danekshea
Streaming: /dev/video0 does not support streaming i/o
Fri Jan 24, 2014 6:05 pm
Hey guys,
I've been trying to get my Raspberry pi camera module working forever now and just can't seem to crack it. I'm trying to use it in conjunction with Octoprint which is a web based print server for 3d printers. Of course, it would be nice to have a stream of my printer while I'm not there.
I have installed uv4l and all the packages for that. I have also made mjpg-streamer but keep getting the following when I try to run a mjpg-streamer instance:
[email protected] ~ $ /home/pi/mjpg-streamer/mjpg-streamer-experimental/mjpg_streamer -i "/home/pi/mjpg-streamer/mjpg-streamer-experimental/input_uvc.so -d /dev/video0 -r SXGA" -o "/home/pi/mjpg-streamer/mjpg-streamer-experimental/output_http.so"
MJPG Streamer Version: svn rev: Unversioned directory
 i: Using V4L2 device.: /dev/video0
 i: Desired Resolution: 1280 x 1024
 i: Frames Per Second.: -1
 i: Format............: JPEG
 i: TV-Norm...........: DEFAULT
 Init v4L2 failed !! exit fatal
 i: init_VideoIn failed
[email protected] ~ $ ^C
[email protected]ypi ~ $ /dev/video0 does not support streaming i/o
I can't figure it out. Any ideas?
RpiName
Re: Streaming: /dev/video0 does not support streaming i/o
Sun Jan 26, 2014 1:02 am
Add this line in /etc/environment and logoff/login or reboot:
LD_PRELOAD=/usr/lib/uv4l/uv4lext/armv6l/libuv4lext.so
danekshea
Wed Jan 29, 2014 8:59 pm
And this worked perfectly. Thank you so much, I've been caught up watching my printer on the camera :D.
Nerol
Sat Sep 12, 2015 9:10 am
it doesn't work for me.
mjpg_streamer -i "/usr/local/lib/input_uvc.so -f 10 -r 320x240" -o "/usr/local/lib/output_http.so -w /home/pi/domotica/video
MJPG Streamer Version: svn rev: 3:172
 i: Desired Resolution: 320 x 240
 i: Frames Per Second.: 10
 i: Format............: MJPEG
It fails when it's executed with sudo, but works without sudo privileges :shock:
RpiName
Sat Sep 12, 2015 10:11 am
Use the UV4L Streaming Server instead of mjpeg_streamer?
Nerol
Sat Sep 12, 2015 5:39 pm
I don't know what you mean
RpiName
Sat Sep 12, 2015 5:56 pm
Nerol wrote:I don't know what you mean
Why don't you use the UV4L Streaming Server to get the MJPEG Stream and control the camera settings directly instead of using mjpg_streamer?
http://www.linux-projects.org/modules/s ... e&artid=14
Return to “Camera board”
