Page 194 of 210
Re: RPi Cam Web Interface
Posted: Thu Oct 18, 2018 1:37 pm
by oldjake
Thanks for the reply. I have been variously refreshing or going out of the page and back in again.
I kicked off another one after I reduced the image resolution. So my image res is 600 x 900. The preview says 121kb (104). The video bit still says 'Busy". I started the conversion at 11.39 which is just about 3 hours ago.
Posted: Thu Oct 18, 2018 1:39 pm
by oldjake
Oh, this is what's in the "Convert using" box:
/usr/bin/ffmpeg -f image2 -i i_%05d.jpg
Posted: Thu Oct 18, 2018 2:13 pm
by btidey
Are you running latest version? There was a fix for the time lapse command put in last week.
If the time lapse command fails then the file will say Busy as the lack of a .mp4 file is what triggers that. The log should say what command was used to do the convert.
Posted: Wed Oct 24, 2018 9:25 pm
by Gary Littlemore
Robert
I had videos that were locked and I had a day of videos today that all had busy against them so I deleted all, the videos that were locked have also deleted.
Posted: Wed Oct 24, 2018 9:38 pm
by btidey
Robert
Yes. I can confirm that happens. Strange as the files are set to read only.
Under investigation.
Posted: Wed Oct 24, 2018 9:55 pm
by btidey
Robert
It looks like the php unlink used in the delete all is not respecting the read only flag.
I'm checking further but I have put in an extra check to prevent this which seems to work in the latest version.
Edit: I understand this now, The erase permissions that unlink is using are at the folder not file level.
The fix put in is effective.
Posted: Wed Oct 24, 2018 11:37 pm
by smxsmxsmx
How would I go about using RPi-Cam-Web-Interface over local wifi access point / connecting with phone to wifi of raspberry pi without going over router?
Posted: Thu Oct 25, 2018 8:23 am
by btidey
If you set the raspberry Pi up as an AP (access point) then it behaves like a wifi router. You can then scan wifi on your phone and connect to the raspberry pi hosted network. The Cam-Web interface will then be accessible from the phone.
There are various tutorials on setting the Pi as an AP. E.g.
https://www.raspberrypi.org/documentati ... s-point.md
Posted: Thu Oct 25, 2018 10:12 am
by Kaushik
Camera preview freeze issue:
Hi, I have a set up that works perfectly most of the time. However, every 3 or 4 days. The preview freezes. I want to know why and how to avoid it?
The cam.jpg stops getting updated. I understand, when that happens, the child raspimjpeg should kill itself and the parent will spawn a new child.
However, that isn't happening : htop shows two raspimjpeg processes and they are sleeping. The TIME+ column has 10h51:15 for the child raspimjpeg.
Why didn't the expected behavior happen. Is there anything I can look for?
Posted: Fri Oct 26, 2018 7:17 am
by ruder
Hello, everyone, I am facing big problem while installing Rpi cam web interface on Raspbian strech lite.
After cloning from Git. I install it using chmod u+x ...
but later i get this error , every time when i try to use sudo :( .
"sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set"
Any solution plz help me, btidey.
Posted: Fri Oct 26, 2018 9:28 am
by Gary Littlemore
The wiki says the chmod was only for older versions, just go with the following:
git clone https://github.com/silvanmelchior/RPi_C ... erface.git
cd RPi_Cam_Web_Interface
./install.sh
Posted: Fri Oct 26, 2018 9:37 am
by ruder
Ok thanks :)
Posted: Sat Oct 27, 2018 7:33 am
by ruder
Posted: Sun Oct 28, 2018 7:06 am
by Gary Littlemore
I’ve got wrongly reported video length times in library, but look at the times between the clips roughly 10 seconds clips.
0541 267921 Kb 359s
2018-10-28
06:51:39
0542 13186 Kb 189s
2018-10-28
06:51:49
0543 9977 Kb 176s
2018-10-28
06:51:52
0544 24992 Kb 183s
2018-10-28
06:52:04
0545 21601 Kb 162s
2018-10-28
06:52:16
Posted: Mon Oct 29, 2018 6:05 pm
by smxsmxsmx
Thank you! I did that, but now the service doesn't autostart anymore and the buttons to capture video, photo do not work anymore. Why could that be?
Posted: Tue Oct 30, 2018 10:43 am
by smxsmxsmx
RPi-Cam-Web-Interface now autostarts but where the camera preview would be is a broken image icon that keeps flashing. Buttons still don't work.
Posted: Thu Nov 01, 2018 8:11 am
by Gary Littlemore
0541 267921 Kb 359s
2018-10-28
06:51:39
0542 13186 Kb 189s
2018-10-28
06:51:49
0543 9977 Kb 176s
2018-10-28
06:51:52
0544 24992 Kb 183s
2018-10-28
06:52:04
0545 21601 Kb 162s
2018-10-28
06:52:16
I’ve got more again this morning:
1375 11846 Kb 204s
2018-11-01
07:36:00
1374 21513 Kb 689s
2018-11-01
07:35:55
1373 11576 Kb 867s
2018-11-01
07:35:45
1372 5112 Kb 1258s
2018-11-01
07:35:42
1371 1988047 Kb 2456s
2018-11-01
07:35:35
Posted: Fri Nov 02, 2018 11:15 pm
by wpballa1
Bob,
I can't quite prove it yet, but I suspect that the purge based on % of disk space left is not working properly. My disk seems to fill up and then the program locks up instead of deleting old videos. If I can get in on time and delete them manually, all is fine, but the automatic purge doesn't seem to be working.
Thanks for any help or advice.
Bill Ballard
Posted: Fri Nov 02, 2018 11:22 pm
by Gary Littlemore
Bob,
Bill Ballard
I’ve found mine gets to around 60% and every montion dectection after that locks up and stays as the status ‘busy’.
Posted: Fri Nov 02, 2018 11:28 pm
by wpballa1
Yes, that sounds like the problem. I will try using Max Space in GB and see if that works. I had to rebuild the entire system it locked up so badly this time. Fortunately, that doesn't take too long.
Posted: Sat Nov 03, 2018 12:20 am
by Gary Littlemore
I’m currently on ‘local:52.5% Total:60052(MB)’ so I’d think it’ll hit 60% at some point tomorrow so I’ll see how I get on.
Posted: Sun Nov 04, 2018 8:54 pm
by Gary Littlemore
I’m currently on ‘local:74% Total:60052(MB)’ no issues yet.
Posted: Mon Nov 05, 2018 7:29 pm
by wpballa1
Well, I got to about the limit in GB that I requested, and then it just stopped recording videos rather than purging any.
Posted: Mon Nov 05, 2018 10:24 pm
by Gary Littlemore
I’m now on local:82% Total:60052(MB), 85% is my limit where it should start deleting files.
Posted: Wed Nov 07, 2018 10:06 pm
by demballs
I've ended up here after lots of searching and have a few questions about whether this tool will meet my requirements.
What I'm after really is (at least) a 720 height, 30fps live video server that applications like OBS Studio can read and include in recordings / streams.
I've read a lot about the preview feed - would that be configurable to that kind of resolution? It would be included in videos / streams that are designed to be watched for entertainment rather than security / surveillance. I'm pretty certain I can connect OBS Studio to that feed, given that it's mjpeg.
I have a few Raspberry Pi Bs hanging around - is it worth me picking up a camera? Can I achieve this?
Thanks in advance for any help.
