Page 133 of 208
Re: RPi Cam Web Interface
Posted: Tue Mar 29, 2016 9:01 am
by spex357
In my last post I'd left Pi out filming after a stop start and don't reboot attempt. I powered it down late that evening, my video's and pictures luckily downloaded in my Pc 's browser. Sunday morning re-power just to check that I wasn't leaving anything behind before formatting. I spent the rest of Sunday trying to rescue my week old sd card, now formatted but won't accept files.
Luckily I have other cards, installed pi-pan, rebooted, same old, raspi, sudo apt-get and finished it off with ./install, Rpi- error re-start etc on reboot, raspi enable camera, camera enabled on reboot, but no buttons, chmod, buttons now work.
Installed Pipe, redirected Servoblaster files, reboot, no direction buttons working, started Crome, pipan.pipe in the list, re-installed pi-pan, rebooted, checked Servoblaster, no feed on Gpio's, renamed servo_off to servo_on in /html, opened Pipan.pipe to find it had no contents, yes pipan.pipe had no contents, hence the buttons didn't work. reboot, no buttons, open pipan.pipe and re-direct it
Reboot, now the camera is steerable on an iphone and ipad by touch (I've never had that working before), just need to remember where I can set the minimum movement down to 1 and I'd call that a super install. Well done, impressed as usual.
Posted: Tue Mar 29, 2016 10:19 am
by btidey
bic wrote:I have my cams in motion state. Once in a while it will 'freeze' during recording. The web interface doesn't freeze, just the preview image (and no further recordings take place). The preview page after reboot always has that last recording in "Busy" state. I can reboot through the web interface. What service can I restart instead of rebooting the pi? Also can there be a check, when the preview is not being updated to restart that service automatically? This has been an issue on all versions.
Also what service/script do you use to keep the disc from becoming full?
Great project, keep up the good work!
The main background service is raspimjpeg. There are actually 2 copies of this running with one acting as a monitor / restart in case the first dies. There is also a check for the preview image not updating in the watchdog interval which should trigger a restart.
The raspimjpeg process can best be restarted via the stop.sh and start.sh scripts in the install folder.
The scheduler has settings to do purging and maintain the disk capacity. I haven't manually deleted images from one of my cameras in over a year.
Posted: Wed Mar 30, 2016 7:38 am
by Patrick260284
Hey guys. Don´t know if this has been asked before, but is it possible to sync the video-stream to an audio device?
I have a daffodil usb soundcard attached (configured and working) with a microphone and would like to have constant audio in my stream.
Posted: Wed Mar 30, 2016 2:22 pm
by ScheissSchiesser
Hi there. I am hoping somebody can help me clarify an error I get when I set
netcam_keepalive on
in the motion configuration file. It looks like it is having trouble reading or converting the jpeg image from the stream?
Before you read through this, here are the questions I am trying to answer:
  • Why does
    netcam_keepalive on
    cause this error (which stops motion from ever getting any image data)?
  • Should I not be using keepalive for the connection?
Thanks for your time!
netcam_keepalive on
[0] [NTC] [ALL] [Mar 30 10:01:33] motion_startup: Using log type (ALL) log level (ALL)
[0] [NTC] [ALL] [Mar 30 10:01:33] become_daemon: Motion going to daemon mode
[0] [NTC] [ALL] [Mar 30 10:01:33] motion_startup: Motion running as daemon process
[0] [NTC] [ENC] [Mar 30 10:01:33] ffmpeg_init: ffmpeg LIBAVCODEC_BUILD 3670016 LIBAVFORMAT_BUILD 3670272
[0] [NTC] [ALL] [Mar 30 10:01:33] main: Thread 1 is from /etc/motion/motion.conf
[0] [NTC] [ALL] [Mar 30 10:01:33] main: Thread 1 is device: http://localhost/html/cam_pic.php input -1
[0] [NTC] [ALL] [Mar 30 10:01:33] main: Stream port 6643
[0] [NTC] [ALL] [Mar 30 10:01:33] main: Waiting for threads to finish, pid: 3103
[1] [NTC] [ALL] [Mar 30 10:01:33] motion_init: Thread 1 started , motion detection Enabled
[1] [ALR] [NET] [Mar 30 10:01:33] netcam_start: Network Camera thread starting... for url (http://localhost/html/cam_pic.php)
[1] [DBG] [NET] [Mar 30 10:01:33] netcam_url_parse: Entry netcam_url_parse data http://localhost/html/cam_pic.php
[1] [DBG] [NET] [Mar 30 10:01:33] netcam_url_parse: Parse case 0 data http://localhost/html/cam_pic.php
[1] [DBG] [NET] [Mar 30 10:01:33] netcam_url_parse: Parse case 1 data http
[1] [DBG] [NET] [Mar 30 10:01:33] netcam_url_parse: Parse case 6 data localhost
[1] [DBG] [NET] [Mar 30 10:01:33] netcam_url_parse: Parse case 9 data /html/cam_pic.php
[1] [INF] [NET] [Mar 30 10:01:33] netcam_start: Netcam_http parameter 'on' converts to flags: HTTP/1.0: 0 HTTP/1.1: 1 Keep-Alive ON.
[1] [INF] [NET] [Mar 30 10:01:33] netcam_start: now calling netcam_setup_html()
[1] [INF] [NET] [Mar 30 10:01:33] netcam_http_build_url: Netcam has flags: HTTP/1.0: 0 HTTP/1.1: 1 Keep-Alive ON.
[1] [INF] [NET] [Mar 30 10:01:33] netcam_http_build_url: Camera connect string is ''GET /html/cam_pic.php HTTP/1.1
Host: localhost
User-Agent: Motion-netcam/3.2.12+git20140228
Connection: Keep-Alive
Authorization: Basic cGk6JGNIIzg4MTM=
'' End of camera connect string.
[1] [INF] [NET] [Mar 30 10:01:33] netcam_http_request: about to try to connect, time #0
[1] [INF] [NET] [Mar 30 10:01:33] netcam_connect: with keepalive set, invalid socket.This could be first time, created a new one with fd 12
[1] [INF] [NET] [Mar 30 10:01:33] netcam_connect: SO_KEEPALIVE is OFF
[1] [INF] [NET] [Mar 30 10:01:33] netcam_connect: SO_KEEPALIVE set on socket.
[1] [INF] [NET] [Mar 30 10:01:33] netcam_connect: re-using socket 12 since keepalive is set.
[1] [INF] [NET] [Mar 30 10:01:33] netcam_read_first_header: Received first header ('HTTP/1.1 200 OK')
[1] [INF] [NET] [Mar 30 10:01:33] netcam_read_first_header: Received first header ('Server: nginx/1.6.2')
[1] [INF] [NET] [Mar 30 10:01:33] netcam_check_content_length: Content-Length -1
[1] [INF] [NET] [Mar 30 10:01:33] netcam_read_first_header: Received first header ('Date: Wed, 30 Mar 2016 14:01:33 GMT')
[1] [INF] [NET] [Mar 30 10:01:33] netcam_read_first_header: Received first header ('Content-Type: image/jpeg')
[1] [INF] [NET] [Mar 30 10:01:33] netcam_check_content_type: Content-type image/jpeg
[1] [NTC] [NET] [Mar 30 10:01:33] netcam_read_first_header: Non-streaming camera (keep-alive set)
[1] [INF] [NET] [Mar 30 10:01:33] netcam_read_first_header: Received first header ('Transfer-Encoding: chunked')
[1] [INF] [NET] [Mar 30 10:01:33] netcam_read_first_header: Received first header ('Connection: keep-alive')
[1] [INF] [NET] [Mar 30 10:01:33] netcam_read_first_header: Received first header ('')
[1] [INF] [NET] [Mar 30 10:01:33] netcam_read_first_header: No 'Connection: Keep-Alive' nor 'Connection: close' header received.
 Motion continues unchanged.
[1] [NTC] [NET] [Mar 30 10:01:33] netcam_setup_html: connected, going on to read image.
[1] [DBG] [NET] [Mar 30 10:01:33] netcam_check_buffsize: expanding buffer from [0/0] to [0/4096] bytes.
[1] [DBG] [NET] [Mar 30 10:01:33] netcam_check_buffsize: expanding buffer from [3941/4096] to [3941/8192] bytes.
[1] [DBG] [NET] [Mar 30 10:01:33] netcam_check_buffsize: expanding buffer from [8037/8192] to [8037/12288] bytes.
[1] [DBG] [NET] [Mar 30 10:01:33] netcam_check_buffsize: expanding buffer from [12133/12288] to [12133/16384] bytes.
[1] [NTC] [NET] [Mar 30 10:01:38] netcam_read_html_jpeg: leaving netcam connected.
[1] [DBG] [NET] [Mar 30 10:01:38] netcam_output_message: Not a JPEG file: starts with 0x31 0x66
[1] [INF] [NET] [Mar 30 10:01:38] netcam_error_exit: netcam->jpeg_error 1
[1] [CRT] [NET] [Mar 30 10:01:38] netcam_start: libjpeg decompression failure on first frame - giving up!
[1] [WRN] [ALL] [Mar 30 10:01:38] motion_init: Could not fetch initial image from camera Motion continues using width and height from config file(s)
[1] [NTC] [ALL] [Mar 30 10:01:38] image_ring_resize: Resizing pre_capture buffer to 1 items
[1] [NTC] [STR] [Mar 30 10:01:38] http_bindsock: motion-stream testing : IPV4 addr: 127.0.0.1 port: 6643
[1] [NTC] [STR] [Mar 30 10:01:38] http_bindsock: motion-stream Bound : IPV4 addr: 127.0.0.1 port: 6643
[1] [NTC] [ALL] [Mar 30 10:01:38] motion_init: Started motion-stream server in port 6643 auth Disabled
[1] [DBG] [ALL] [Mar 30 10:01:38] motion_loop: vid_return_code 1
[1] [DBG] [ALL] [Mar 30 10:01:39] motion_loop: vid_return_code 1
[1] [WRN] [ALL] [Mar 30 10:01:40] motion_loop: Retrying until successful connection with camera
[1] [ALR] [NET] [Mar 30 10:01:40] netcam_start: Network Camera thread starting... for url (http://localhost/html/cam_pic.php)
[1] [DBG] [NET] [Mar 30 10:01:40] netcam_url_parse: Entry netcam_url_parse data http://localhost/html/cam_pic.php
[1] [DBG] [NET] [Mar 30 10:01:40] netcam_url_parse: Parse case 0 data http://localhost/html/cam_pic.php
[1] [DBG] [NET] [Mar 30 10:01:40] netcam_url_parse: Parse case 1 data http
[1] [DBG] [NET] [Mar 30 10:01:40] netcam_url_parse: Parse case 6 data localhost
[1] [DBG] [NET] [Mar 30 10:01:40] netcam_url_parse: Parse case 9 data /html/cam_pic.php
[1] [INF] [NET] [Mar 30 10:01:40] netcam_start: Netcam_http parameter 'on' converts to flags: HTTP/1.0: 0 HTTP/1.1: 1 Keep-Alive ON.
[1] [INF] [NET] [Mar 30 10:01:40] netcam_start: now calling netcam_setup_html()
[1] [INF] [NET] [Mar 30 10:01:40] netcam_http_build_url: Netcam has flags: HTTP/1.0: 0 HTTP/1.1: 1 Keep-Alive ON.
[1] [INF] [NET] [Mar 30 10:01:40] netcam_http_build_url: Camera connect string is ''GET /html/cam_pic.php HTTP/1.1
Host: localhost
[1] [INF] [NET] [Mar 30 10:01:40] netcam_http_request: about to try to connect, time #0
[1] [INF] [NET] [Mar 30 10:01:40] netcam_connect: with keepalive set, invalid socket.This could be first time, created a new one with fd 13
[1] [INF] [NET] [Mar 30 10:01:40] netcam_connect: SO_KEEPALIVE is OFF
[1] [INF] [NET] [Mar 30 10:01:40] netcam_connect: SO_KEEPALIVE set on socket.
[1] [INF] [NET] [Mar 30 10:01:40] netcam_connect: re-using socket 13 since keepalive is set.
[1] [INF] [NET] [Mar 30 10:01:40] netcam_read_first_header: Received first header ('HTTP/1.1 200 OK')
[1] [INF] [NET] [Mar 30 10:01:40] netcam_read_first_header: Received first header ('Server: nginx/1.6.2')
[1] [INF] [NET] [Mar 30 10:01:40] netcam_check_content_length: Content-Length -1
[1] [INF] [NET] [Mar 30 10:01:40] netcam_read_first_header: Received first header ('Date: Wed, 30 Mar 2016 14:01:40 GMT')
[1] [INF] [NET] [Mar 30 10:01:40] netcam_read_first_header: Received first header ('Content-Type: image/jpeg')
[1] [INF] [NET] [Mar 30 10:01:40] netcam_check_content_type: Content-type image/jpeg
[1] [NTC] [NET] [Mar 30 10:01:40] netcam_read_first_header: Non-streaming camera (keep-alive set)
[1] [INF] [NET] [Mar 30 10:01:40] netcam_read_first_header: Received first header ('Transfer-Encoding: chunked')
[1] [INF] [NET] [Mar 30 10:01:40] netcam_read_first_header: Received first header ('Connection: keep-alive')
[1] [INF] [NET] [Mar 30 10:01:40] netcam_read_first_header: Received first header ('')
[1] [INF] [NET] [Mar 30 10:01:40] netcam_read_first_header: No 'Connection: Keep-Alive' nor 'Connection: close' header received.
[1] [NTC] [NET] [Mar 30 10:01:40] netcam_setup_html: connected, going on to read image.
[1] [DBG] [NET] [Mar 30 10:01:40] netcam_check_buffsize: expanding buffer from [0/0] to [0/4096] bytes.
[1] [DBG] [NET] [Mar 30 10:01:40] netcam_check_buffsize: expanding buffer from [3941/4096] to [3941/8192] bytes.
[1] [DBG] [NET] [Mar 30 10:01:40] netcam_check_buffsize: expanding buffer from [8164/8192] to [8164/12288] bytes.
[1] [DBG] [NET] [Mar 30 10:01:40] netcam_check_buffsize: expanding buffer from [12259/12288] to [12259/16384] bytes.
[1] [NTC] [NET] [Mar 30 10:01:45] netcam_read_html_jpeg: leaving netcam connected.
[1] [DBG] [NET] [Mar 30 10:01:45] netcam_output_message: Not a JPEG file: starts with 0x31 0x66
[1] [INF] [NET] [Mar 30 10:01:45] netcam_error_exit: netcam->jpeg_error 1
[1] [CRT] [NET] [Mar 30 10:01:45] netcam_start: libjpeg decompression failure on first frame - giving up!
[1] [DBG] [ALL] [Mar 30 10:01:45] motion_loop: vid_return_code 1
[1] [DBG] [ALL] [Mar 30 10:01:46] motion_loop: vid_return_code 1
[1] [DBG] [EVT] [Mar 30 10:01:46] exec_command: Executing external command 'echo -n '0' >/var/www/html/FIFO1'
[1] [NTC] [ALL] [Mar 30 10:01:46] motion_loop: End of event 1
[1] [NTC] [ALL] [Mar 30 10:01:46] motion_loop: Thread exiting
[1] [NTC] [STR] [Mar 30 10:01:46] stream_stop: Closing motion-stream listen socket & active motion-stream sockets
[1] [NTC] [STR] [Mar 30 10:01:46] stream_stop: Closed motion-stream listen socket & active motion-stream sockets
[0] [NTC] [ALL] [Mar 30 10:01:47] main: Threads finished
[0] [NTC] [ALL] [Mar 30 10:01:48] main: Motion terminating
[0] [NTC] [ALL] [Mar 30 10:01:48] motion_remove_pid: Closing logfile (/home/pi/motion.log).
netcam_keepalive off
[0] [NTC] [ALL] [Mar 30 10:13:38] motion_startup: Using log type (ALL) log level (ALL)
[0] [NTC] [ALL] [Mar 30 10:13:38] become_daemon: Motion going to daemon mode
[0] [NTC] [ALL] [Mar 30 10:13:38] motion_startup: Motion running as daemon process
[0] [NTC] [ENC] [Mar 30 10:13:38] ffmpeg_init: ffmpeg LIBAVCODEC_BUILD 3670016 LIBAVFORMAT_BUILD 3670272
[0] [NTC] [ALL] [Mar 30 10:13:38] main: Thread 1 is from /etc/motion/motion.conf
[0] [NTC] [ALL] [Mar 30 10:13:38] main: Thread 1 is device: http://localhost/html/cam_pic.php input -1
[0] [NTC] [ALL] [Mar 30 10:13:38] main: Stream port 6643
[0] [NTC] [ALL] [Mar 30 10:13:38] main: Waiting for threads to finish, pid: 3308
[1] [NTC] [ALL] [Mar 30 10:13:38] motion_init: Thread 1 started , motion detection Enabled
[1] [ALR] [NET] [Mar 30 10:13:38] netcam_start: Network Camera thread starting... for url (http://localhost/html/cam_pic.php)
[1] [DBG] [NET] [Mar 30 10:13:38] netcam_url_parse: Entry netcam_url_parse data http://localhost/html/cam_pic.php
[1] [DBG] [NET] [Mar 30 10:13:38] netcam_url_parse: Parse case 0 data http://localhost/html/cam_pic.php
[1] [DBG] [NET] [Mar 30 10:13:38] netcam_url_parse: Parse case 1 data http
[1] [DBG] [NET] [Mar 30 10:13:38] netcam_url_parse: Parse case 6 data localhost
[1] [DBG] [NET] [Mar 30 10:13:38] netcam_url_parse: Parse case 9 data /html/cam_pic.php
[1] [INF] [NET] [Mar 30 10:13:38] netcam_start: Netcam_http parameter 'off' converts to flags: HTTP/1.0: 1 HTTP/1.1: 0 Keep-Alive OFF.
[1] [INF] [NET] [Mar 30 10:13:38] netcam_start: now calling netcam_setup_html()
[1] [INF] [NET] [Mar 30 10:13:38] netcam_http_build_url: Netcam has flags: HTTP/1.0: 1 HTTP/1.1: 0 Keep-Alive OFF.
[1] [INF] [NET] [Mar 30 10:13:38] netcam_http_build_url: Camera connect string is ''GET /html/cam_pic.php HTTP/1.0
Host: localhost
Connection: close
[1] [INF] [NET] [Mar 30 10:13:38] netcam_http_request: about to try to connect, time #0
[1] [INF] [NET] [Mar 30 10:13:38] netcam_connect: disconnecting netcam since keep-alive not set.
[1] [INF] [NET] [Mar 30 10:13:38] netcam_connect: with no keepalive, new socket created fd 12
[1] [INF] [NET] [Mar 30 10:13:38] netcam_connect: re-using socket 12 since keepalive is set.
[1] [INF] [NET] [Mar 30 10:13:38] netcam_read_first_header: Received first header ('HTTP/1.1 200 OK')
[1] [INF] [NET] [Mar 30 10:13:38] netcam_read_first_header: Received first header ('Server: nginx/1.6.2')
[1] [INF] [NET] [Mar 30 10:13:38] netcam_check_content_length: Content-Length -1
[1] [INF] [NET] [Mar 30 10:13:38] netcam_read_first_header: Received first header ('Date: Wed, 30 Mar 2016 14:13:38 GMT')
[1] [INF] [NET] [Mar 30 10:13:38] netcam_read_first_header: Received first header ('Content-Type: image/jpeg')
[1] [INF] [NET] [Mar 30 10:13:38] netcam_check_content_type: Content-type image/jpeg
[1] [NTC] [NET] [Mar 30 10:13:38] netcam_read_first_header: Non-streaming camera (keep-alive not set)
[1] [INF] [NET] [Mar 30 10:13:38] netcam_read_first_header: Received first header ('Connection: close')
[1] [NTC] [NET] [Mar 30 10:13:38] netcam_read_first_header: Found Conn: close header ('Connection: close')
[1] [INF] [NET] [Mar 30 10:13:38] netcam_read_first_header: Received first header ('')
[1] [NTC] [NET] [Mar 30 10:13:38] netcam_setup_html: connected, going on to read image.
[1] [DBG] [NET] [Mar 30 10:13:38] netcam_check_buffsize: expanding buffer from [0/0] to [0/4096] bytes.
[1] [DBG] [NET] [Mar 30 10:13:38] netcam_check_buffsize: expanding buffer from [3974/4096] to [3974/8192] bytes.
[1] [DBG] [NET] [Mar 30 10:13:38] netcam_check_buffsize: expanding buffer from [8070/8192] to [8070/12288] bytes.
[1] [DBG] [NET] [Mar 30 10:13:38] netcam_check_buffsize: expanding buffer from [12166/12288] to [12166/16384] bytes.
[1] [NTC] [NET] [Mar 30 10:13:38] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1] [NTC] [NET] [Mar 30 10:13:38] netcam_read_html_jpeg: leaving netcam connected.
[1] [INF] [NET] [Mar 30 10:13:38] netcam_init_jpeg: jpeg_error 0
[1] [INF] [NET] [Mar 30 10:13:38] netcam_get_dimensions: JFIF_marker NOT PRESENT ret 0
[1] [ALR] [NET] [Mar 30 10:13:38] netcam_handler_loop: Camera handler thread [2] started
[1] [NTC] [ALL] [Mar 30 10:13:38] image_ring_resize: Resizing pre_capture buffer to 1 items
[1] [NTC] [STR] [Mar 30 10:13:38] http_bindsock: motion-stream testing : IPV4 addr: 127.0.0.1 port: 6643
[1] [NTC] [STR] [Mar 30 10:13:38] http_bindsock: motion-stream Bound : IPV4 addr: 127.0.0.1 port: 6643
[1] [NTC] [ALL] [Mar 30 10:13:38] motion_init: Started motion-stream server in port 6643 auth Disabled
[1] [WRN] [NET] [Mar 30 10:13:38] netcam_next: called with no data in buffer
[1] [DBG] [ALL] [Mar 30 10:13:38] motion_loop: vid_return_code 6
[1] [DBG] [NET] [Mar 30 10:13:38] netcam_read_html_jpeg: Calculated frame time 452102.593750
[1] [INF] [NET] [Mar 30 10:13:38] netcam_proc_jpeg: processing jpeg image - content length 0
[1] [DBG] [NET] [Mar 30 10:13:38] netcam_read_html_jpeg: Calculated frame time 458325.625000
[1] [INF] [NET] [Mar 30 10:13:38] netcam_image_conv: jpeg_error 0
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: Label: 2 (0) Size: 122322 (1,0)
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: Label: 3 (1) Size: 21 (52,125)
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: Label: 4 (2) Size: 5710 (444,150)
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: Label: 5 (3) Size: 103 (74,154)
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: Label: 6 (4) Size: 31 (438,161)
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: Label: 7 (5) Size: 102 (247,244)
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: Label: 8 (6) Size: 401 (317,249)
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: Label: 9 (7) Size: 28 (301,258)
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: Label: 10 (8) Size: 1149 (263,259)
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: Label: 11 (9) Size: 639 (95,263)
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: Label: 12 (10) Size: 51 (177,302)
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: Label: 13 (11) Size: 21 (178,316)
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: Label: 14 (12) Size: 217 (107,322)
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: Label: 15 (13) Size: 41 (62,328)
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: Label: 16 (14) Size: 26 (438,343)
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: Label: 17 (15) Size: 36 (78,357)
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: Label: 18 (16) Size: 331 (75,371)
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: Label: 19 (17) Size: 70 (25,374)
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: Label: 20 (18) Size: 72 (52,377)
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: Label: 21 (19) Size: 36 (40,379)
[1] [DBG] [ALL] [Mar 30 10:13:38] alg_labeling: 2 Labels found. Largest connected Area: 122322 Pixel(s). Largest Label: 20
[1] [INF] [NET] [Mar 30 10:13:39] netcam_proc_jpeg: processing jpeg image - content length 0
[1] [INF] [NET] [Mar 30 10:13:39] netcam_init_jpeg: jpeg_error 0
[1] [INF] [NET] [Mar 30 10:13:39] netcam_connect: disconnecting netcam since keep-alive not set.
[1] [INF] [NET] [Mar 30 10:13:39] netcam_connect: with no keepalive, new socket created fd 12
[1] [INF] [NET] [Mar 30 10:13:39] netcam_connect: re-using socket 12 since keepalive is set.
[1] [INF] [NET] [Mar 30 10:13:39] netcam_read_first_header: Received first header ('HTTP/1.1 200 OK')
[1] [INF] [NET] [Mar 30 10:13:39] netcam_read_first_header: Received first header ('Server: nginx/1.6.2')
[1] [INF] [NET] [Mar 30 10:13:39] netcam_check_content_length: Content-Length -1
[1] [INF] [NET] [Mar 30 10:13:39] netcam_read_first_header: Received first header ('Date: Wed, 30 Mar 2016 14:13:39 GMT')
[1] [INF] [NET] [Mar 30 10:13:39] netcam_read_first_header: Received first header ('Content-Type: image/jpeg')
[1] [INF] [NET] [Mar 30 10:13:39] netcam_check_content_type: Content-type image/jpeg
[1] [NTC] [NET] [Mar 30 10:13:39] netcam_read_first_header: Non-streaming camera (keep-alive not set)
[1] [INF] [NET] [Mar 30 10:13:39] netcam_read_first_header: Received first header ('Connection: close')
[1] [NTC] [NET] [Mar 30 10:13:39] netcam_read_first_header: Found Conn: close header ('Connection: close')
[1] [INF] [NET] [Mar 30 10:13:39] netcam_read_first_header: Received first header ('')
[1] [DBG] [NET] [Mar 30 10:13:39] netcam_read_html_jpeg: Calculated frame time 466017.156250
[1] [NTC] [NET] [Mar 30 10:13:39] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
[1] [NTC] [NET] [Mar 30 10:13:39] netcam_read_html_jpeg: leaving netcam connected.
[1] [INF] [NET] [Mar 30 10:13:39] netcam_image_conv: jpeg_error 0
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 2 (0) Size: 32 (97,0)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 3 (1) Size: 93194 (105,0)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 4 (2) Size: 21 (219,10)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 5 (3) Size: 35 (337,10)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 6 (4) Size: 26 (166,11)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 7 (5) Size: 21 (362,14)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 8 (6) Size: 28 (132,15)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 9 (7) Size: 21 (269,15)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 10 (8) Size: 21 (348,15)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 11 (9) Size: 21 (254,17)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 12 (10) Size: 58 (260,19)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 13 (11) Size: 4408 (445,155)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 14 (12) Size: 1941 (129,256)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 15 (13) Size: 3479 (216,339)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 16 (14) Size: 114 (1,349)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 17 (15) Size: 193 (101,352)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 18 (16) Size: 71 (34,353)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 19 (17) Size: 122 (45,353)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 20 (18) Size: 26 (57,357)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 21 (19) Size: 93 (175,364)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 22 (20) Size: 51 (144,370)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: Label: 23 (21) Size: 106 (83,376)
[1] [DBG] [ALL] [Mar 30 10:13:39] alg_labeling: 3 Labels found. Largest connected Area: 93194 Pixel(s). Largest Label: 22
I apologize for the lengthy logs but I am not sure what is relevant.
Posted: Wed Mar 30, 2016 3:11 pm
by midhun
Hello all,
Before I ask my question, this is an awesome piece of code. Great project! Kudos to the devs.
Also I am a total NOOB and my following question might be stupid but please excuse me.
My question is that, to detect the motion, why isnt a Motion Sensor (PIR) being used? That would detect all the movements rights?
Posted: Fri Apr 01, 2016 8:47 am
by btidey
Patrick260284 wrote:Hey guys. Don´t know if this has been asked before, but is it possible to sync the video-stream to an audio device?
There is no built in audio support as such. However, some users have used the macros to trigger a simultaneous recording when a video capture starts and then 'box' the audio during conversion to mp4.
There is a difficulty in getting good sync particularly if the video buffer is used to get pre-trigger capture as the amount of time in the buffer can vary.
Posted: Fri Apr 01, 2016 8:49 am
by btidey
ScheissSchiesser wrote:Hi there. I am hoping somebody can help me clarify an error I get when I set
netcam_keepalive on
This doesn't look like RPi Cam stuff. I think you may have posted your question in the wrong forum.
Posted: Fri Apr 01, 2016 8:54 am
by btidey
midhun wrote:Hello all,
Some users have used a PIR to trigger captures. This is fairly easy to do with a bit of python.
The reasons for using the camera / analysis to do the baseline motion detection are
no extra sensor needed
range of detection
masking of areas to focus detection on where it is needed
flexibility in tweaking detection parameters to suit purpose
Posted: Sun Apr 03, 2016 1:22 pm
by Max1968
Installation script issues
I've been using raspimjpeg on 6 different pi's for more than a year now, and i was very very happy about it. However, with the recent changes to the installation script(s) I'm facing severe issues, and today it completely killed one of my pi's so that i need to reinstall it from scratch. What exactly is the recommended installation procedure / base OS ?
The issues I had was:
- Update failing with some weird message i should commit my changes first (i didnt do any changes) - This happened several times, usually i just removed the raspimjpeg installation with the install script and reinstalled, worked fine after
- Recently completely inconsistent behaviour of the install script. On the same pi running wheezy i did a install followed by an uninstall and a deletion of the git directory. The first time it was installed into subfolder html, the second time it was installed into the root www directory
- Today the installation script tried to do a chown www-data:www-data of my media directory (why is it doing this at all ?), but due to some errors somewhere it did this on / instead, and now not only my pi itself but also some mounted network drives have severe ownership issues... This was on a pi running jessie.
Due to these issues recently i took a look at pikrellcam, so far it looks good. Thus i will do a fresh install of both, and go on with whatever runs more smooth now...
Posted: Sun Apr 03, 2016 5:17 pm
by Max1968
Followup to my previous message "Installation issues"
I just did a clean install of Jessie, and right after this i did the installation using install.sh (previously was using the "old" installation method). Configuration parameters suggested by the script was "html" for the subdirectory which i did not change, so i had raspimjpeg running from ~www-data/html/html.
Thus i removed raspimjpeg again using the "remove.sh" script, reinstalled it again, this time using "" as subdirectory. Now the web interface is working fine (directly in www-data root), but i have a new folder ~root/media/media where the media files are stored. Why was that folder created, especially as it seems still ~www-data/media is used for recordings and such ?
After this i started the update process for testing, using "update.sh", receiving a message "nothing to update" - But then got the configuration dialog followed by an error message "./install.sh: line 125: rpicamdirEsc: command not found" and a request to reboot although nothing was changed, not even installed packages - Why that ?
Posted: Mon Apr 04, 2016 8:08 am
by btidey
Max1968 wrote:Followup to my previous message "Installation issues"
When you do a remove the script tries to preserve any media files that exist by moving them to your home directory. That is why the user media folder was created. It is not used operationally wen you install again. That is always under the /var/www tree.
When you do an update it first tries to fetch any files from the github repository then it runs install.sh. You got the message nothing to update as nothing had changed on github. It still runs the install.sh in case you wan to change something. If you just want to rerun the installer (to change parameters for example then you can just run install.sh direct.
I think the error you got on line 125 was caused by an extra space character in that script. I have corrected that now.
The reboot request is always done at the end of the script just a way of ensuring that all changes are applied OK including things like autostart. Actually most of the time you can just do a ./start.sh to start up at this point and avoid any reboot.
Posted: Mon Apr 04, 2016 8:58 am
by Max1968
OK, thanks - However as stated in my first comment above it did not only try to move existing media files (the folder ~www-data/media in my case is always empty as I move files immediately to a network share) to ~root/media/media, but also tried to change ownership of all files on my pi to www-data:www-data ("chown -R www-data:www-data /") - this should never happen. I guess some variable in the script that should contain the correct path was not set, and thus "/" was used.
Furthermore on the same jessie pi I installed from scratch now i tried to do a "update.sh", results below - I did not do any changes to the install.sh script, thus there seems to be an issue somewhere as well:
root@EGDrivewayCamera:~/RPi_Cam_Web_Interface# ./update.sh
Local : a435a4159d99f20e96a5b6f8aa15c0c4298ffeb0
Remote: 074a9a2fa771fdd6b2d59eee8c95bbe32f74d478
                                                        lqqqqqqqqUpdate messageqqqqqqqqqqqk
                                                        x Commits don't match. We update. x
                                                        x                                 x
                                                        mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
remote: Counting objects: 3, done.
remote: Compressing objects: 100% (3/3), done.
remote: Total 3 (delta 0), reused 0 (delta 0), pack-reused 0
Unpacking objects: 100% (3/3), done.
From https://github.com/silvanmelchior/RPi_Cam_Web_Interface
 * branch            master     -> FETCH_HEAD
   a435a41..074a9a2  master     -> origin/master
Updating a435a41..074a9a2
error: Your local changes to the following files would be overwritten by merge:
        install.sh
Please, commit your changes or stash them before you can merge.
Aborting
*** ABORTED ***
An error occurred. Exiting...
Posted: Mon Apr 04, 2016 11:38 am
by errikos
I am tryind to install it in Jessie Lite, RPi B (the first version 256mb)
After the interface i have the following error
raspimjpeg: no process found
php: no process found
motion: no process found
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
  apache2-bin apache2-data apache2-utils gpac-modules-base liba52-0.7.4 libapr1 libaprutil1 libaprutil1-dbd-sqlite3
  libaprutil1-ldap libasyncns0 libavcodec56 libavdevice55 libavfilter5 libavformat56 libavresample2 libavutil54 libcaca0
  libcdio-cdda1 libcdio-paranoia1 libcdio13 libdc1394-22 libdirectfb-1.2-9 libdrm-amdgpu1 libdrm-freedreno1 libdrm-nouveau2
  libdrm-radeon1 libelf1 libfaad2 libflac8 libfreenect0.2 libgl1-mesa-dri libgl1-mesa-glx libglapi-mesa libglu1-mesa
  libgpac3 libgsm1 libice6 libjack-jackd2-0 libllvm3.7 liblua5.1-0 libmad0 libmp3lame0 libmysqlclient18 libogg0 libonig2
  libopencv-core2.4 libopencv-imgproc2.4 libopenjpeg5 libopus0 liborc-0.4-0 libperl4-corelibs-perl libpulse0 libqdbm14
  libraw1394-11 libschroedinger-1.0-0 libsdl1.2debian libsm6 libsndfile1 libspeex1 libswscale3 libtheora0 libtxc-dxtn-s2tc0
  libva1 libvdpau1 libvorbis0a libvorbisenc2 libvpx1 libx11-xcb1 libx264-142 libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0
  libxcb-present0 libxcb-sync1 libxdamage1 libxfixes3 libxi6 libxshmfence1 libxtst6 libxv1 libxvidcore4 libxxf86vm1 lsof
  mysql-common php5-common php5-json php5-readline ssl-cert va-driver-all vdpau-va-driver x11-common
Suggested packages:
  www-browser apache2-doc apache2-suexec-pristine apache2-suexec-custom php-pear frei0r-plugins jackd2 opus-tools pulseaudio
  libraw1394-doc speex vdpau-driver mysql-client postgresql-client php5-user-cache openssl-blacklist
Recommended packages:
  ffmpeg
  apache2 apache2-bin apache2-data apache2-utils gpac gpac-modules-base liba52-0.7.4 libapache2-mod-php5 libapr1 libaprutil1
  libaprutil1-dbd-sqlite3 libaprutil1-ldap libasyncns0 libav-tools libavcodec56 libavdevice55 libavfilter5 libavformat56
  libavresample2 libavutil54 libcaca0 libcdio-cdda1 libcdio-paranoia1 libcdio13 libdc1394-22 libdirectfb-1.2-9
  libdrm-amdgpu1 libdrm-freedreno1 libdrm-nouveau2 libdrm-radeon1 libelf1 libfaad2 libflac8 libfreenect0.2 libgl1-mesa-dri
  libgl1-mesa-glx libglapi-mesa libglu1-mesa libgpac3 libgsm1 libice6 libjack-jackd2-0 libllvm3.7 liblua5.1-0 libmad0
  libmp3lame0 libmysqlclient18 libogg0 libonig2 libopencv-core2.4 libopencv-imgproc2.4 libopenjpeg5 libopus0 liborc-0.4-0
  libperl4-corelibs-perl libpulse0 libqdbm14 libraw1394-11 libschroedinger-1.0-0 libsdl1.2debian libsm6 libsndfile1
  libspeex1 libswscale3 libtheora0 libtxc-dxtn-s2tc0 libva1 libvdpau1 libvorbis0a libvorbisenc2 libvpx1 libx11-xcb1
  libx264-142 libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0 libxcb-present0 libxcb-sync1 libxdamage1 libxfixes3 libxi6
  libxshmfence1 libxtst6 libxv1 libxvidcore4 libxxf86vm1 lsof motion mysql-common php5 php5-cli php5-common php5-json
  php5-readline ssl-cert va-driver-all vdpau-va-driver x11-common zip
0 upgraded, 99 newly installed, 0 to remove and 90 not upgraded.
Need to get 35.8 MB of archives.
After this operation, 122 MB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
  libice6 libsm6 libxi6 libxtst6 libxfixes3 libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0 libxcb-present0 libxcb-sync1 libxdamage1
  libxxf86vm1 mysql-common libmysqlclient18 libxv1 libgpac3 gpac-modules-base gpac motion
E: There are problems and -y was used without --force-yes
awk: cannot open /etc/apache2/ports.conf (No such file or directory)
sudo: htpasswd: command not found
mv: cannot move ‘etc/apache2/sites-available/raspicam.conf’ to ‘/etc/apache2/sites-available/raspicam.conf’: No such file or d
irectory
ln: failed to create symbolic link ‘/etc/apache2/sites-enabled/raspicam.conf’: No such file or directory
sed: can't read /etc/apache2/conf.d/other-vhosts-access-log: No such file or directory
Failed to restart apache2.service: Unit apache2.service failed to load: No such file or directory.
^CYour custom raspimjpg backed up at /etc/raspimjpeg.bak
sed: can't read /etc/motion/motion.conf: No such file or directory
Can you please help?
Also is there a ready image to use? This would make it even easier...
Thank you !! :) :) :)
Edit:
Retried, I view a blank page when I enter the IP...
./start.sh shows message
Then when I go to the web page, the rpi stops responding...
Edit:
Stupid power supply issues.
Amazing piece of software!!
Thank you!!
Posted: Fri Apr 08, 2016 8:48 am
by errikos
How can you set the duration of the timelapse? it is recording for a predeined time or stopse when syou press timelapse stop?
Posted: Sun Apr 10, 2016 6:01 pm
by erwang01
Does anyone know what ./raspizip.sh does?
Posted: Mon Apr 11, 2016 10:47 am
by btidey
errikos wrote:Hello,
There is a setting for timelapse duration under camera settings on main page.You can also set it using the command 'tv n' where n is the duration in 0.1 sec units; e.g. tv 50 sets interval to 5 seconds.
Posted: Mon Apr 11, 2016 10:50 am
by btidey
erwang01 wrote:Hello,
raspizip.sh is a shell script used by the web server for zipping files together for download.
Live annotation
Posted: Mon Apr 11, 2016 3:03 pm
by Florisjan
Last week I tried upgrading from 6.0.3 to 6.0.23 (the latest at that time.) I use a python script to change the annotation by appending the fifo file with an 'an' line, several times a second. This worked well in .3, but after the update it seems to interfere a lot with the system; very often annotation lines are mixed with 'ca 1 / ca 0' lines, so the motion is often not captured or it does not stop recording and obviously the annotation looks crap.
I have tried this with and without upgrading raspimjpeg (the whole system in fact), so I doubt the problem lies there. Is there a way to check if it is safe to write to the FIFO, or can the annotation be changed in another way? Perhaps a 2nd fifo to feed instructions to the RPI CWI system, so it can pass the instructions along without them colliding with the internal commands?
Thanks in advance,
Fj.
Posted: Mon Apr 11, 2016 5:24 pm
by slabua
Are there any known issues related to the timelapse feature (unless I'm setting it up wrong)?
I have set on the scheduler to enable the timelapse from 8am to 8pm, at 1 frame per minute, but I only get 119 frames saved (2 hours, from 8 to 10am).
Posted: Tue Apr 12, 2016 9:57 am
by btidey
slabua wrote:Are there any known issues related to the timelapse feature (unless I'm setting it up wrong)?
That would seem to imply that something in the period change at 10AM is stopping the time lapse. I am not aware of md 1 or ca commands doing that.
Check the scheduler log around the 10AM time period to see what the activity was. There should be the regular time lapse captures. Is there a time lapse stop there or does the time lapse just stop?
Posted: Tue Apr 12, 2016 8:52 pm
by slabua
Strange, the log says it's keeping recording a frame every minute without issues.
I checked the storage, and the files are indeed there.
The problem seems to be here then?
Screenshot from 2016-04-12 22-48-01 - RPi Cam Control v6.0.37_ rpicam@pi.slbnet Download.png
Screenshot from 2016-04-12 22-48-01 - RPi Cam Control v6.0.37_ rpicam@pi.slbnet Download.png (15.86 KiB) Viewed 6091 times
The conversion seems to apply only to those 119 or 120 frames, leaving the remaining pictures orphaned.
Posted: Wed Apr 13, 2016 1:30 pm
by GammaScorpii
Hi guys,
I'm trying to figure out how the brightness of my shot changes depending on the initial light levels when the camera is switched on. I've tried setting the shutter speed at "50000", exposure to "off", ISO to "100". It doesn't change throughout the shot which is good, but every time I switch the camera off and on again, the brightness of the shot is different.
How can I set it to never change?
Posted: Wed Apr 13, 2016 2:32 pm
by slabua
Another strange thing is this: at some point after 10.00, I manually stopped and restarted the timelapse. It has now continued beyond the 16.00 slot, without interruption. The preview icon currently shows a total of 212 frames (up to the slot of 16.00, indeed).
I think for some reason, at each scheduler slot, something happens with the preview, or the naming of files, though, each image gets saved on disk as per scheduler log.
Posted: Fri Apr 15, 2016 2:00 pm
by ScheissSchiesser
netcam_keepalive on
You're probably right. Do you know of a good support forum for "motion?"
Posted: Fri Apr 15, 2016 2:12 pm
by ScheissSchiesser
Can somebody help me figure out why my motionPars.json file is not getting populated with the motion settings? This causes me to be unable to view/change the motion settings via the web interface.
I am having trouble determining which part of the RPi-Cam-Web-Interface code is responsible for doing that. It is probably something in the motion.php file, but I am having trouble understanding it. It might help to debug this problem if I could figure that out.
As it stands now, motionPars.json is an empty file. Bringing up the motion.php page via clicking on the "motion settings" button shows a blank page (no table), presumably because the motionPars.json file contains no data.
Any help/hints would be appreciated.
