I checked the logs and I found this:
Jun 15 14:19:02 raspberrypi kernel: [ 858.204008] ERROR::dwc_otg_hcd_urb_enqueue:482: Not connected
Jun 15 14:19:02 raspberrypi kernel: [ 858.204032] ERROR::dwc_otg_hcd_urb_enqueue:482: Not connected
Jun 15 14:19:02 raspberrypi kernel: [ 858.204056] ERROR::dwc_otg_hcd_urb_enqueue:482: Not connected
Jun 15 14:19:02 raspberrypi kernel: [ 858.204091] ERROR::dwc_otg_hcd_urb_enqueue:482: Not connected
Jun 15 14:19:02 raspberrypi kernel: [ 858.204116] ERROR::dwc_otg_hcd_urb_enqueue:482: Not connected
Jun 15 14:19:02 raspberrypi kernel: [ 858.387408] usb 1-1: USB disconnect, device number 2
Jun 15 14:19:02 raspberrypi kernel: [ 858.387440] usb 1-1.1: USB disconnect, device number 3
Jun 15 14:19:02 raspberrypi kernel: [ 858.387677] smsc95xx 1-1.1:1.0: eth0: unregister 'smsc95xx' usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet
Jun 15 14:19:02 raspberrypi kernel: [ 858.398935] usb 1-1.2: USB disconnect, device number 4
Jun 15 14:19:03 raspberrypi kernel: [ 859.259341] cfg80211: Calling CRDA for country: CN
Jun 15 14:19:03 raspberrypi kernel: [ 859.727845] usb 1-1.2: ath9k_htc: USB layer deinitialized
Jun 15 14:19:04 raspberrypi kernel: [ 859.887453] Indeed it is in host mode hprt0 = 00021501
Jun 15 14:19:04 raspberrypi kernel: [ 860.357372] usb 1-1: new high-speed USB device number 5 using dwc_otg
Jun 15 14:19:04 raspberrypi kernel: [ 860.357556] Indeed it is in host mode hprt0 = 00001101
Jun 15 14:19:04 raspberrypi kernel: [ 860.747684] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
Jun 15 14:19:04 raspberrypi kernel: [ 860.747716] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 15 14:19:04 raspberrypi kernel: [ 860.748543] hub 1-1:1.0: USB hub found
Jun 15 14:19:04 raspberrypi kernel: [ 860.748688] hub 1-1:1.0: 5 ports detected
Jun 15 14:19:05 raspberrypi kernel: [ 861.027550] usb 1-1.1: new high-speed USB device number 6 using dwc_otg
Jun 15 14:19:05 raspberrypi kernel: [ 861.127952] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Jun 15 14:19:05 raspberrypi kernel: [ 861.127983] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 15 14:19:05 raspberrypi kernel: [ 861.131210] smsc95xx v1.0.4
Jun 15 14:19:05 raspberrypi kernel: [ 861.192441] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:bf:e7:06
Jun 15 14:19:05 raspberrypi kernel: [ 861.287589] usb 1-1.2: new high-speed USB device number 7 using dwc_otg
Jun 15 14:19:10 raspberrypi kernel: [ 866.409103] usb 1-1.2: New USB device found, idVendor=0cf3, idProduct=9271
Jun 15 14:19:10 raspberrypi kernel: [ 866.409136] usb 1-1.2: New USB device strings: Mfr=16, Product=32, SerialNumber=48
Jun 15 14:19:10 raspberrypi kernel: [ 866.409170] usb 1-1.2: Product: USB2.0 WLAN
Jun 15 14:19:10 raspberrypi kernel: [ 866.409186] usb 1-1.2: Manufacturer: ATHEROS
Jun 15 14:19:10 raspberrypi kernel: [ 866.409199] usb 1-1.2: SerialNumber: 12345
Jun 15 14:19:10 raspberrypi kernel: [ 866.413808] usb 1-1.2: ath9k_htc: Firmware htc_9271.fw requested
Jun 15 14:19:11 raspberrypi kernel: [ 866.831493] usb 1-1.2: ath9k_htc: Transferred FW: htc_9271.fw, size: 51272
Jun 15 14:19:11 raspberrypi kernel: [ 867.067848] ath9k_htc 1-1.2:1.0: ath9k_htc: HTC initialized with 33 credits
Jun 15 14:19:11 raspberrypi kernel: [ 867.300381] ath9k_htc 1-1.2:1.0: ath9k_htc: FW Version: 1.3
Jun 15 14:19:11 raspberrypi kernel: [ 867.309129] ieee80211 phy1: Atheros AR9271 Rev:1
Jun 15 14:19:12 raspberrypi kernel: [ 868.659291] ERROR::dwc_otg_hcd_urb_enqueue:482: Not connected
Jun 15 14:19:12 raspberrypi kernel: [ 868.659352] ERROR::dwc_otg_hcd_urb_enqueue:482: Not connected
Jun 15 14:19:12 raspberrypi kernel: [ 868.659399] ERROR::dwc_otg_hcd_urb_enqueue:482: Not connected
Jun 15 14:19:12 raspberrypi kernel: [ 868.659442] ERROR::dwc_otg_hcd_urb_enqueue:482: Not connected
Jun 15 14:19:12 raspberrypi kernel: [ 868.659483] ERROR::dwc_otg_hcd_urb_enqueue:482: Not connected
Jun 15 14:19:12 raspberrypi kernel: [ 868.659525] ERROR::dwc_otg_hcd_urb_enqueue:482: Not connected
It seems that the 482 Not connected repeats many times, and then the USB disconnect and reconnect show again, and again, until I reset the pi.
Edit: I tried without the wifi interface, only by ethernet, and it is working fine.
