kartook
Raspberry Pi camera modul surveillance camera
Sun Oct 13, 2013 6:28 pm
Hi all ,
i want to make my Raspberry Pi as low-cost HD surveillance camera. i am using Raspberry Pi camera module. Unfortunately i am getting error message below .Since i am newbie looking for experts help to make this happen .
version info :
[email protected] ~ $ uname -a
Linux raspberrypi 3.6.11+ #538 PREEMPT Fri Aug 30 20:42:08 BST 2013 armv6l GNU/Linux
[email protected] ~ $ ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:9f:b1:0b
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
collisions:0 txqueuelen:0
wlan0 Link encap:Ethernet HWaddr 00:0f:13:38:18:34
inet addr:192.168.43.136 Bcast:192.168.43.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:10107 errors:0 dropped:0 overruns:0 frame:0
TX packets:8778 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:4971003 (4.7 MiB) TX bytes:3751448 (3.5 MiB)
[email protected] ~ $ nano /etc/default/motion
start_motion_daemon=yes
[email protected] ~/packs $
[email protected] ~/packs $ ./motion -n -c motion-mmalcam.conf
[-1242586272] [NTC] [ALL] conf_load: Processing thread 0 - config file motion-mmalcam.conf
[-1242586272] [NTC] [ALL] motion_startup: Motion mmaltest Started
[-1242586272] [NTC] [ALL] motion_startup: Logging to file (/home/pi/motion.log)
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
[email protected] ~ $ tail -f /home/pi/motion.log
[1] [ALR] [VID] [Oct 13 18:13:08] mmalcam_start: MMAL Camera using video capture
[1] [ERR] [VID] [Oct 13 18:13:08] camera component couldn't be enabled
[1] [ALR] [VID] [Oct 13 18:13:08] MMAL Camera cleanup
[1] [WRN] [ALL] [Oct 13 18:13:08] motion_init: Could not fetch initial image from camera Motion continues using width and height from config file(s)
[1] [CRT] [STR] [Oct 13 18:13:08] http_bindsock: motion-stream bind() failed, retrying:
[1] [ERR] [STR] [Oct 13 18:13:08] http_bindsock: motion-stream socket failed, retrying:
[1] [CRT] [STR] [Oct 13 18:13:08] http_bindsock: motion-stream creating socket/bind ERROR:
[1] [ERR] [ALL] [Oct 13 18:13:08] motion_init: Problem enabling motion-stream server in port 8081:
[1] [ALR] [VID] [Oct 13 18:13:09] mmalcam_start: MMAL Camera thread starting... for camera (vc.ril.camera) of 1024 x 576 at 2 fps
[1] [ALR] [VID] [Oct 13 18:13:09] mmalcam_start: MMAL Camera using video capture
[1] [ERR] [VID] [Oct 13 18:13:09] camera component couldn't be enabled
[1] [ALR] [VID] [Oct 13 18:13:09] MMAL Camera cleanup
[1] [WRN] [ALL] [Oct 13 18:13:09] motion_init: Could not fetch initial image from camera Motion continues using width and height from config file(s)
ka~
Re: Raspberry Pi camera modul surveillance camera
Sun Oct 13, 2013 7:36 pm
What output does
give?
If ENOSPC, have you set the GPUmemory split correctly? Have you checked all the cables to make sure they are well seated? Are you running the very latest Raspbian?
madrian
Mon Oct 14, 2013 10:14 pm
I really hope that there will be sometime a true video surveillance app for the RPi, like this:
http://commergate.dnsalias.com:97/doc/page/main.asp
demo1/demo1
Live View and record at the same time.
Mon Oct 14, 2013 10:35 pm
Have you guys seen the front page post? Also, there are further links in the comments to other projects.
kartook
Sat Oct 26, 2013 4:13 pm
When i run this command it shows below message . i am trying to access my onboard raspberry PI inbuilt cam through Web.System running new update and upgrade ..
Distro info
[email protected] ~ $ ps aux | grep raspi
pi 2340 0.0 0.2 3540 808 pts/0 S+ 16:13 0:00 grep --color=auto raspi
raspistill Camera App v1.2
Time delay 0, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Link to latest frame enabled no
Full resolution preview No
Preview Yes, Full screen Yes
Preview window 0,0,1024,768
Opacity 255
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 400, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
Camera component done
Encoder component done
Starting component connection stage
Connecting camera stills port to encoder input port
Enabling encoder output port
Starting capture 1
Finished capture 1
Closing down
Close down completed, all components disconnected, disabled and destroyed
[email protected] ~ $ sudo vcdbg log msg
001512.153: HDMI:Setting property pixel encoding to Default
001512.177: HDMI:Setting property pixel clock type to PAL
001512.200: HDMI:Setting property content type flag to No data
001512.222: HDMI:Setting property fuzzy format match to enabled
001513.173: hdmi: HDMI:>>>>>>>>>>>>>Rx sensed, reading EDID<<<<<<<<<<<<<
001513.637: hdmi: HDMI:EDID error reading EDID block 0 attempt 0
001514.905: hdmi: HDMI:EDID error reading EDID block 0 attempt 1
001516.169: hdmi: HDMI:EDID error reading EDID block 0 attempt 2
001517.432: hdmi: HDMI:EDID error reading EDID block 0 attempt 3
001518.695: hdmi: HDMI:EDID error reading EDID block 0 attempt 4
001519.958: hdmi: HDMI:EDID error reading EDID block 0 attempt 5
001521.221: hdmi: HDMI:EDID error reading EDID block 0 attempt 6
001522.484: hdmi: HDMI:EDID error reading EDID block 0 attempt 7
001523.747: hdmi: HDMI:EDID error reading EDID block 0 attempt 8
001525.010: hdmi: HDMI:EDID error reading EDID block 0 attempt 9
001526.036: hdmi: HDMI:EDID giving up on reading EDID block 0
001526.079: hdmi: HDMI: No lookup table for resolution group 0
001526.096: hdmi: HDMI: hotplug attached with DVI support
001526.163: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
001526.611: hdmi: HDMI:EDID error reading EDID block 0 attempt 0
001527.872: hdmi: HDMI:EDID error reading EDID block 0 attempt 1
001529.133: hdmi: HDMI:EDID error reading EDID block 0 attempt 2
001530.394: hdmi: HDMI:EDID error reading EDID block 0 attempt 3
001531.655: hdmi: HDMI:EDID error reading EDID block 0 attempt 4
001532.916: hdmi: HDMI:EDID error reading EDID block 0 attempt 5
001534.177: hdmi: HDMI:EDID error reading EDID block 0 attempt 6
001535.438: hdmi: HDMI:EDID error reading EDID block 0 attempt 7
001536.700: hdmi: HDMI:EDID error reading EDID block 0 attempt 8
001537.961: hdmi: HDMI:EDID error reading EDID block 0 attempt 9
001538.985: hdmi: HDMI:EDID giving up on reading EDID block 0
001541.583: hdmi: HDMI: power_on to CEA mode 720p60
001543.740: hdmi: HDMI: Action callback added to queue to happen at frame 0
003545.864: vchiq_core: vchiq_init_state: slot_zero = 0x57000000, is_master = 1
003550.464: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
003552.926: cma: cma_hwm is zero - disabling cma service
003554.955: TV service:host side not connected, dropping notification 0x00000002, 0x00000001, 0x00000004
kartook
Sat Oct 26, 2013 5:47 pm
jamesh wrote:What output does
give?
My motion config
http://pastebin.com/42FKm6cv
Time delay 5000, Raw no
Opacity 255
Starting capture 1
Finished capture 1
Closing down
Return to “Camera board”
