reggie4
Motion.conf file for low light
Sat Feb 01, 2014 8:33 pm
Hi all,
I have a NoIR camera board and am using it to 1) store video files and 2) provide a live feed to the web.
It works well during the day, but at night the pictures are way too dark. Interestingly the live feed is brighter than the video files, which is strange and somewhat disappointing.
I need good low level light performance and am prepared to manually change the motion .conf file each morning and evening, if i have to, to tune for day and then for night.
I don't have an IR light source, and don't want to use one
Please could someone have a look at what im doing wrong, because i cannot get it to lighten up at all!
# Daemon
# Start in daemon (background) mode and release terminal (default: off)
daemon on
# File to store the process ID, also called pid file. (default: not defined)
process_id_file /var/run/motion/motion.pid
# Basic Setup Mode
# Start in Setup-Mode, daemon disabled. (default: off)
setup_mode off
# Use a file to save logs messages, if not defined stderr and syslog is used. (default: not defined)
#logfile /home/pi/motion.log
logfile /tmp/motion.log
# Level of log messages [1..9] (EMR, ALR, CRT, ERR, WRN, NTC, INF, DBG, ALL). (default: 6 / NTC)
#log_level 5
log_level 2
# Filter to log messages by type (COR, STR, ENC, NET, DBL, EVT, TRK, VID, ALL). (default: ALL)
log_type all
# Capture device options
# Videodevice to be used for capturing  (default /dev/video0)
# for FreeBSD default is /dev/bktr0
#videodevice /dev/video0
# v4l2_palette allows to choose preferable palette to be use by motion
# to capture from those supported by your videodevice. (default: 17)
# E.g. if your videodevice supports both V4L2_PIX_FMT_SBGGR8 and
# V4L2_PIX_FMT_MJPEG then motion will by default use V4L2_PIX_FMT_MJPEG.
# Setting v4l2_palette to 2 forces motion to use V4L2_PIX_FMT_SBGGR8
# instead.
# Values :
# V4L2_PIX_FMT_SN9C10X : 0  'S910'
# V4L2_PIX_FMT_SBGGR16 : 1  'BYR2'
# V4L2_PIX_FMT_SBGGR8  : 2  'BA81'
# V4L2_PIX_FMT_SPCA561 : 3  'S561'
# V4L2_PIX_FMT_SGBRG8  : 4  'GBRG'
# V4L2_PIX_FMT_SGRBG8  : 5  'GRBG'
# V4L2_PIX_FMT_PAC207  : 6  'P207'
# V4L2_PIX_FMT_PJPG    : 7  'PJPG'
# V4L2_PIX_FMT_MJPEG   : 8  'MJPEG'
# V4L2_PIX_FMT_JPEG    : 9  'JPEG'
# V4L2_PIX_FMT_RGB24   : 10 'RGB3'
# V4L2_PIX_FMT_SPCA501 : 11 'S501'
# V4L2_PIX_FMT_SPCA505 : 12 'S505'
# V4L2_PIX_FMT_SPCA508 : 13 'S508'
# V4L2_PIX_FMT_UYVY    : 14 'UYVY'
# V4L2_PIX_FMT_YUYV    : 15 'YUYV'
# V4L2_PIX_FMT_YUV422P : 16 '422P'
# V4L2_PIX_FMT_YUV420  : 17 'YU12'
#v4l2_palette 17
v412_palette 7
# Tuner device to be used for capturing using tuner as source (default /dev/tuner0)
# This is ONLY used for FreeBSD. Leave it commented out for Linux
; tunerdevice /dev/tuner0
# The video input to be used (default: -1)
# Should normally be set to 0 or 1 for video/TV cards, and -1 for USB cameras
input -1
# The video norm to use (only for video capture and TV tuner cards)
# Values: 0 (PAL), 1 (NTSC), 2 (SECAM), 3 (PAL NC no colour). Default: 0 (PAL)
norm 0
# The frequency to set the tuner to (kHz) (only for TV tuner cards) (default: 0)
frequency 0
# Rotate image this number of degrees. The rotation affects all saved images as
# well as movies. Valid values: 0 (default = no rotation), 90, 180 and 270.
rotate 0
# Image width (pixels). Valid range: Camera dependent, default: 352
#width 1024
width 1280
#width 1920
# Image height (pixels). Valid range: Camera dependent, default: 288
#height 576
height 720
#height 1080
# Maximum number of frames to be captured per second.
# Valid range: 2-100. Default: 100 (almost no limit).
framerate 2
# Minimum time in seconds between capturing picture frames from the camera.
# Default: 0 = disabled - the capture rate is given by the camera framerate.
# This option is used when you want to capture images at a rate lower than 2 per second.
minimum_frame_time 0
# URL to use if you are using a network camera, size will be autodetected (incl http:// ftp://$
# Must be a URL that returns single jpeg pictures or a raw mjpeg stream. Default: Not defined
;netcam_url
# Username and password for network camera (only if required). Default: not defined
# Syntax is user:password
####################################################################################; netcam_u$
; netcam_userpass value xxxxxx:xxxxxx
# The setting for keep-alive of network socket, should improve performance on compatible net c$
# off:   The historical implementation using HTTP/1.0, closing the socket after each http requ$
# force: Use HTTP/1.0 requests with keep alive header to reuse the same connection.
# on:    Use HTTP/1.1 requests that support keep alive as default.
# Default: off
#netcam_keepalive off#########################################################################$
netcam keepalive on
# URL to use for a netcam proxy server, if required, e.g. "http://myproxy".
# If a port number other than 80 is needed, use "http://myproxy:1234".
# Default: not defined
; netcam_proxy value
;netcam_url
; netcam_userpass value xxxx:xxxxxxx
# Default: off
netcam keepalive on
# Set less strict jpeg checks for network cameras with a poor/buggy firmware.
# Default: off
netcam_tolerant_check off
# Let motion regulate the brightness of a video device (default: off).
# The auto_brightness feature uses the brightness option as its target value.
# If brightness is zero auto_brightness will adjust to average brightness value 128.
# Only recommended for cameras without auto brightness
auto_brightness on
# Set the initial brightness of a video device.
# If auto_brightness is enabled, this value defines the average brightness level
# which Motion will try and adjust to.
# Valid range 0-255, default 0 = disabled
brightness 50
# Set the contrast of a video device.
contrast 25
# Set the saturation of a video device.
saturation 5
# Set the hue of a video device (NTSC feature).
hue 0
# File "camera" support - read raw YUV data from a file
#filecam_path /home/pi/test-cap/motion-mmal.capture
# OpenMax/MMAL camera support for Raspberry Pi
mmalcam_name vc.ril.camera
#mmalcam_control_params
#mmalcam_raw_capture_file /home/pi/motion-mmal.capture
# Switch this setting to "on" to use the still image mode of the Pi's camera
# instead of video. This gives a wider field of view, but requires
# a much slower frame-rate to achieve exposure stability
# (e.g. 0.25 fps or slower). You can use the minimum_frame_time
# parameter above to achieve this
mmalcam_use_still off
# Round Robin (multiple inputs on same video device name)
# Number of frames to capture in each roundrobin step (default: 1)
roundrobin_frames 1
# Number of frames to skip before each roundrobin step (default: 1)
roundrobin_skip 1
# Try to filter out noise generated by roundrobin (default: off)
switchfilter off
# Motion Detection Settings:
# Threshold for number of changed pixels in an image that
# triggers motion detection (default: 1500)
threshold 1500
# Automatically tune the threshold down if possible (default: off)
threshold_tune off
# Noise threshold for the motion detection (default: 32)
noise_level 32
# Automatically tune the noise threshold (default: on)
noise_tune on
# Despeckle motion image using (e)rode or (d)ilate or (l)abel (Default: not defined)
# Recommended value is EedDl. Any combination (and number of) of E, e, d, and D is valid.
# (l)abeling must only be used once and the 'l' must be the last letter.
# Comment out to disable
despeckle_filter EedDl
# Detect motion in predefined areas (1 - 9). Areas are numbered like that:  1 2 3
# A script (on_area_detected) is started immediately when motion is         4 5 6
# detected in one of the given areas, but only once during an event.        7 8 9
# One or more areas can be specified with this option. Take care: This option
# does NOT restrict detection to these areas! (Default: not defined)
; area_detect value
# PGM file to use as a sensitivity mask.
# Full path name to. (Default: not defined)
; mask_file value
# Dynamically create a mask file during operation (default: 0)
# Adjust speed of mask changes from 0 (off) to 10 (fast)
smart_mask_speed 0
# Ignore sudden massive light intensity changes given as a percentage of the picture
# area that changed intensity. Valid range: 0 - 100 , default: 0 = disabled
lightswitch 0
# Picture frames must contain motion at least the specified number of frames
# in a row before they are detected as true motion. At the default of 1, all
# motion is detected. Valid range: 1 to thousands, recommended 1-5
minimum_motion_frames 1
# Specifies the number of pre-captured (buffered) pictures from before motion
# was detected that will be output at motion detection.
# Recommended range: 0 to 5 (default: 0)
# Do not use large values! Large values will cause Motion to skip video frames and
# cause unsmooth movies. To smooth movies use larger values of post_capture instead.
pre_capture 10
# Number of frames to capture after motion is no longer detected (default: 0)
post_capture 10
# Event Gap is the seconds of no motion detection that triggers the end of an event.
# An event is defined as a series of motion images taken within a short timeframe.
# Recommended value is 60 seconds (Default). The value -1 is allowed and disables
# events causing all Motion to be written to one single movie file and no pre_capture.
# If set to 0, motion is running in gapless mode. Movies don't have gaps anymore. An
# event ends right after no more motion is detected and post_capture is over.
event_gap 60
# Maximum length in seconds of a movie
# When value is exceeded a new movie file is created. (Default: 0 = infinite)
#max_movie_time 0
max_mpeg_time 240
# Always save images even if there was no motion (default: off)
emulate_motion off
# Image File Output
# Output 'normal' pictures when motion is detected (default: on)
# Valid values: on, off, first, best, center
# When set to 'first', only the first picture of an event is saved.
# Picture with most motion of an event is saved when set to 'best'.
# Picture with motion nearest center of picture is saved when set to 'center'.
# Can be used as preview shot for the corresponding movie.
#output_pictures on
output_pictures best
# Output pictures with only the pixels moving object (ghost images) (default: off)
output_debug_pictures off
# The quality (in percent) to be used by the jpeg compression (default: 75)
quality 100
# Type of output images
# Valid values: jpeg, ppm (default: jpeg)
picture_type jpeg
# FFMPEG related options
# Film (movies) file output, and deinterlacing of the video input
# The options movie_filename and timelapse_filename are also used
# by the ffmpeg feature
# Use ffmpeg to encode movies in realtime (default: off)
ffmpeg_output_movies on
# Use ffmpeg to make movies with only the pixels moving
# object (ghost images) (default: off)
ffmpeg_output_debug_movies off
# Use ffmpeg to encode a timelapse movie
# Default value 0 = off - else save frame every Nth second
ffmpeg_timelapse 0
# The file rollover mode of the timelapse video
# Valid values: hourly, daily (default), weekly-sunday, weekly-monday, monthly, manual
ffmpeg_timelapse_mode daily
# Bitrate to be used by the ffmpeg encoder (default: 400000)
# This option is ignored if ffmpeg_variable_bitrate is not 0 (disabled)
ffmpeg_bps 500000
# Enables and defines variable bitrate for the ffmpeg encoder.
# ffmpeg_bps is ignored if variable bitrate is enabled.
# Valid values: 0 (default) = fixed bitrate defined by ffmpeg_bps,
# or the range 2 - 31 where 2 means best quality and 31 is worst.
ffmpeg_variable_bitrate 5
# Codec to used by ffmpeg for the video compression.
# Timelapse mpegs are always made in mpeg1 format independent from this option.
# Supported formats are: mpeg1 (ffmpeg-0.4.8 only), mpeg4 (default), and msmpeg4.
# mpeg1 - gives you files with extension .mpg
# mpeg4 or msmpeg4 - gives you files with extension .avi
# msmpeg4 is recommended for use with Windows Media Player because
# it requires no installation of codec on the Windows client.
# swf - gives you a flash film with extension .swf
# flv - gives you a flash video with extension .flv
# ffv1 - FF video codec 1 for Lossless Encoding ( experimental )
# mov - QuickTime ( testing )
# ogg - Ogg/Theora ( testing )
ffmpeg_video_codec msmpeg4
# Use ffmpeg to deinterlace video. Necessary if you use an analog camera
# and see horizontal combing on moving objects in video or pictures.
# (default: off)
ffmpeg_deinterlace off
# SDL Window
# Number of motion thread to show in SDL Window (default: 0 = disabled)
#sdl_threadnr 0
# External pipe to video encoder
# Replacement for FFMPEG builtin encoder for ffmpeg_output_movies only.
# Bool to enable or disable extpipe (default: off)
use_extpipe off
# External program (full path and opts) to pipe raw video to
# Generally, use '-' for STDIN...
;extpipe mencoder -demuxer rawvideo -rawvideo w=320:h=240:i420 -ovc x264 -x264encopts bframes=$
# Snapshots (Traditional Periodic Webcam File Output)
# Make automated snapshot every N seconds (default: 0 = disabled)
snapshot_interval 0
# Text Display
# %Y = year, %m = month, %d = date,
# %H = hour, %M = minute, %S = second, %T = HH:MM:SS,
# %v = event, %q = frame number, %t = thread (camera) number,
# %D = changed pixels, %N = noise level, \n = new line,
# %i and %J = width and height of motion area,
# %K and %L = X and Y coordinates of motion center
# %C = value defined by text_event - do not use with text_event!
# You can put quotation marks around the text to allow
# leading spaces
# Locate and draw a box around the moving object.
# Valid values: on, off, preview (default: off)
# Set to 'preview' will only draw a box in preview_shot pictures.
locate_motion_mode off
# Set the look and style of the locate box if enabled.
# Valid values: box, redbox, cross, redcross (default: box)
# Set to 'box' will draw the traditional box.
# Set to 'redbox' will draw a red box.
# Set to 'cross' will draw a little cross to mark center.
locate_motion_style box
# Draws the timestamp using same options as C function strftime(3)
# Default: %Y-%m-%d\n%T = date in ISO format and time in 24 hour clock
# Text is placed in lower right corner
text_right %Y-%m-%d\n%T-%q
# Draw a user defined text on the images using same options as C function strftime(3)
# Default: Not defined = no text
# Text is placed in lower left corner
; text_left CAMERA %t
text_left car cam
# Draw the number of changed pixed on the images (default: off)
# Will normally be set to off except when you setup and adjust the motion settings
# Text is placed in upper right corner
text_changes off
# This option defines the value of the special event conversion specifier %C
# You can use any conversion specifier in this option except %C. Date and time
# values are from the timestamp of the first image in the current event.
# Default: %Y%m%d%H%M%S
# The idea is that %C can be used filenames and text_left/right for creating
# a unique identifier for each event.
text_event %Y%m%d%H%M%S
# Draw characters at twice normal size on images. (default: off)
text_double on
# Text to include in a JPEG EXIF comment
# May be any text, including conversion specifiers.
# The EXIF timestamp is included independent of this text.
;exif_text %i%J/%K%L
# Target Directories and filenames For Images And Films
# For the options snapshot_, picture_, movie_ and timelapse_filename
# you can use conversion specifiers
# Quotation marks round string are allowed.
# Target base directory for pictures and films
# Recommended to use absolute path. (Default: current working directory)
#target_dir /home/pi
target_dir /mnt
# File path for snapshots (jpeg or ppm) relative to target_dir
# Default: %v-%Y:%m:%d:-%H%M%S-snapshot
# Default value is equivalent to legacy oldlayout option
# For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-snapshot
# File extension .jpg or .ppm is automatically added so do not include this.
# Note: A symbolic link called lastsnap.jpg created in the target_dir will always
# point to the latest snapshot, unless snapshot_filename is exactly 'lastsnap'
snapshot_filename %v-%Y%m%d%H%M%S-snapshot
# File path for motion triggered images (jpeg or ppm) relative to target_dir
# Default: %v-%Y%m%d%H%M%S-%q
# For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-%q
# Set to 'preview' together with best-preview feature enables special naming
# convention for preview shots. See motion guide for details
picture_filename %Y-%m-%d---%H-%M-%S
# File path for motion triggered ffmpeg films (movies) relative to target_dir
# For Motion 3.0 compatible mode choose: %Y/%m/%d/%H%M%S
# File extension .mpg or .avi is automatically added so do not include this
# This option was previously called ffmpeg_filename
#movie_filename %v-%Y%m%d%H%M%S
movie_filename %Y-%m-%d---%H-%M-%S
# File path for timelapse movies relative to target_dir
# Default: %Y%m%d-timelapse
# Default value is near equivalent to legacy oldlayout option
# For Motion 3.0 compatible mode choose: %Y/%m/%d-timelapse
# File extension .mpg is automatically added so do not include this
timelapse_filename %Y%m%d-timelapse
# Global Network Options
# Enable or disable IPV6 for http control and stream (default: off )
ipv6_enabled off
# Live Stream Server
# The mini-http server listens to this port for requests (default: 0 = disabled)
stream_port 8080
# Quality of the jpeg (in percent) images produced (default: 50)
stream_quality 50
# Output frames at 1 fps when no motion is detected and increase to the
# rate given by stream_maxrate when motion is detected (default: off)
stream_motion on
# Maximum framerate for stream streams (default: 1)
stream_maxrate 4
# Restrict stream connections to localhost only (default: on)
stream_localhost off
# Limits the number of images per connection (default: 0 = unlimited)
# Number can be defined by multiplying actual stream rate by desired number of seconds
# Actual stream rate is the smallest of the numbers framerate and stream_maxrate
stream_limit 0
# Set the authentication method (default: 0)
# 0 = disabled
# 1 = Basic authentication
# 2 = MD5 digest (the safer authentication)
stream_auth_method 1
# Authentication for the stream. Syntax username:password
# Default: not defined (Disabled)
##################################################################################stream_authen$
stream_authentication xxxxx:xxxxxxx
# HTTP Based Control
# TCP/IP port for the http server to listen on (default: 0 = disabled)
webcontrol_port 8081
# Restrict control connections to localhost only (default: on)
webcontrol_localhost on
# Output for http server, select off to choose raw text plain (default: on)
webcontrol_html_output on
# Authentication for the http based control. Syntax username:password
###################################################################################; webcontrol$
webcontrol_authentication xxxxxx:xxxxxxxx
# Tracking (Pan/Tilt)
# Type of tracker (0=none (default), 1=stepper, 2=iomojo, 3=pwc, 4=generic, 5=uvcvideo, 6=servo)
# The generic type enables the definition of motion center and motion size to
# be used with the conversion specifiers for options like on_motion_detected
track_type 0
# Enable auto tracking (default: off)
track_auto off
# Serial port of motor (default: none)
;track_port /dev/ttyS0
# Motor number for x-axis (default: 0)
;track_motorx 0
# Set motorx reverse (default: 0)
;track_motorx_reverse 0
# Motor number for y-axis (default: 0)
;track_motory 1
# Set motory reverse (default: 0)
;track_motory_reverse 0
# Maximum value on x-axis (default: 0)
;track_maxx 200
# Minimum value on x-axis (default: 0)
;track_minx 50
# Maximum value on y-axis (default: 0)
;track_maxy 200
# Minimum value on y-axis (default: 0)
;track_miny 50
# Center value on x-axis (default: 0)
;track_homex 128
# Center value on y-axis (default: 0)
;track_homey 128
# ID of an iomojo camera if used (default: 0)
track_iomojo_id 0
# Angle in degrees the camera moves per step on the X-axis
# with auto-track (default: 10)
# Currently only used with pwc type cameras
track_step_angle_x 10
# Angle in degrees the camera moves per step on the Y-axis
track_step_angle_y 10
# Delay to wait for after tracking movement as number
# of picture frames (default: 10)
track_move_wait 10
# Speed to set the motor to (stepper motor option) (default: 255)
track_speed 255
# Number of steps to make (stepper motor option) (default: 40)
track_stepsize 40
# External Commands, Warnings and Logging:
# You can use conversion specifiers for the on_xxxx commands
# %f = filename with full path
# %n = number indicating filetype
# Both %f and %n are only defined for on_picture_save,
# on_movie_start and on_movie_end
# Do not sound beeps when detecting motion (default: on)
# Note: Motion never beeps when running in daemon mode.
quiet on
# Command to be executed when an event starts. (default: none)
# An event starts at first motion detected after a period of no motion defined by event_gap
; on_event_start value
# Command to be executed when an event ends after a period of no motion
# (default: none). The period of no motion is defined by option event_gap.
; on_event_end value
# Command to be executed when a picture (.ppm|.jpg) is saved (default: none)
# To give the filename as an argument to a command append it with %f
; on_picture_save value
# Command to be executed when a motion frame is detected (default: none)
; on_motion_detected value
# Command to be executed when motion in a predefined area is detected
# Check option 'area_detect'.   (default: none)
; on_area_detected value
# Command to be executed when a movie file (.mpg|.avi) is created. (default: none)
; on_movie_start value
# Command to be executed when a movie file (.mpg|.avi) is closed. (default: none)
; on_movie_end value
# Command to be executed when a camera can't be opened or if it is lost
# NOTE: There is situations when motion don't detect a lost camera!
# It depends on the driver, some drivers dosn't detect a lost camera at all
# Some hangs the motion thread. Some even hangs the PC! (default: none)
; on_camera_lost value
# Common Options for database features.
# Options require database options to be active also.
# Log to the database when creating motion triggered picture file  (default: on)
; sql_log_picture on
# Log to the database when creating a snapshot image file (default: on)
; sql_log_snapshot on
# Log to the database when creating motion triggered movie file (default: off)
; sql_log_movie off
# Log to the database when creating timelapse movies file (default: off)
; sql_log_timelapse off
# SQL query string that is sent to the database
# Use same conversion specifiers has for text features
# Additional special conversion specifiers are
# %n = the number representing the file_type
# Default value:
# Create tables :
# Mysql
# CREATE TABLE security (camera int, filename char(80) not null, frame int, file_type int, time$
# Postgresql
# insert into security(camera, filename, frame, file_type, time_stamp, text_event) values('%t',$
; sql_query insert into security(camera, filename, frame, file_type, time_stamp, event_time_sta$
# Database Options
# database type : mysql, postgresql, sqlite3 (default : not defined)
; database_type value
# database to log to (default: not defined)
; database_dbname value
# The host on which the database is located (default: localhost)
# User account name for database (default: not defined)
; database_user value
# User password for database (default: not defined)
; database_password value
# Port on which the database is located
#  mysql 3306 , postgresql 5432 (default: not defined)
; database_port value
# Database Options For SQLite3
# SQLite3 database (file path) (default: not defined)
; sqlite3_db value
# Video Loopback Device (vloopback project)
# Output images to a video4linux loopback device
# The value '-' means next available (default: not defined)
; video_pipe value
# Output motion images to a video4linux loopback device
; motion_video_pipe value
# Thread config files - One for each camera.
# Except if only one camera - You only need this config file.
# If you have more than one camera you MUST define one thread
# config file for each camera in addition to this config file.
# Remember: If you have more than one camera you must have one
# thread file for each camera. E.g. 2 cameras requires 3 files:
# This motion.conf file AND thread1.conf and thread2.conf.
# Only put the options that are unique to each camera in the
# thread config files.
; thread /usr/local/etc/thread1.conf
; thread /usr/local/etc/thread2.conf
; thread /usr/local/etc/thread3.conf
; thread /usr/local/etc/thread4.conf
Id really appriaciate your advice on what to do,
Regards,
Reggie.
reggie4
Re: Motion.conf file for low light
Tue Feb 04, 2014 7:58 am
Hi all,
I know lots of you don't use motion, being a general PI forum, and wondered if anyone knows of a forum that specializes in the use of Motion. Iv'e Googled around, but not found anywhere.
I'm trying to improve the low level light performance, and am not too bothered about even using Video, as long as i get about 1 frame per second for 60 seconds when motion is detected.
The video clip i get is very dark, but it's not that dark when one looks with ones own eyes.
I don't mind using a script to fire off 60 shots with some other software, that motion calls when it detects movement; if that will improve low level light performance.
I'm playing with the settings, but getting nowhere fast!
Any ideas?
AndrewB
Mon Mar 31, 2014 7:09 pm
Hi there,
I've had some success by un-commenting the "mmalcam_control_params" line in the config file and specifying this:
mmalcam_control_params -ex sports -ev 25 --shutter 256000
The "-ex sports" encourages it to use 1600 ISO, i.e. the maximum sensitivity. The shutter speed specification holds the shutter open for enough light; although you might need to tune that. Finally the "-ev 25" seems necessary to prevent the "sports" mode from ignoring the shutter speed parameter.
I need to do much more research around the Pi camera to understand how the various preset modes (e.g. "sports") are defined; and to what extent they can be controlled. It looks like there are other threads on the forum about that.
The problem I'm having with the Pi NoIR and Motion is that I can't find a combination of camera settings that works well for both day and night. I'm considering writing a program to automatically modify the config script at sunrise and then again at sunset, so that it sets the values appropriately and then restarts the Motion service. Unless somebody else has any better ideas!
Cheers
reggie4
Tue Apr 15, 2014 10:13 am
Hi Andrew, you say
; that would be very good, and I'd be interested in your script.
I'm trying to control the sensitivity value in the motion.conf file via cron, but have had zero sucess, after weeks of trying! I thought I could try:
http://localhost:8091/0/config/set?threshold=4000 in the cron line at say 11pm then:
http://localhost:8091/0/config/set?threshold=1000
In the cron line at 6am, to make it less sensitive during the day, but it doesn't change the motion.conf file.
I just cannot manage to get it working, so am also considering a script to modify the motion.conf file and restart motion. But, am frustrated that I cannot get it to change a setting the way the wiki suggests!
I've just about given up, let me know if you have any sucess with your script, I too want to tune motion for day and night, Kind regards, Reggie.
grats
Fri Apr 25, 2014 6:56 am
reggie4 wrote:Hi Andrew, you say
Instead of all that, I'd do like:
have two files of motion.conf
just
make /home/day.conf & /home/night.conf
then have cron copy paste the day.conf to /etc/motion.conf at whatever time and the same deal for night
that'd be the easiest method, this way you just have two configurations that are near the same but slightly different for your light/day light and just replace the /etc/motion.conf cuz the cp command rewrites/renames the file when you copy it anyway
and then just restart motion I am pretty sure you have to do? there is no reload configuration I don't think
so like
stop motion
copy night config
start motion
etc
Fri Apr 25, 2014 9:04 am
reggie4 wrote: I'm trying to control the sensitivity value in the motion.conf file via cron, but have had zero sucess, after weeks of trying! I thought I could try:
http://www.raspberrypi.org/forums/viewt ... 91&t=71010 gives you some ways to calculate sunrise/sunset. You should be able to do a HTTP GET to those threshold URLs from a python script.
reggie4
Wed Apr 30, 2014 2:08 pm
Thanks Dougie I'll look into that,
Iv'e written a script to control motion via cron, as i gave up trying to use motion's software interface!
It can be used to automatically tune motion for day and night.
you can find it here.
http://raspberrypi.stackexchange.com/qu ... n-via-cron
Kind Regards,
Reggie.
richrarobi
Sun Nov 27, 2016 10:33 am
I realise this is a very old post....
I have the mmal version of motion working, but there is another thread viewtopic.php?f=43&t=166287&p=1071957&h ... n#p1071957 that uses standard motion with the picamera module. I wanted to use this as I think I can then have multiple threads (add a webcam to the picam setup).
However low light wasn't so good.
It is possible the solution is in the brightness setting (auto brightness off, brightness 110)
- waiting for night time to see if it works... :roll:
NOPE! Standard motion stll has black screen, mmal motion shows picture, by the light of the street lamp...
Anyone suggest how to set standard motion up for low light??
stefets2112
Wed Jul 25, 2018 1:02 am
Hi all,
I bump up this thread, if anyone have a solution how to patch motion OR motion.conf to get good pictures in the night please reply !
When using the raspistill --exposure night switch with the camera module the image is clear even in the night.
How can I tell motion to capture with --exposure night ? Is this possible ?
lackdaz
Fri Sep 14, 2018 4:01 am
For the benefit of all,
I've treaded perhaps the exact same path as most of you have - trying to get a PiNoir to capture video on my sleeping parrot and then trying to extend its functionality to the day. This was also my first time working with mmal cameras. There are a number of preconditions that you need to ensure in order to get mmal working - at least that was what I found out over a couple of days.
1) If you intend to use mmal functionality, you need to install motion via wget rather than apt-get. Instructions here https://rawgit.com/Motion-Project/motio ... build.html. This peculiarity is explained here https://motion-project.github.io/motion_config.html
2) In the `motion.conf` files, you need to uncomment out mmalcam_name which defaults to vc.ril.camera. Just remove the ;. You will also need to uncomment out mmal_control_params if you wish to add in any control parameters. So for clarity, the line should read
mmal_control_params -ex night
instead of
; mmal_control_params -ex night
3) Next, you need to restart your daemon (if you are using one) via sudo kill -s SIGHUP xxxx where xxxx is your camera pid or sudo /etc/init.d/motion restart
Peripherals and control parameters wise, you will need a IR light source - I used a single bulb and there tends to be a 'halo effect' caused by the uneven light dispersion from the source. But you will need this light source to provide some contrast from its background. Also make sure that your frame rates are low enough to get enough exposure in (I currently leave this at the default 2, but I've noticed better images when I dropped it below 2, ie changing the minimum_time_frame to above 0. I'll post results again when I get my better light source in.
I'm by far no code expert, nor imaging expert, so do point out where I might have messed up! I do document my process for setting up things so I can retrace them. So do watch out this space https://github.com/lackdaz/rpi-projects. Currently, I'm working on writing that cron script to change day/night settings ie increase frame rates during the day and lower them at night. I hope this helps someone!
Johnny_quattro
Fri Oct 02, 2020 12:32 pm
Thanks for your post from around 2 years ago. Don't you just love the tinterweb? haha
It has certainly clarified a few issues for me.
I run 4 separate Raspberry Pi cameras (official Pi camera modules, 1 is NoIR and the other 3 are standard jobs) and moved away from the mmalcam option due to problems with dependencies. This was down to running different versions of OS, as one Pi was still on Wheezy and the rest were on Jessie. Now they are all on Buster and that's when I went down the standard motion daemon route, installed via apt. Much less hassle and a lot easier. I only discovered the poor light performance issue when I needed to look at some of the captured footage and was concerned to see essentially a black picture with just the overlaid timestamp (double-height option) in the bottom right-hand side of the image. This obviously made the footage unusable, and the previous motion-mmalcam setup worked fine. Usual disclaimer here - I know it's night time and I know it's dark but the cameras were definitely capturing usable images in he past, with the motion-mmalcam option.
I read the 2nd link provided (the first one no longer works unfortunately) and saw the following:
"Raspberry Pi cameras can be set up two different ways. If Motion is installed by using the apt packages (e.g. apt-get install motion), then the camera must be set up using the bcm2835-v4l2 module which creates a v4l2 device for the camera. Users will need to install this module using the command sudo modprobe bcm2835-v4l2. This will set up the camera as a normal v4l2 device and it can be accessed via a standard /dev/videoX device. If Motion is built from source or installed via the deb packages on the project release page, then an additional option is to set up the camera using the mmalcam_name parameter or using the bcm2835-v4l2 module. When Motion is installed via apt, the mmalcam option is not available."
I performed some troubleshooting late last night after stopping the running motion daemon and had great success with the following raspistill command:
It proved that there was nothing wrong with the camera so it must therefore be a software-related issue, which you've alluded to in your detailed post above. Thanks for that. Armed with this new (to me) information, I will go down the route of manually installing the .deb package rather than using apt/apt-get and hopefully later this evening will be able to test further.
Cheers,
John G
sparkie777
Fri Oct 02, 2020 1:06 pm
this and most of the other quotations is completely outdated. At least in Pi OS buster.
Why don't you just install via apt and check '/etc/motion/motion.conf'? You will see all required options are already there.
Johnny_quattro
Fri Oct 02, 2020 1:47 pm
You appear to have written that I wrote that. It was denoted by quotation marks and was taken from the 2nd link, as stated. I also highlighted the quoted part of the text in bold font. I hope that clarifies things for you.
With regard to the actual issue at hand, I've already installed motion via apt/apt-get as detailed in my post. Apart from changes to the config for port numbers etc., mmalcam-motion previously yielded decent usable photos at night, especially so with street lighting. With the current motion daemon, pictures taken are incredibly dark and unusable. I've already gone down the purge route to remove any configs and used the supplied /etc/motion/motion.conf when installed from scratch.
Johnny_quattro
Fri Oct 02, 2020 3:25 pm
Thanks for the pointer to the differences on the config file options within motion.conf. I've had to tweak various parameters including the timelapse options, as well as the mmalcam stuff for low-light conditions. All seems to be working well right now but further testing will be required shortly when it gets darker as the sun sets (at time of writing).
Return to “Camera board”
