HashberryPee
ascii output?
Fri May 31, 2013 6:48 pm
how can I get a cam stream in ascii (local, on the RPi)?
BR
Michael
mikerr
Re: ascii output?
Fri May 31, 2013 7:35 pm
Full motion ascii via mplayer caca is good fun:
sudo apt-get install mplayer
raspivid -t 10000 -p 0,0,320,200 -w 320 -h 200  -o - |mplayer -cache 1024 -fps 30 -vo caca -
The matrix has you...
HashberryPee
Re: ascii output?
Sun Jun 02, 2013 6:09 pm
It works, thanks a lot!
First you've posted two solutions. Remember something with '...|h'. What was that about?
mikerr
Re: ascii output?
Sun Jun 02, 2013 9:41 pm
The first bit was just a joke, that I removed, but here it is again:
raspivid -t 1000 -o - | tr -dc '[:print:]' |head
It does print an ascii stream ...
HashberryPee
Re: ascii output?
Mon Jun 03, 2013 8:13 pm
I see.. :)
Tried the very same with 'aa' instead of 'caca' but I get:
Cache not responding! [performance issue]
VO: [aa] cannot open /dev/ccsa00 for writing, so we'll use linux driver
X Error of failed request: BadName (named color or font does not exist)
Major opcode of ailed request: 45 (X_OpenFont)
Serial number of failed request: 7
Parent process disappeared, exiting cache process.
Any idea?
mikerr
Re: ascii output?
Mon Jun 03, 2013 10:18 pm
libaa want's a font it can't find. The fix would be to install that font - but it's not telling you which one ... :roll:
So I got it working using curses instead:
raspivid -t 999999 -p 0,0,320,200 -w 320 -h 200  -o - |mplayer -cache 1024 -nosub -fps 31 -vo aa:driver=curses -quiet -monitoraspect 0.5 -
HashberryPee
Re: ascii output?
Tue Jun 04, 2013 8:21 pm
For some reason it doesn't like the '-monitoraspect' option. Error message isn't that revealing
Unknown option on the command line: -monitoraspect=0.5
Error parsing option on the command line: -monitoraspect=0.5
MPlayer svn r34540 (Debian), built with gcc-4.6 (C) 2000-2012 Mplayer Team
Works without the monitoraspect option but the ascii outut is quite small then.
mikerr
Re: ascii output?
Tue Jun 04, 2013 8:54 pm
Sorry typed that bit of the line wrong, there's no "=" after monitoraspect :oops:
HashberryPee
Re: ascii output?
Wed Jun 05, 2013 8:02 pm
That's it, thanks again! You're a wizard.
Should have seen it by myself - was looking through the documentation and didn't notice. :roll:
Return to “Camera board”
