karlkiste
Fiddling on memory split with camera enabled
Thu Oct 17, 2013 8:52 am
Hi!
I've just learned that enabling the camera module on raspbian will set the GPU memory to 128MB. I have not found, however, how this is done. Is it hardcoded in start_x.elf?
I'd like to try lower values, as I only need the preview function and neither video nor pictures saved or encoded. Maybe even dynamic memory split if possible.
Where can I find the value to change?
Thanks!
RaTTuS
Contact: Twitter YouTube
Re: Fiddling on memory split with camera enabled
Thu Oct 17, 2013 8:54 am
look in /boot/config.txt
gpu_mem
Covfefe
karlkiste
Thu Oct 17, 2013 9:30 am
Yes, I've set
gpu_mem=16 # and 32, 64
I'm still missing 128MB from ARM memory.
It's a Model A, so I'd really like to save some bytes there.
----------EDIT-------------------
Oooops, sorry! No idea what I did before, now I've tried again, and the split value changes. Sorry for the noise.
P.S.: For running raspistill in preview-only mode, the required gpu_ram depends on the screen resolution. 64MB is sufficient for 1080p.
Return to “Camera board”
