state of mind. I have the Adafruit PiTFT 320x240 LCD with touch screen installed and it no longer functioned.
After I re-ran the PiTFT install tutorial, everything ran again but the PiCam is still the 'old' PiCam - no new fancy hi-res stuff.
Is the new camera firmware mod not compatible with the kernel changes that Adafruit uses for the PiTFT?
Thanks for any tips!
6by9
Re: Is new pi-cam compatible with PiTFT?
Thu Mar 20, 2014 5:36 pm
Almost all of the new camera changes are on the GPU side with just a very minor one in the V4L2 driver (if you use that).
rpi-update will also update the kernel though, and Dom does a fairly good job of pulling in the updates from upstream and linux.git.
Seeing as PiTFT is adding a kernel module, I'd guess that something in there has changed in the kernel to make the module incompatible.
Adafruit have released the source to their module at http://adafruit-download.s3.amazonaws.c ... uit-ts.zip so that you can build your own kernel with their changes - http://elinux.org/RPi_Kernel_Compilation for instructions on building kernels (it will take quite a while if you try and do it on a Pi, but you can cross-compile on most Linux PCs).
Return to “Camera board”
