bingo
Streaming from camera rpi with necat and mplayer
Sat Aug 10, 2013 3:22 pm
Hi
After trying the instructions from the camera board documentation http://www.raspberrypi.org/archives/tag/camera-board I can't view the stream of my camera RPi.
Bellow is the description of all my tests
- I installed netcat on my Raspberry Pi
sudo apt-get install mplayer netcat
- I installed netcat mplayer mplayer-svn-36251.7z and netcat nc111nt.zip on my computer Windows 7 - 64 bits
- On my PC I opened the command line interpreter cmd.exe and start to reading the stream with
c:\netcat\nc.exe -L -p 5001 | c:\mplayer\mplayer.exe -fps 31 -cache 1024 -
Abnormal output return to the command prompt
- I tried Netcat alone with the command
The safety windows appear to ask autorisation for nc.exe. I validated. Next I open a second command line interpreter cmd.exe and type telnet 192.168.0.5 5001. Bi-directional connection work fine
- Start again to read the stream and the response is:
MPlayer sherpya-r35968+39eaacf-4.6 (C) 2000-2013 MPlayer Team
Playing
Reading from stdin
Cachefill: 0.00% (0 bytes)
Seem to be work fine
- I tried MPlayer alone with the command
c:\mplayer.exe -fps 31 video.h264 (previously recorder with the command: raspivid -o video.h264 -t 10000)
The display is fine
- I started the camera board with
 raspivid -t 10000 -o – | nc 192.168.0.5 5001
The red LED is ON during 10 s but MPlayed never launches the window, the stream is not displayed
I suspected that my softwares Netcat and/or MPlayer is not suitable with my Windows 7 - 64 bits
I found this topic http://www.recantha.co.uk/blog/?p=4128 but my CPU is inter Core(TM) i7
I dowloaded MPlayer MPUI 1.2.38 (march 18th 2013) http://www.x64bitdownload.com/downloads ... edxpn.html and netcat 1.12 http://eternallybored.org/misc/netcat/
I started again to read the stream with the command
c:\netcat\nc64.exe -L -p 5001 | c:\mplayer\mplayer.exe -vo direct3d -fps 31 -cache 1024 -
But the stream is still not displayed, MPlayer never launched
I am stuck
Can you have a idea why these basics command don't work ?
Thanks for your help
bingo
Re: Streaming from camera rpi with necat and mplayer
Tue Aug 13, 2013 12:56 am
The option -L or -l doesn't change nothing juste to close the connection at the end of the time out
It works with ffmeg and crtmpserver but I don't understand why the basic command doesn't work ?
bingo
Wed Aug 14, 2013 1:33 am
I tried with -L or with -l
Now I did without -l
 c:\netcat\nc,exe -p 5001
But same result: MPlayer never launched
Without the option -l netcat exit quickly
option -l specify that nc should listen for an incoming connection, option -L est available under Windows this option will restart Netcat with the same command line when the connection is terminated.
I read also the incompatibility under Linux of the options -l and -p but in this case the syntax proposed is
is nc -l 5001
I also tried but no success
I use netcat 1.12 for NT and I tested successfully many commands of the manual using the syntax nc -l -p XX
hukuzatuna
Sat Aug 24, 2013 6:57 pm
I think there are option mismatches on various versions of netcat. The command that worked for me was
nc -l 5001 | mplayer -fps 31 -cache 1024 -
Which is very similar to the camera documentation. The command on the RPi was
raspivid -hf -vf -t 99999 -o - | nc 192.168.0.6 5001
Now, I did have to fuss with it for a while because I cut and pasted the command initially, and finally noticed some of the hyphens were "extra long," perhaps a unicode translation problem. When I typed the commands over by hand, all was well.
Cheers,
Phil
bingo
Sun Aug 25, 2013 12:29 am
Thank for your help
Unfortunately it doesn't work (I didn't use copy and paste)
I had already tried this command with out the -p option. My netcat exiting very quickly if I don't use l'option -p
When a start the commande raspivid the red light is ON but in the Windows side the cache fill remains to 0.00% (0 bytes)
It works with the rmtp http://www.raspberrypi.org/phpBB3/viewt ... 43&t=45368 but I would like what is wrong.
Netcat, mplayer, Windows 7 64 bit, .... ?
I tried with my laptop but same issue (also Windows 7 64 bits
spudnix
Mon Aug 26, 2013 6:32 am
Received my new RPi Camera module and struggled with this over the weekend.
The CORRECT commands for Mac OS X are
Mac (10.8.4): $ nc -l PORT | mplayer -fps 31 -cache 1024 -
RPi (3.6.11+ #474): $ raspivid -t 999999 -o - | nc CLIENT_IP_ADDR PORT
NOTE: There is no -p switch used on the Mac Client as noted in the documentation.
Example:
Step 1 on Mac OS X (IP_ADDR=192.168.1.9):
Listen with netcat on port 5001 and stream captured content to mplayer.
$ nc -l 5001 | mplayer -fps 31 -cache 1024 -
Step 2 on RaspberryPi:
Create stream with raspivid and send with netcat to 192.168.1.9 on port 5001
$ raspivid -t 999999 -o - | nc 192.168.1.9 5001
"There is no dark side in the moon, really. Matter of fact, it's all dark."
bingo
Mon Aug 26, 2013 6:25 pm
Thanks for your information
But this topic is for Windows 7 - 64 bits
The -p options is needed for Windows, if not netcat exit promptly
but the stream is not caught
Rusty14
Sat Sep 28, 2013 1:07 am
hey, so i am trying to stream video to my Mac from my pi. the problem is every time I run netcat it just exits immediately.
Im putting in the code :
nc -l -p 5001 | mplayer -fps 31 -cache 1024 -
and I have tried a few variations, but every time it exits right away like such:
Taylors-MacBook-Pro:~ taylorlee$ nc -l -p 5001 | mplayer -fps 31 -cache 1024 -
usage: nc [-46AcCDdFhklnrtUuvz] [-K tc] [-b boundif] [-i interval] [-p source_port]
	  [-s source_ip_address] [-w timeout] [-X proxy_version]
	  [-x proxy_address[:port]] [hostname] [port[s]]
MPlayer 1.1-4.2.1 (C) 2000-2012 MPlayer Team
Playing -.
Reading from stdin...
Cache fill:  0.00% (0 bytes)
libavformat version 54.6.101 (internal)
Exiting... (End of file)
Does any one have any idea whats going on? Ive tried updating NC and mplayer via brew and im up to date.
mengs
Fri Oct 04, 2013 12:49 am
I am very new to RPi and linux system. I have the problem as I run the following on my mac.
Many thanks!
Daniel_L
Mon Dec 02, 2013 2:08 pm
I have the same issue as the original post, and I have followed the same path to solve it as described.
RPi with camera, trying to stream to Win 7 64 bit i5. Cache is filling up, so the stream is received but the Mplayer is not started. But if a stop the stream from RPi with ctrl-c, a window appears on the laptop playing the video... but I want to see it as it is streaming of course.
Any ideas?
Return to “Camera board”
