MacHack
Re: Streaming mjpg from Raspberry Cam
Tue Oct 29, 2013 10:33 am
I have something new for you.
Using the resizer code from wibble82 from his api http://www.raspberrypi.org/phpBB3/viewt ... 43&t=59300, I've written a bit of code that let you have full field of view with the video port. As the binning is still missing, there is a 15 fps limitation.
I added the "-fullfov" parameter which enables the full field of view. Obviously, this parameter has no effect if you use -usestills. Enabling the "-fullfov" option will automatically limit the framerate at 15 fps.
I haven't had time to test it completely so use it at your own risk, there might still be some bug that would need a reboot.
Have fun with it.
input_raspicam.c.tar.gz
(8.36 KiB) Downloaded 495 times
Hodofca
Tue Oct 29, 2013 12:43 pm
MacHack wrote:Hi,
Have fun with it.
Hi. It looks promissing. I really would like to test it out but can you give some instruction for a newbie how to install it? I've just copied this file into my mjpeg folder on my raspberry, did "make clean all" and now i use:
 LD_LIBRARY_PATH=/home/pi/mjpg mjpg_streamer -o "output_http.so -w ./www" -i "input_raspicam.so -x 800 -y 480 -fps 2 -ex sports -fullfov"
but its simply not recognizing -fullfov option
Without it everything works for me without issues.
tiger79
Wed Oct 30, 2013 3:14 pm
Hodofca you are getting better framerates now ?
Like the 15 fps mentioned by jacksonliam ?
jacksonliam
Wed Oct 30, 2013 8:11 pm
MacHack wrote:Hi,
Have fun with it.
Nice! I'll try and merge that at the weekend. Does that pull a full 5MP frame from the camera, feed it into the resizer component to turn the full frame into the requested resolution then the encoder to encode it to JPEG? Didn't realise you could pull 5MP frames from the camera that quickly!
Hodofca
Wed Oct 30, 2013 8:15 pm
tiger79 wrote:Hodofca you are getting better framerates now ?
No. Still the same but i think that i dont need so much fps for my surveillance cam. now i set my cam to 3 fps -ex sports and it's enought.
jacksonliam
Wed Oct 30, 2013 8:30 pm
Tiger79 are you seeing this too? If its a problem with the code I'm interested in fixing it!
Hodofca, how are you measuring the FPS when you have it set to e.g. "-fps 15" and are not using "-usestills", because the plugin only outputs the measured framerate when using "-usestills".
Hodofca
Wed Oct 30, 2013 10:52 pm
I use iSpy 64 v.5.5.8.0
I know that this soft shows a bit lower framerate compared to just looking at the output using web browser, but well..i dont know any other method to check fps. Another thing is that iSpy is not even showing 1080p (in web browser no problem).
jacksonliam
Thu Oct 31, 2013 7:29 pm
I think this is an iSpy issue, not an issue with mjpg-streamer.
VLC will show the stream, but not as well as a web browser and it does not calculate the FPS. The problem is, mjpg works by capturing frames and then the client requests frames as fast as it can from the server. Any display of the FPS on the client side is going to be an average/estimate.
Todd Alan
Fri Nov 01, 2013 7:20 am
Heads up!!!!! A new version of the Video4Linux2 driver for the Raspberry Pi Camera Board is out! This is really slick I have it running at 30fps, practically 0 latency. I'm streaming over my edimax 7811. This is the solution that I have been looking for. check it out http://www.linux-projects.org/modules/n ... toryid=154
gsh
Fri Nov 01, 2013 7:40 am
Is this still using the user mode implementation?
Gordon
Gordon Hollingworth PhD
jacksonliam
Fri Nov 01, 2013 6:07 pm
Todd Alan wrote:Heads up!!!!! A new version of the Video4Linux2 driver for the Raspberry Pi Camera Board is out! This is really slick I have it running at 30fps, practically 0 latency. I'm streaming over my edimax 7811. This is the solution that I have been looking for. check it out http://www.linux-projects.org/modules/n ... toryid=154
I think that is using the same mmal API's as this to get fast JPEGs. This should actually be a tiny bit more resource-friendly if you want mjpg-streamer rather than using the v4l2 plugin with that driver!
gsh wrote:Is this still using the user mode implementation?
Gordon
Sorry, I don't quite understand the question! My mjpg-streamer raspicam plugin (which is what this thread has mostly become about) uses mmal to put the camera in either stills or video mode sending the frames through the jpeg-encoder and writes the resulting output directly to the mjpg-streamer buffers.
Todd Alan
Fri Nov 01, 2013 6:54 pm
Gordon
Todd wrote: I was getting ready to implement your raspicam plugin when I found this update. I am using mjpg-streamer with the new driver. I want to incorporate the raspicam plugin next so I can get the video running in the background. Soon this driver will have the ability to implement text into the stream
rmsalinas
Fri Nov 01, 2013 8:25 pm
Hi guys,
I've just created a library in C++ for controlling the camera. You might be interested in it. Take a look at
http://www.uco.es/investiga/grupos/ava/node/40
Cheers
Rafa
tiger79
Mon Nov 04, 2013 12:43 pm
jacksonliam wrote:
Hodofca wrote:
tiger79 wrote: Tiger79 are you seeing this too? If its a problem with the code I'm interested in fixing it!
I cannot test atm but if possible I will pick it up this week to see if I am getting the results I have been hoping for (640x480 at 15fps with 8-10% cpu usage, actually what I am able to do now with a BeagleBone Black)....
RpiName
Wed Nov 06, 2013 3:03 am
There's probably only one good reason (and many bad reasons) to have a driver in kernel space if you can have one in user space, but considering this camera on the rpi, the little benefit is not worth the effort.
jbeale
Wed Nov 06, 2013 6:59 am
MacHack wrote:Using the resizer code from wibble82 from his api http://www.raspberrypi.org/phpBB3/viewt ... 43&t=59300, I've written a bit of code that let you have full field of view with the video port. As the binning is still missing, there is a 15 fps limitation.
I would very much like to try this out. Is the code available? How can I try it?
gsh
Wed Nov 06, 2013 7:14 am
You don't state what your reasons are what are the many bad reasons? I can only think of one which is it's slightly more difficult to maintain because debugging is more difficult but otherwise ...
Also where's the source, is it closed source as well?
Gordon
RpiName
Wed Nov 06, 2013 9:17 am
gsh wrote:Also where's the source, is it closed source as well?
As being open source is not really in the spirit of Broadcom, funding/investing in an userspace driver is one more way to keep their sauce secret. Not that I would be happy for that, but it's more coherent with the closed source nature of the rpi.
gsh
Wed Nov 06, 2013 9:45 am
Troll alert...
Lets get your facts straight first shall we:
1) Broadcom has completely open sourced all ARM side code so saying that is just trolling which will get you banned
2) Neither Raspberry Pi or Broadcom is funding a user space driver - open or closed source. We are funding the right way to do it, i.e. a kernel driver that for some reason you originally said is the wrong way to do it.
3) Closed source nature of the RPi see 1 above
Gordon Hollingworth (Director of Engineering, Raspberry Pi so I know what I'm talking about)
RpiName
Wed Nov 06, 2013 10:27 am
gsh wrote: 1) Broadcom has completely open sourced all ARM side code so saying that is just trolling which will get you banned
Either you misunderstood what I am trying to say or I did not explain my point well.
1-3) That's exactly what I am saying: the GPU code (the "secret sauce") which is called by the open-source ARM side "wrapper" is still closed-source, isn'it?
2) I did not say that. I was suggesting to consider an userspace driver (open source or not) as an alternative to easily keep some GPU implementation secret while profiting by the userspace stack already developed. I am not sure this would be so easy with a kernel driver.
MacHack
Wed Nov 06, 2013 10:29 am
to try this, follow the same instructions as for my previous patch. For clarity purposes, I'll rewrite it here.
You need to download the file from my previous post and extract it.
After, you need to clone the github from jacksonliam https://github.com/jacksonliam/mjpg-streamer and replace the file mjpg-streamer/mjpg-streamer-experimental/plugins/input_raspicam/input_raspicam.c by the one you've just extracted. Then build mjpeg-streamer.
I think jacksonliam may add it the github quite soon and remove some bugs in it.
By the way, jacksonliam, if you do it, I think I forgot to destroy the resizer at the end of my code which could result in a lock up of the camera and need a reboot.
Have fun with it.
Wed Nov 06, 2013 10:31 am
Either you misunderstood what I am trying to say or I did not explained my point well.
1. The GPU is and always has been a binary blob, and closed source. That has nothing to do with a user space or kernel driver for the camera - both of which are ARM side. I believe the userspace driver is closed source - ( I could be wrong) this is nothing to do with either the Foundation or Broadcom. The kernel driver will be OSS when it is released.
2. That doesn't make sense. The kernel driver will be using exactly the same interface to the GPU as the userspace one, but will by its nature use it more effectively. It's nothing to do with keeping stuff secret - and I repeat, the kernel driver will be OSS, as it has to be.
gsh
Wed Nov 06, 2013 10:35 am
I was assuming you had something useful to add but obviously not
Gordon
RpiName
Wed Nov 06, 2013 10:42 am
jamesh wrote:The kernel driver will be using exactly the same interface to the GPU as the userspace one
Okay, thanks for the clarification.
corncrake
Wed Nov 06, 2013 4:54 pm
Hi All,
Thanks for your work here - have this in use with a bird feeder. I use this to provide a stream to another machine running motion.
I am experience the fade to black issue ( after maybe 3 hours running ) and I would like to slow down the default frame rate. I have tried "-fps 0.5" but this seems to speed up, not slow down the fps and the -d delay parameter is not working for me.
Any help appreciated.
John
Return to “Camera board”
