MikeDunn
Re: RaspberryPi Camera for Astrophotography
Tue Sep 29, 2015 9:41 am
@Dougie,
Yes I know; it's on my list of things to get / fix. As it doesn't actually hurt anything (at least, I've not seen anything posted here to the contrary), it's not top of the list; but once I get a camera module a better supply will likely be bought @ the same time.
@Gordon,
Cheers for that; will have a check this morning (if I can) 8-)
Mike
[edit]
Grabbed a few spare minutes, and changing to 192 / 608 did it :D Looks really neat now :P
Kudos !
Now ... which camera to get ... vanilla or NoIR ... decisions decisions !!!
M
gordon77
Tue Sep 29, 2015 12:49 pm
Updated version.
By default should fit Pi Screen (800 x480)
You can set 'NoFrame' off / on in Display Setting (default off)
MikeDunn
Wed Sep 30, 2015 6:13 pm
Been checking out Jessie; was hoping to deploy the new version on there, but am not quite happy yet. Add on having to head away for a few days, and I won't get around to re-testing until the week-end ...
Mike
gordon77
Wed Sep 30, 2015 6:31 pm
MikeDunn wrote:Been checking out Jessie; was hoping to deploy the new version on there, but am not quite happy yet. Add on having to head away for a few days, and I won't get around to re-testing until the week-end ...
Mike
What are you not happy with ? I tried jessie yesterday and saw no issues at least with this program.
Gordon
MikeDunn
Wed Sep 30, 2015 6:43 pm
Various things ... the long-hold-down on the touchscreen for the right-click no longer works; VNC won't start automatically (although I fixed an error box on a manual start - they've gone & changed the descriptor text :roll: ); various other bits & pieces that I use & require; seems I have intermittent WiFi access as well now :roll: As such, not tried the app yet :( I want to be sure the underlying system is both stable and functional first.
Hopefully, there will be some fixes to these by the week-end.
Mike
gordon77
Wed Sep 30, 2015 6:47 pm
OK, l don't use any of those things.
Gordon
gordon77
Thu Oct 22, 2015 10:57 am
Updated version 8n
You can resize the buttons (bh and bw). This has meant a lot if re-writing so let me know if any issues.
Exp Modes modifed. You can now use options eg night / nigh2 which will allow you to change ev / Exp Time.
The most sensitive mode appears to be night / nigh2 with ISO in Auto, I think it puts it into ISO 1600. nigh2 will allow you to set the Exp Time.
It does work with Jessie, but my RTC won't work.
Gordon
gordon77
Fri Oct 23, 2015 9:45 am
Version n2
After some more testing added 'spor2' Exp Mode which can set ISO 1600 in auto ISO.
Frame now off in default.
Gordon
gordon77
Tue Oct 27, 2015 12:02 pm
Version o4
I managed some more testing last night, even if a bit cloudy and a full moon.
Hopefully many bugs fixed.
Regards sensitivity of the camera here's a comparison
Looking at Capella
PiNoir camera, with IR/UV filter, at auto ISO in Night Mode, -ss @ 450mS on a 80mm scope
Canon 7D at 200 ISO, f5.6, 400mm lens, 80 seconds exposure
I was guiding on the star to the right in the Pi image.
gordon77
Tue Oct 27, 2015 12:05 pm
Screenshot
Rpi Camera image
gordon77
Tue Nov 10, 2015 11:16 am
r8p
Added a Night / Day Mode, changes the colours to mainly red.
Set Night = 1 in DISPLAY section for Night colours, or press the D or N at bottom right of the keys.
(Not sure when you need a Day Mode, but they were the original colours)
update to r8q, minor bug fixes
Screenshot (testcard) in Night Mode
gordon77
Fri Dec 18, 2015 5:06 pm
New version.
Can now drive the Seeed Raspberry Pi Relay board v1.0. So you maybe able to interface to some older Scopes.
Set 'use_Seeed = 1', enable your i2c and sudo apt-get install python-smbus. Relay board address left to default of 20, on i2c-1.
Relay 1 = N, Relay2 = S, Relay 3 = E, Relay 4 = W.
Pin26 still available to interface to a dslr etc
All at your own risk ! . Let me know any errrors.
Gordon
gordon77
Mon Dec 28, 2015 1:11 pm
Update.
I found a couple of issues if using a webcam.
Gordon
gordon77
Sun Jan 03, 2016 10:59 am
Update, now added support for PiFace Relay Plus board.
This board uses SPI, see within program to install & enable.
set use_PiFaceRP = 1
SPI conflicts with the GPIOs I have used so it needs to move the ext DSLR camera output from pin 26, set AC_OP if using SPI. I have moved it to pin 13 but you could move it where you want it.
MikeDunn
Sun Jan 03, 2016 8:06 pm
Gordon,
Do you have 2 settings conflicting here ?
# if using the RPi camera set use_Pi_Cam = 1 , if set to 0 the program will use a USB camera.
use_Pi_Cam = 1
# if using the RPi.GPIO on the Pi set use_RPiGPIO = 1, not required if only using the DSLR GPIO O/P (photoon = 1).
use_RPiGPIO = 1
# to enable GPIO control of DSLR function set photoon = 1
photoon = 1
I couldn't get this to work until I reset
photoon = 0
Your thoughts ?
Mike
gordon77
Sun Jan 03, 2016 8:08 pm
Mike,
I haven't seen any. What error did you get?
Gordon
MikeDunn
Sun Jan 03, 2016 8:13 pm
I didn't get anything ! Just a big black box instead of the interface ...
Hence I had a look at this config & changed that parameter - and bingo :D
gordon77
Sun Jan 03, 2016 8:17 pm
Does it repeat if you change photoon back to 1?
Gordon
MikeDunn
Sun Jan 03, 2016 8:43 pm
Hmmm, no - works fine ...
Strange ... :?:
gordon77
Sun Jan 03, 2016 8:46 pm
Thanks Mike,
Let me know if it happens again.
I'll do some testing tomorrow.
Gordon
gordon77
Mon Jan 04, 2016 3:24 pm
I've run this most of the day and seen no problems.
Gordon
AndyDane
Wed Jan 20, 2016 8:08 pm
OK, this might sound really basic but how did you get your camera lined up with the eyepiece?
Ive got gstreamer working nicely but I can't seem to get the camera lined up or mounted so that I get an image out...
I've tried a variety or ways of making it stable but failing...
ta
Andy
Jetstar49
Thu Jan 21, 2016 1:26 am
Hi gordon,
I just received my first raspberry pi 2 and camera board in hopes of making it into an autoguider. I found this thread after doing some searching on google. What you have done so far looks amazing. I am going to try and code the software myself since I know Python and Open CV, but I may switch to yours later on.
Before I jump in and try it I had a question about communication with the mount. I know you have developed yours to work with an LX200. Do you know what I would need to change in order for this to work with a Celestron CGEM with a ST-4 port? Would I need the Arduino board or would the GPIO pins be fine? Sorry if you answered this before. I read through most of the posts and didn't see it.
gordon77
Thu Jan 21, 2016 6:29 am
This should work with any ST4 port, using the opto relays, opto coupler, seeed relays, piface relay plus or any relay board. I would recommend the opto coupler as the simplest and cheapest.l use It on a neq6 pro mount with the opto coupler.
Gordon
Opto coupler
ST-4_interface IL74.jpg (47.95 KiB) Viewed 3636 times
gordon77
Thu Jan 21, 2016 6:32 am
AndyDane wrote:OK, this might sound really basic but how did you get your camera lined up with the eyepiece?
ta
Andy
I don't mount it on the eyepiece. Take the eyepiece off the scope and insert the pi camera mounted on a 1.25" adaptor. Ensure you've removed the lens from the pi camera.
I used a mount similar to this which l took from an old Webcam
http://www.m12lenses.com/mobile/Product ... T-LH020RPM
And one of these...
http://www.amazon.com/Adapter-Telescope ... B00T23G3VG
Gordon.
Pi camera with adaptor
Return to “Camera board”
