gordon77
Re: RaspberryPi Camera for Astrophotography
Sat Apr 19, 2014 1:32 pm
Mars 18/4/2014 Pi Noir camera with UV&IR cut filter.
Meade LX10, processed with registax.
Gordon77
Mars 18042014
gordon77
Tue Jul 08, 2014 10:18 am
Just tried the latest Raspbian and my Philips NPC900 webcam connects on USB :D (the 840 won't or my 3D webcam :( )
The 900 webcam is a popular one for astrophotography.
Anyone know how to control a webcam via Python ?
Gordon77
gordon77
Thu Jul 10, 2014 9:16 am
All I can find is cam.set_controls() which only seems to have vflip, hflip and brightness.
Brightness seems to be working on the 900 so I'll go with that for now.
gordon77
EckyH
Sat Sep 06, 2014 8:11 am
gordon77 wrote: Heres the details of the ST-4 interface
Hello and thanks for the project idea. I'd like to control a mount (Losmandy G9 with DDS Model 492) via RPi as well.
I'm not in electronics generally and and integrated circuits in particular, so please forgive me my dumb question: What's the reason for those four dedicated digital relays?
Found a lot of other types available from several dealers, some with 4 integrated relays.
Despite a search for the ST-4 "standard" documents (eg. for voltage and current used) - didn't found any other documents than descriptions of the pin-out...
Thank you very much!
E.
raceconditions
Fri Oct 31, 2014 3:26 pm
So this very post was actually my inspiration for getting a Raspberry PI hooked up to my telescope. I ended up using Proto Armour and a series of mount adapters to make the attachment and I have to say it worked extremely well. I've blogged about this and some of the software I've been working on for GPS telescope sync and a WiFi telescope server.
For the hardware configuration, check here:
NexStar SE Telescope and Raspberry PI
gordon77
Thu Nov 06, 2014 6:43 pm
E.
Sorry l hadn't noticed this question.
The 4 relays provide the + and - ra and Dec controls.
Here's the st4 connection, but note it can change on various makes of equipments.
http://www.nexstarsite.com/OddsNEnds/AutoGuide.htm
Gordon77
gordon77
Thu Nov 06, 2014 6:54 pm
raceconditions wrote:So this very post was actually my inspiration for getting a Raspberry PI hooked up to my telescope. I ended up using Proto Armour and a series of mount adapters to make the attachment and I have to say it worked extremely well. I've blogged about this and some of the software I've been working on for GPS telescope sync and a WiFi telescope server.
Looks very good. What software are you using ?
Gordon77
gordon77
Fri Nov 07, 2014 2:44 pm
E.
Gordon77
Sorry I misread this, you already know the pinout !. I am the same on the ST4 volts and currents, I can't find any figures. I used the relays to get opto-isolation, and they can handle > 1A but I don't suspect the currents get anywhere near that.
Gordon77
Stupotmcdoodlepip
Fri Nov 07, 2014 5:08 pm
Many ST4 devices are USB bus powered, so you can safely assume that the total required current is less than 500mA, however, in reality, if the inputs simply drive, for example, microcontroller inputs, then they'll likely only draw microamps at most.
Pretty simple to check using a multimeter (set to mA mode) in series with the relay switched contacts.
The relays are most likely used for galvanic isolation, e.g., where there's no guarantee that the two subsystems will share a common ground, say, for instance if your controller is powered by a mains adaptor and the guide camera is plugged into a PC or laptop.
gordon77
Sat Nov 08, 2014 6:04 pm
Stupotmcdoodlepip wrote:Many ST4 devices are USB bus powered, so you can safely assume that the total required current is less than 500mA, however, in reality, if the inputs simply drive, for example, microcontroller inputs, then they'll likely only draw microamps at most.
When 'driving' ST4 you sink current, to earth/common rather than supplying current, but your interface may need current, possibly from the USB etc.
Gordon77
HKay
Tue Nov 11, 2014 9:06 pm
Hi Gordon,
Some days ago, I found you posting and your autoguiding software. I was able to adapt your code to use the PiFace-interfaceboard to connect to the autoguider interface of my mount and to connect to the camera. As far as I was able to test, the autoguiding seems to work. Wasn't able to go outside yet.
Do you currently have some newer version of your program? Are you interested in the changes for the PiFace (which aren't very difficult, as you surely would know)?
Anyway, I want to thank you for this piece of code and hope to be able to test it outside as soon as possible!
Greetings,
Hardy
gordon77
Thu Nov 13, 2014 4:31 pm
Glad you like the software. I attach the latest version, I think the changes are some bug fixes, some speed improvements, added a PHOTO button where you can take photos with an external camera (eg DSLR) with a suitable interface to another GPIO (you control the camera in bulb mode. Set the number of photos you want and the time of exposure and press PHOTO), you can also set the brightness of images if using a USB camera, and if you press the SHIFT key it will store images for later processing.
Please note that using any software or any interface designs l have uploaded is at your own risk. I have tested it on my own equipment. Please take care when interfacing to any equipment, eg a telescope, camera, to ensure you do not damage them.
If you want to publish how you used the PiFace that would be interesting.
Let me know how it goes.
Gordon77
deivid
Sun Nov 16, 2014 6:33 am
gordon77 wrote:noir[...]
I saw your post about taking a pic with an UV filter, does that mean that you can capture UV light? if so, could you take a picture of your face? I'm looking to set up an UV-capturing camera to 'check' people's skin
gordon77
Sun Nov 16, 2014 9:03 am
Sorry I don't know if the Pi camera is sensitive to UV. I used an astronomy filter that cuts IR & UV that can blur the images. I think you'll need to look for a filter to pass UV to try.
Gordon77
gordon77
Wed Jan 21, 2015 2:13 pm
Updated version.
I bought a 7" HDMI so there is now a Display option where you can select LCD (848x480),Composite (640x480) etc. You'll also need to adjust config.txt to suit.
(note on a 7" HDMI display (848x480) the SAVE and RELOAD buttons won't appear fully, you can just press Keys 1,2 or 3 to RELOAD or Keys 4,5 or 6 to SAVE the configs. This maybe sorted with setting /boot/config.txt with appropriate settings and using Un/Decorate to remove the window header.
scr cap = screen (window) capture (as below)
pic cap = picture capture, saves a full res Pi camera image
con cap = constant capture, saves every image
It took quite a bit or rewriting so let me know of any bugs.
Gordon77
Pi with camera and telescope adaptor
Pi with camera.jpg (58.15 KiB) Viewed 5071 times
gordon77
Sun Feb 01, 2015 9:39 pm
Update.
Should now update the picture quicker (thanks to the tip from ethanol100!) plus a few minor bug fixes.
Picture from tonight, Canon 7D , 400mm f5.6 lens, guided by 80mm scope and Pi with camera and this software.
Gordon77
M42
Screenshot
gordon77
Tue Feb 03, 2015 5:17 am
The Telescope setup for testing.
The setup
gordon77
Sat Feb 07, 2015 4:41 pm
gordon77 wrote:Update.
Gordon77
Updates the pictures even quicker with a Pi2 :D
If you're using RPi.GPIO you'll need to update, see below, or try raspbian image dated 2015-02-16
Pi2 version
fireshipjohn
Fri Feb 13, 2015 5:02 pm
The RPi.GPIO is now updated/published and it all works OK on an Pi2 :)
So just an apt-get update and an apt-get upgrade will do it, although I think a firmware update is required to fix other (PWM) issues with the RPi.GPIO package, so best do a rpi-update and reboot also.
So now a nice VNC session to a remote Pi2 runs at about 35% cpu load.
John
vendinleciel
Fri Feb 20, 2015 9:35 am
Hello, i live in North of France and i am very interesting by your developpement.
I try for a couple of weeks to make telescope tracking on an old st4 mount with a webcam and with raspberry.
So your project seems fit for it.
I should try with a webcam philips before buying a PI camera.
it seems there is two tracks for an ST4 mount:
1 for using an arduino with 4 relays module, but i do'nt find the .ino software for arduino ? does it exist somewere?
2 for using a direct connexion between GPIO and relays module.
Is one system more efficient than the other?
Congratulations for this project.
Vendin le ciel
gordon77
Fri Feb 20, 2015 10:46 am
.ino attached for Arduino, if need any more details let me know.
If you use the Seeed 4 relay board (shown early in the thread as ST4-5c.jpg) you'll need to change
const int West = 4; //pin of the Arduino WEST
const int South = 6; //pin of the Arduino SOUTH
const int North = 7; //pin of the Arduino NORTH
const int East = 5; //pin of the Arduino EAST
const int MotorStep = 3; //pin of the Arduino connects to the STEP pin of the EasyDriver board or PWM interface
const int MotorDir = 2; //pin of the Arduino connects to the DIR pin of the EasyDriver boardor PWM interface
Either system is OK .
Using a usb camera and the GPIO may have some minor issues with timings of the pulses to the scope, depending how long it takes to take an image, and I haven't worked out a method to control the camera parameters except for brightness so everything else is auto.
Using the Pi GPIO maybe cheaper unless you have an Arduino + relay board.
You maybe able to us a cheap opto isolator instead of my opto relays.
I wasn't sure of the current needed to switch but I have read recently on Meade, Celestron its only 50mA so maybe worth a try.
Gordon77
Scope_Emulator.zip
,ino file
(5.63 KiB) Downloaded 158 times
vendinleciel
Fri Feb 20, 2015 4:01 pm
Hello Gordon
thanks for your quick answer.
I should first try with GPIO and 4 relay module because i am waiting for an arduino.
In your answer you speak of an Easydriver module wired on arduino; i don't see any reference about this module in the forum or in the pictures and diagrams of the project.
Does it drive directly a stepper motor and for what use?
gordon77
Fri Feb 20, 2015 4:15 pm
This started out as a project to drive a Meade LX10 from a PC using PHD guiding software etc.
I added control to be able to drive a Meade #1209 focusser, another user wanted a drive for a stepper motor he wanted to use for focussing his scope so I added that, I've never seen it used.
I assume it drives one of these https://www.sparkfun.com/products/retired/9402
The arduino program can also do other features such as accept inputs from a LX10 handcontroller or a ST-4 device to control the LX10 ( the LX10 is not ST-4) and also accept variable pot inputs to produce a fairly crude drift control on star loss but you probably won't need any of this to drive a ST-4 scope. They should all be disabled in the program so you dont need to connect any of these inputs.
Gordon77
the arduino
fireshipjohn
Mon Mar 02, 2015 10:16 am
Hi Gordon,
I found a small bug I think, if I leave the program running for an extended period it sometime crashes with a message:
JPEG loading error - at line 736.
It looks like a race condition with raspistill updating /run/shm/test.jpg.
So I tried this little patch which seems to fix it. (well it outputs the message and doesn't crash!)
735,736c735,740
<       image = pygame.image.load(imagefile)
>       try:
>       except pygame.error, message:
>         print 'Failed initial load image:', imagefile
>         time.sleep(0.5)
Its not a full fix, because you could get two successive failures, but seems to work for me.
John
gordon77
Mon Mar 02, 2015 5:16 pm
Thanks John,
I can't say I have seen that and I've run it for many hours, so I am not sure what's happening.
Are you using a Pi1 or Pi2 ?
What settings are you using ? Exp mode off ? Exp time ? Any options on eg graph, Plot, log ? Can you upload a screen shot ( scr pic)
When I originally wrote it I read about reading incomplete files but I never saw that either.
I'll include your fix in the next version, let me know if it all goes well. Sounds like we should only lose 0.5 secs occasionally.
Gordon
Return to “Camera board”
