Using EasyCap instead of camera
Posted: Fri May 31, 2013 9:15 am
by simonb
I would like to capture from an EasyCap USB video capture stick, encode to H264 and stream to rtmp.
The EasyCap seems to be recognised OK and shows up on /dev/video.
For the camera one would normally use something like raspivid piped into ffmpeg. Unfortunately raspivid is locked to the camera hardware.
I've been looking at trying to recompile a version of raspivid that takes video from whatever is on /dev/video and sends it through the H264 hardware encoder. I have tried to recompile the "userland" tools but it flunks with link errors. I've tried to find the source deb for raspberrypi-firmware, which contains raspivid, but it is not available because the package is binary-only firmware.
So my questions are,
1) Am I on the right track or barking up the wrong tree? Am I making life difficult for myself by re-inventing the wheel and there is an easier way to get access to the hardware H264 encoder?
2) If I am on the right track then how do I get raspivid to recompile? I've found some instructions in the README that led me to set up distcc. However, having done that, the buildme script still uses some hardlinked local compiler. And I get the link errors again.
Re: Using EasyCap instead of camera
Posted: Fri May 31, 2013 9:36 am
by topguy
- Have you verified that you CAN grab video from EasyCap with standard tools ?
You are probably not the first to try to use EasyCap nor try to use the x264 encoder. Have you searched the forum for similar threads ?
Posted: Fri May 31, 2013 9:54 am
by simonb
Yes. I have found a few snippets. Probably the closest one to what I am trying to do is this one...
http://www.raspberrypi.org/phpBB3/viewt ... 38&t=41844
It leads to the GST module, OMX.broadcom.video_encode.
I will look at this but it will take me a while to figure out gstreamer pipes, especially if I want to encode sound too. If anyone can suggest an example gstreamer command that will take a v4L2 and ALSA source and produce an H264 file or stream would help me considerably.
Posted: Fri May 31, 2013 10:01 am
by fbutler
simonb wrote:If anyone can suggest an example gstreamer command that will take a v4L2 and ALSA source and produce an H264 file or stream would help me considerably.
Here is one that I have used. It may need some adjustment for your setup:
gst-launch-1.0 -t -e -v avimux name=mux ! filesink location=test.avi alsasrc device=hw:2,0 ! audio/x-raw, format=S16LE, rate=48000, channels=2 ! queue ! mux. v4l2src device=/dev/video0 ! video/x-raw, format='UYVY'! videoconvert ! video/x-raw,format='I420', width=720, height=576, framerate=25/1 ! omxh264enc ! mux.
Posted: Fri May 31, 2013 11:12 am
by simonb
Thanks! Much appreciated.
I had to install gstreamer1.0. This is how I did it (for anyone else who may find this thread useful).
I created a file /etc/apt/sources.list.d/gstreamer1.0.list with the following contents...
deb http://vontaene.de/raspbian-updates/ . main
I then installed gstreamer1.0 and associated packages...
sudo apt-get update
sudo apt-get install gstreamer1.0-alsa gstreamer1.0-plugins-bad gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-ugly gstreamer1.0-tools gstreamer1.0-x gstreamer1.0-omx
The only tweak I had to make to the suggested command line was setting the alsa device to "device=hw:1,0".
I now need to find a real PAL video source and see if this really does capture video.
Posted: Fri May 31, 2013 8:36 pm
by Defiant
The rpi can output PAL ;)
Did you have any success with your easycap device?
If yes, which one is it?
Posted: Fri May 31, 2013 8:45 pm
by simplesi
If you can get this to work - you'll have opened up the RPi to another whole geek eco-system
Simon
Posted: Tue Jan 12, 2016 6:18 am
by flyingbaloon
fbutler wrote:simonb wrote:If anyone can suggest an example gstreamer command that will take a v4L2 and ALSA source and produce an H264 file or stream would help me considerably.
Hi
Iam trying to play easy cap capture using the gpu . I am unable to get the suggested pipeline to work
gst-launch-1.0 -t -e -v avimux name=mux ! filesink location=test.avi alsasrc device=hw:1,0 ! audio/x-raw, format=S16LE, rate=48000, channels=2 ! queue ! mux. v4l2src device=/dev/video0 ! video/x-raw, format='YVYV'! videoconvert ! video/x-raw,format='I420', width=720, height=480, framerate=25/1 ! omxh264enc ! mux.
it gives me error could not link v4l2src0 to videoconvert0 . Please help me out . thanks
