Peted
Re: RPi Cam Web Interface
Mon Jun 02, 2014 3:24 pm
I will be mounting my Pi and Camera outside and want it to be as hidden as possible, does any one know how i can turn off the red light on the camera?
Cheers
Pete
ludespeedny
Mon Jun 02, 2014 3:26 pm
If you edit the config.txt file and put this in it should work.
disable_camera_led=1
Peted
Mon Jun 02, 2014 3:34 pm
Thanks, that worked.
troelssiggaard
Mon Jun 02, 2014 8:47 pm
Is it possible to rename / rearrange the video file name from motion detection? I would like to have the file's date be in: DD-MM-YYYY instead of the YYYY-MM-DD now.
Thanks in advance :)
Update: Never mind, I figured it out. Had to recompile RaspiMJPEG on the Pi with the edited time/date in the C code.
Last edited by troelssiggaard on Wed Jun 04, 2014 10:54 am, edited 1 time in total.
jussi24
Tue Jun 03, 2014 6:24 am
Is this thread dead?
I'm only reading newbie's problems here for weeks now. Where are silvanmelchior and james? Did the development of the project stop? Or what's happening in the backend? Maybe the efforts headed to another project/thread as it has been with mjpeg-streamer towards raspimjpeg?
Thanks,
jussi
T800
Tue Jun 03, 2014 10:36 am
I've had this set up for a few months now and it works very well. The only problem I'm having is even though my settings are for 1080p, when I set them in the web GUI and press 'OK' the settings disappear. The image that the camera displays is much smaller. When I run the image through MediaInfo it says: 512x288.
Is there anyway I can force it?
I had a look in the raspimjpeg config and it's set on 1080p for video although there is a line that says 512 just under preview. I changed this to 1920 and it never made every difference.
Am I doing something wrong?
poing
Tue Jun 03, 2014 11:45 am
IIRC you can change the displayed preview size in /etc/rc.local.
0lly
Tue Jun 03, 2014 11:48 am
T800 wrote: I changed this to 1920 and it never made every difference.
Try 1024 or 1280 and Reboot ! after this change
Its working.
rahlquist
Tue Jun 03, 2014 2:36 pm
Is there any way we could get some sort of a heartbeat indicator on screen? Occasionally pi may lockup and I cant tell looking at the screen. Any thoughts?
punacmc
Tue Jun 03, 2014 3:30 pm
First off, what a great program. Followed the instructions at the beginning of this thread and it worked the first time. I have two questions.
1. If I use some of the web page links or buttons, the pi locks up. I have to unplug to reboot. Anybody have that issue and know how to fix it?
2. Where are the videos saved? I would like to be able to FTP into and download the videos to a separate device like my phone.
ludespeedny
Tue Jun 03, 2014 3:40 pm
Possibly power issue? I had a problem with that as well. Also try reverting to different firmware. There is a post about that back a few pages.
The files are saved in /var/www/media, which you could redirect to a different location if you want.
mad-hatter
Tue Jun 03, 2014 7:02 pm
Warning!
Somebody is sending scam emails, purporting to come from this thread. Enclosed the message source.
Look at the view and unsubscribe link addresses at the bottom and the RULES_HIT, they don't match other forum emails.
My AV software marked it as spam with a don't open warning.
Regards
Delivered-To: I'veChangedMyAddress@ntlworld.com
Received: by 10.194.56.131 with SMTP id a3csp50317wjq;
        Tue, 3 Jun 2014 08:30:40 -0700 (PDT)
X-Received: by 10.180.100.41 with SMTP id ev9mr34259518wib.22.1401809439197;
        Tue, 03 Jun 2014 08:30:39 -0700 (PDT)
Return-Path: <www-data@raspberrypi.org>
Received: from haggis.mythic-beasts.com (haggis.mythic-beasts.com. [2a00:1098:0:86:1000:0:2:1])
        by mx.google.com with ESMTPS id x2si29138613wif.58.2014.06.03.08.30.38
        for <I'veChangedMyAddress@ntlworld.com>
        (version=TLSv1.2 cipher=RC4-SHA bits=128/128);
Received-SPF: none (google.com: www-data@raspberrypi.org does not designate permitted sender hosts) client-ip=2a00:1098:0:86:1000:0:2:1;
Authentication-Results: mx.google.com;
       spf=neutral (google.com: www-data@raspberrypi.org does not designate permitted sender hosts) smtp.mail=www-data@raspberrypi.org
Received: from [2a00:1098:0:80:1000:13:0:2] (port=37144 helo=www.raspberrypi.org)
	by haggis.mythic-beasts.com with esmtps (TLS1.0:RSA_AES_256_CBC_SHA1:256)
	(Exim 4.80)
	(envelope-from <www-data@raspberrypi.org>)
	id 1Wrqfe-0000et-AF
	for I'veChangedMyAddress@ntlworld.com; Tue, 03 Jun 2014 16:30:38 +0100
Received: from www-data by www.raspberrypi.org with local (Exim 4.72)
	(envelope-from <www-data@00-25-90-28-bc-aa>)
	id 1Wrqfe-0001Dt-2O
To: =?UTF-8?B?bWFkLWhhdHRlcg==?= <I'veChangedMyAddress@ntlworld.com>
Subject: =?UTF-8?B?VG9waWMgcmVwbHkgbm90aWZpY2F0aW9uIC0gIlJQaSBDYW0gV2ViIEludGVy?= =?UTF-8?B?ZmFjZSI=?=
X-PHP-Originating-Script: 33:functions_messenger.php
Reply-To: <forum@raspberrypi.org>
Sender: <forum@raspberrypi.org>
MIME-Version: 1.0
Message-ID: <55a2acec540236a0819609e0bac9dd9b@www.raspberrypi.org>
Date: Tue, 03 Jun 2014 16:30:35 +0100
Content-Type: text/plain; charset=UTF-8
Content-Transfer-Encoding: 8bit
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: phpBB3
X-MimeOLE: phpBB3
X-phpBB-Origin: phpbb://93.93.128.176/forums
X-Antivirus: AVG for E-mail 2014.0.4592 [3955/7614]
X-AVG-ID: ID5BF766B2-51DE31AC
X-Antispam: NO; Spamcatcher 6.5.17. Score 50
X-AVG-Antispam-Info: 50,3,0,0fc197c8e938c693,d41d8cd98f00b204,
	forum@raspberrypi.org,I'veChangedMyAddress@ntlworld.com,
	RULES_HIT:41:46:150:152:355:379:493:539:540:541:543:836:882:967:978:988:989:1277:1311:1313:1314:1345:1437:1515:1516:1518:1534:1541:1593:1594:1711:1730:1747:1777:1792:2106:2198:2199:2393:2525:2566:2682:2685:2693:2859:2902:2933:2937:2939:2942:2945:2947:2951:2954:3022:3138:3139:3140:3141:3142:3352:3865:3866:3867:3873:3934:3936:3938:3941:3944:3947:3950:3953:3956:3959:4362:4423:5007:6248:6261:7223:7974:8599:8828:8987:9025:9038:9388:9394:10004:10400:11216:11218:11232:11253:11473:11638:11639:11658:11984:12043:12292:12517:12519:12555:12679:12682:12740:13025:13069:13071:13161:13229:13255:13311:13357:13845:13894:14094:14096,
	0,RBL:none,CacheIP:none,Bayesian:0.5,0.5,0.5,Netcheck:none,DomainCache:0,
	MSF:not bulk,SPF:,MSBL:0,DNSBL:neutral,
	Custom_rules:0:0:0
Hello mad-hatter,
You are receiving this notification because you are watching the topic,
"RPi Cam Web Interface" at "Raspberry Pi". This topic has received a reply
by punacmc since your last visit. You can use the following link to view
the replies made, no more notifications will be sent until you visit the
topic.
If you want to view the newest post made since your last visit, click the
following link:
http://93.93.128.176/forums/viewtopic.php?f=43&t=63276&p=559450&e=559450
If you want to view the topic, click the following link:
If you want to view the forum, click the following link:
http://93.93.128.176/forums/viewforum.php?f=43
If you no longer wish to watch this topic you can either click the
"Unsubscribe topic" link found at the bottom of the topic above, or by
clicking the following link:
http://93.93.128.176/forums/viewtopic.php?uid=12033&f=43&t=63276&unwatch=topic
Thanks, The Management
cyrano
Tue Jun 03, 2014 9:06 pm
Smells more like a wrong phpBB config.
93.93.128.176 is not the regular forum, but seems to run a complete copy. It seems to belong to the foundation's hosting (Mythic Beasts). Development server?
poing
Tue Jun 03, 2014 10:24 pm
Yes, if it would be a 'scam' email there should be some 'scamming' inside somewhere... Best send a PM to a moderator, don't panic.
mad-hatter
Wed Jun 04, 2014 5:12 pm
Thanks for your comments on scam mail.
I'm not panicking, and not paranoid, because deep down I know they are all out to get me.
Regards
jarrah31
Wed Jun 04, 2014 7:13 pm
punacmc wrote:First off, what a great program. Followed the instructions at the beginning of this thread and it worked the first time. I have two questions.
1. Something doesn't play nice with the latest camera firmware and raspimjpeg, so run the command from the wiki link below to go back to a slightly older version to make the buttons work again: http://elinux.org/RPi-Cam-Web-Interface ... a_Firmware
jarrah31
Wed Jun 04, 2014 7:25 pm
jussi24 wrote:Is this thread dead?
Thanks,
jussi
I think Silvan has reached a point where he's happy with the code. He's said a few times early on that's he's very busy and doesn't have much time to work on this project I'm afraid. Silvan has also tried to fix the problem with the latest camera firmware, spending most of a day without luck.
In reality I think we just need someone who's interested in developing it further. I know it could do with a really good web developer to spruce up the interface as well, so he's put all the code on github for others to edit who have the time. :)
jarrah31
Wed Jun 04, 2014 7:37 pm
T800 wrote: I had a look in the raspimjpeg config and it's set on 1080p for video although there is a line that says 512 just under preview. I changed this to 1920 and it never made every difference.
I suspect 1920 is too large - I change this to 800 for example (to make 800x600) on mine and it makes the preview window larger. (you have to stop and start the process for it to take effect)
/RPi_Cam_Web_Interface_Installer.sh stop
/RPi_Cam_Web_Interface_Installer.sh start
Also bear in mind that the displayed video stream is just a preview - when you take a picture or record a video using the buttons, it does them in full resolution as determined elsewhere in the /etc/raspimjpeg config file.
punacmc
Thu Jun 05, 2014 1:13 am
I increased the power to the pi and got better results with the web interface. I may still have to go back and test with the previous firmware. next question. How can you view the video? most players will not play the files. My S4 will but others can not. I would like to convert with my phone if possible but can also handle doing it on the pi.
T800
Thu Jun 05, 2014 9:36 am
I think I'm going wrong because the CCTV application that records jpg images is capturing http://192.168.0.191/cam.jpg
So this means I'm capturing the preview image?
How can set this program up so it starts automatically when it boots and produces a HD image (720p or 1080p) on a link like above?
redhat9lin
Fri Jun 06, 2014 1:22 am
I was trying to clone from Github, but github is asking me for a username/password. Do I have to register to github before I can clone this?
redhat9lin
Fri Jun 06, 2014 9:51 am
Please, any help why github is asking me for username/password while trying to clone?
0lly
Fri Jun 06, 2014 12:12 pm
username/password are not needed
use
git clone https://github.com/silvanmelchior/RPi_Cam_Web_Interface.git
redhat9lin
Fri Jun 06, 2014 1:01 pm
I tried 2 freshly installed Raspbian on two different SD cards, but still asking me for username/password.
If I copy the files manually from Github, where should I put them on RPi?
0lly
Fri Jun 06, 2014 1:34 pm
put all files to
/home/pi/RPi_Cam_Web_Interface
Return to “Camera board”
