For example, I type in:
raspistill -f
The only way to exit this is to ctrl+c in the terminal, and whilst this gives me my terminal back, the red light stays on for the camera board.
Not sure what to do now, no hints so far found on this forum. I have been doing the usual touch radiator before I touch any of the components, so shouldn't be that. The camera was delivered in a crushed box, but if that was an issue, then it wouldn't have worked for the first day.
Also to note, I am using NOOBS and have just completely reset it (to Raspbian) and it still wont work.
Are there any tests I can run to see what is causing all the issues?
Thankyou for any advice you can give to solve this annoying bug,
Dan
