IntelliTom
raspivid stream times out
Thu Dec 05, 2013 11:26 pm
Hi Guys
I am using the rpi camera for a live monitoring stream for a piece of machinery. I need to be able to log in once an hour or so and check everything is ok.
I've got a working stream set up. But for some reason it times out after about 1 hour. Here is the command I am using:
raspivid -o - -t 9999999 -w 800 -h 600 -fps 28  --hflip | cvlc -vvv stream:///dev/std$
I though the 9999999 meant that it would be infinite? Or maybe I got that wrong?
If I do PS X it look like it's still running, but I can't connect to it
 2717 ?        Sl    66:27 /usr/bin/vlc -I dummy -vvv stream:///dev/stdin --sout #standard{access=http,mux=ts,dst=:8888} :demux=h264
 2765 ?        Sl    78:41 /usr/bin/vlc -I dummy -vvv stream:///dev/stdin --sout #standard{access=http,mux=ts,dst=:8888} :demux=h264
I usually kill the PID and re-run the raspivid command. But it's annoying that I have to do that each time I log in.
Any ideas?
ethanol100
Re: raspivid stream times out
Fri Dec 06, 2013 2:02 am
You can set -t 0 to disable the timeout.
IntelliTom
Fri Dec 06, 2013 11:25 am
Cool, thanks. Simple ;)
Return to “Camera board”
