CopterRichie
omxplayer to play stream from 2nd Pi
Wed Jan 29, 2014 7:27 pm
Thank you in advance,
I would like to use omxplayer on Pi#2 to play a video stream sent from Pi#1. On Pi#1, I am using the following
raspivid -t 0 -w 640 -h 480 -o - | nc 192.168.1.10 5001
What is required on Pi#2 to play the stream using omxplayer? (hopefully, something very simple)
Richard
tvjon
Re: omxplayer to play stream from 2nd Pi
Wed Jan 29, 2014 7:51 pm
Will something simpler do?
nc -l -k 5001 | ./hello_video.bin /dev/stdin
Negligible latency :)
Make sure hello_video.bin is in your path.
You may have to build it in /opt/ etc.
HTH
CopterRichie
Wed Jan 29, 2014 8:11 pm
Thank you.
CopterRichie
Wed Jan 29, 2014 9:17 pm
tvjon wrote:Will something simpler do?
HTH
thank you, thank you and another thank you. Perfect!!
CopterRichie
Fri Jan 31, 2014 10:07 pm
Follow up question please, how can I modify the above line to write to both the /dev/stdin and to a file simultaneously?
Thank you.
ghans
Fri Jan 31, 2014 10:16 pm
nc -l -k 5001 | tee filename.h264 | ./hello_video.bin /dev/stdin
ghans
CopterRichie
Fri Jan 31, 2014 10:17 pm
Thank you!!!
wjaxxx
Mon Aug 25, 2014 6:59 am
I have the same setup.
It works beautifull during the first moments while there is data in the hello_video buffer.
However when the receiver pi catch up the transmitter pi, the video starts to play less smooth like a little bit choppy.
Does it happens to you?
joicemj
Sun Feb 05, 2017 9:25 am
This is super cool. Thanks for sharing this here. I would like to go a step further. How to simply make a video conferencing using the same ?
I was thinking about a solution, like this
picture shows.
One window showing the present user and the other window, remote user.
is this possible to composite both using `raspivid` ?
what about the possibility of doing the same with `gstreamer` ?
compositing is possible, I tried. But suffering to do the same with remote videos.
Any recommendations / help ?
Return to “Camera board”
