talkeasy
start camera stream from web page
Sun Jun 09, 2013 11:24 am
Hi all
I would like to start a pi camera stream via a webpage and then view the stream via VLC but seem to have run into a permissions issue, I think.
So far I have reused this code to start the stream:
raspivid -o - -t 999991 -hf -w 640 -h 360 -fps 25|cvlc -vvv stream:///dev/stdin --sout '#standard{access=http,mux=ts,dst=:8090}' :demux=h264
It works fine from the SSH command line as user pi, and from a inside shell script started from the command line, and from a php script which calls the shell script, again from the command line as user pi.
The problem arises when I try to run the php script from /var/www. Other scripts work fine from the directory, but after some digging around it seems that VLC will not run as root due a to restriction put in place by the developers for security issues, and also it seems, as www-data.
Can anyone figure out how I could resolve this conundrum, please?
Thanks.
MmmPi
Re: start camera stream from web page
Mon Jun 10, 2013 2:41 am
Have you tried su to run it as a normal user?
http://stackoverflow.com/questions/6905 ... t-password
znanev
Mon Jun 10, 2013 2:38 pm
Hi talkeasy,
I had similar issues. The application raspivid needs access to the video group (the default user - pi, is already a member of this group, so that's why it works when running the command from the terminal). So this worked nicely for me:
usermod -a -G video www-data
This command says: "Add the user www-data to the secondary group video".
This should be all you need to do, if your web server runs under the www-data accont.
talkeasy
Mon Jun 10, 2013 9:09 pm
Thanks for the replies. I now have a working solution, although the php and shell scripts need tidying up to exit properly.
I updated /etc/sudoers with:
www-data ALL=(pi) NOPASSWD: /home/pi/bin/script.sh
and then called
sudo -u pi /home/pi/bin/script.sh
from another www-data shell script.
Haven't got the php script to exit nicely yet, but VLC now starting nicely.
UPDATE: To have the php in the webpage exit properly I have modified the code to the following:
shell_exec('nohup ./script.sh > /dev/null & echo $!;');
Return to “Camera board”
