CopterRichie
Omxplayer & raspivid
Wed Feb 12, 2014 2:32 pm
Please help me out here, I am having a very hard time understanding why I am not able to play a stream from Raspberry Pi#1 using raspivid and Raspberry Pi#2 using omxplayer.
On Raspberry #1
raspivid -t 0 -w 640 -h 480 -o - | nc 192.168.1.10 5001
Raspberry #2
I have tried all of the variances listed there: http://elinux.org/Omxplayer including
nc -l -k 5001 | omxplayer -
nc -l -k 5001 | omxplayer /dev/stdin
Thank you.
ethanol100
Re: Omxplayer & raspivid
Wed Feb 12, 2014 4:00 pm
You can try a fifo? Similar to:
To view the feed on a Raspberry Pi:
Find your IP address by running ifconfig. (Your IP address will be listed in the console output and will probably be of the form 192.168.1.XXX).
Run the following commands in a terminal on the receiving Pi:
mkfifo buffer
nc -p 5001 -l > buffer | /opt/vc/src/hello_pi/hello_video/hello_video.bin buffer
from http://www.raspberrypi.org/camera
And you need first to start the listening command on the receiver, before you can pipe the video from the sender.
CopterRichie
Wed Feb 12, 2014 4:04 pm
Thank you.
Marcos.Scholl
Wed Feb 12, 2014 9:13 pm
CopterRichie wrote:Thank you.
Friend, managed to stream Pi for Pi with a good resolution and the video not slow and crashing?
I'm trying this, was using Mplayer , but is extremely slow . I would be grateful if you could help me , since it seems to be doing the same thing!
Which codes of Transmitter and receiver you used for its proper functioning ?
Thank you.
CopterRichie
Wed Feb 12, 2014 9:20 pm
Marcos.Scholl wrote:Friend, managed to stream Pi for Pi with a good resolution and the video not slow and crashing?
Thank you.
use this, it works!
mkfifo buffer
Return to “Camera board”
