raspivid --timeout 0 not working
Posted: Tue Oct 22, 2013 4:42 pm
by SnowLeopard
raspivid --timeout 0 -o test.h264 no longer records indefinitely, but rather creates a 19 byte file and exists immediately.
Re: raspivid --timeout 0 not working
Posted: Wed Oct 23, 2013 11:04 am
by jamesh
I can see the problem, mainly hadn't realised anyone would want to do that given the other options. I'll sort it out.
Posted: Wed Oct 23, 2013 2:10 pm
by towolf
This option was highly appreciated. We had a lot of talk months ago about what the maximum milliseconds are that fit into a 32-bit integer.
Then finally someone came to send a pull request (actually more than one person did) to make -t 0 indefinite operation. Now it's clobbered again.
Wasn't there something about a slow motion train wreck?
Posted: Wed Oct 23, 2013 2:14 pm
by jamesh
towolf wrote:This option was highly appreciated. We had a lot of talk months ago about what the maximum milliseconds are that fit into a 32-bit unsigned integer.
Ah, I presume you have never made a mistake in your own code. Must be great to be perfect. How do you manage to get your head through the door?
You really are a most unpleasant and ungrateful person. Note to self, if towolf puts in a change request, ignore it forever.
Posted: Wed Oct 23, 2013 2:31 pm
by towolf
Well, I'm now backtracking through git (which you called a slow motion train wreck) to find a last-known-good commit. And doing that takes a lot of time.
Meanwhile (waiting for compiles) I took the time to notify you that the recent changes had side effects, since you said you were not aware that anybody would use this feature. Now you know. But you call me ungrateful.
And anyway, ignoring the threats which we had already, I defer to Linus Torvalds (incidentally the author of git), who says that unnecessary politeness hinders technical progress on the internet.
Posted: Wed Oct 23, 2013 3:02 pm
by jamesh
SnowLeopard wrote:raspivid --timeout 0 -o test.h264 no longer records indefinitely, but rather creates a 19 byte file and exists immediately.
OK, have fixed the code and seems to work OK now.
I've pushed to my github, which will also include setting the max possible bitrate to 25Mbits/s to stop the hard lockup reported at higher values (no point going higher than that anyway 1080p, a since 17Mbits/s is regarded as the best compromise of size vs quality), and setting the shutter speed every frame in a multi frame capture.
Also updates the docs.
So if people can try the bug_fixes branch and give it a bit of a test that would be much appreciated.
Posted: Wed Oct 23, 2013 4:35 pm
by poing
The images remain the same brightness now when using -tl, but I get:
raspistill -t 60000 -tl 1000 -w 250 -h 250 -ss 345000 -ISO 800 -o img/test%d.jpg
mmal: Skipping frame 3 to restart at frame 4
mmal: Skipping frame 5 to restart at frame 6
mmal: Skipping frame 8 to restart at frame 9
mmal: Skipping frame 10 to restart at frame 11
mmal: Skipping frame 12 to restart at frame 13
mmal: Skipping frame 14 to restart at frame 15
mmal: Skipping frame 16 to restart at frame 17
mmal: Skipping frame 18 to restart at frame 19
In the past I never got the frame skipping IIRC, even with full res and also -tl 1000.
Posted: Wed Oct 23, 2013 4:37 pm
by SnowLeopard
  • 25 mbit/s fix: works. Using a higher value lowers it to 25mbit. Although I would have expected exiting with an error about using a value out of range (or at least a stderr warning). I fully expect someone to get confused by requesting >25mbit and not being warned the value is out of range, and not understanding why videos never have higher bw. The only way you see the value is overridden is running with '-v'
  • shutter speed: works. raspistill -n -v -tl 500 -ex sports -ss 1000 -o shut1000-%d.jpg gave 6 images with same exif exposure time and look all the same to the eye
  • timeout: does not work. raspivid exits gracefully after 10 seconds when "-t 0" is used. Changing the vcos_sleep(10000) to 5000 at line 1156 makes it exit after 5 seconds. Not sure what the fix is.
Posted: Wed Oct 23, 2013 4:54 pm
by SnowLeopard
poing wrote:In the past I never got the frame skipping IIRC, even with full res and also -tl 1000.
I've been getting these skipping frame messages since playing with the shutter speed option. If you check "vcdbg msg log" (or with -f) you'll get matching ca_process_frame_frames: metadata_image NULL messages appearing.
I am getting mmal: mmal_vll_load: could not load VLL 'videnc.vll': each time I run raspivid though. I just rebooted to be sure it was not provoked by an unclean crash or something, and the mmal message appeared right after raspivid said "Starting video capture", and a new mmal message is generated everytime raspivid is run.
The raw recorded video plays fine in vlc, so not sure what's going on there.
Posted: Wed Oct 23, 2013 4:59 pm
by jamesh
Consider that if you mess arund with shutter speed, but also are trying to hit 30fps (which needs a minimum shutter speed of 33ms) you may start to drop frames. They are highly interrelated.
Posted: Sat Oct 26, 2013 5:50 am
by KLL
hallo, a beginner question:
also for raspistill i tried the t 0 / run forever / option and -k and -l
and they not work as described in the github manual.
pls. help, what are the steps to get the new version?
Posted: Sat Oct 26, 2013 8:42 am
by jamesh
KLL wrote:hallo, a beginner question:
Try
sudo rpi-update
Posted: Sun Oct 27, 2013 1:57 am
by KLL
thanks very much, i did not know about that one,
the apt-get update / upgrade i did a lot.
-l , -k, -t already tested. good service!
as my system ( SD, new noobs.. ) is only a week old
looks like that is recommended with every new installation.
Posted: Thu Jan 16, 2014 12:01 pm
by mentar
Thanks for putting the feature back in, it's necessary for streaming, which is working well indeed :)
