Only for Mac OS and Linux
Over the past week after receiving my camera, I have been trying to set up a method to stream lag free video from my robot. It has to be lag free for the robot as it is going to be remote controlled from the live feed.
I have just posted a guide on my blog explaining how to do it for mac OS, should be very similar for linux based OSs.
The guide can be found at http://pi.gbaman.info/?p=150
Currently I don't see an easy way to do this on windows, I believe it requires gstreamer 1.0 and may not work with 0.10. If anyone finds a way, do let me know
Streaming lag free 1080p 25fps video. Gstreamer
Lead developer of PiNet, a free and opensource centralised user accounts and file storage system for Raspberry Pi classrooms used in over 200 schools across the world.
http://pinet.org.uk
http://pinet.org.uk
Re: Streaming lag free 1080p 25fps video. Gstreamer
Works nice! much better than other options with VLC.
I have about 0,5s lag instead of 3-4 seconds.
Thank you!
Thank you!
You get gst-launch-0.10 when you download the GStreamer SDK for Windows.
As how you use a command line on Windows, I have no idea.
For some reason I cannot get this to work it freezes on Pipeline is Prerolling or I get an error
ERROR: from element /GstPipeline:pipeline0/GstGDPDepay:gdpdepay0: Could not decode stream.
Hi Gbaman,Gbaman wrote:The guide can be found at http://pi.gbaman.info/?p=150
This pipeline doesn't work when I try it. Here's what I am seeing when attempting to use the sender pipe with no modifications other than using the IP address of the sending Pi:
pi@raspi1 ~ $ raspivid -t 999999 -h 720 -w 1080 -fps 25 -hf -b 2000000 -o - | gst-launch-1.0 -v fdsrc ! h264parse ! rtph264pay config-interval=1 pt=96 ! gdppay ! tcpserversink host=192.168.1.101 port=5000
Setting pipeline to PAUSED ...
/GstPipeline:pipeline0/GstTCPServerSink:tcpserversink0: current-port = 5000
Pipeline is PREROLLING ...
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, width=(int)1080, height=(int)720, parsed=(boolean)true, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)0164001fffe1000f2764001fac2b402202df2f00f1226a01000528ee025cb0
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0.GstPad:src: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, sprop-parameter-sets=(string)"J2QAH6wrQCIC3y8A8SJq\,KO4CXLA\=", payload=(int)96, ssrc=(uint)924457899, timestamp-offset=(uint)3503283303, seqnum-offset=(uint)43364
/GstPipeline:pipeline0/GstGDPPay:gdppay0.GstPad:sink: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, sprop-parameter-sets=(string)"J2QAH6wrQCIC3y8A8SJq\,KO4CXLA\=", payload=(int)96, ssrc=(uint)924457899, timestamp-offset=(uint)3503283303, seqnum-offset=(uint)43364
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0.GstPad:sink: caps = video/x-h264, width=(int)1080, height=(int)720, parsed=(boolean)true, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)0164001fffe1000f2764001fac2b402202df2f00f1226a01000528ee025cb0
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0: timestamp = 3503283303
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0: seqnum = 43364
/GstPipeline:pipeline0/GstGDPPay:gdppay0.GstPad:src: caps = application/x-gdp, streamheader=(buffer)< 01000100464e00000155ffffffffffffffff000000000000000000000000000000000000000000000000000000000000000000000000000000005d6700004773744576656e745365676d656e742c207365676d656e743d284773745365676d656e7429224773745365676d656e742c20666c6167733d284773745365676d656e74466c616773294753545f5345474d454e545f464c41475f4e4f4e452c20726174653d28646f75626c6529312c206170706c6965642d726174653d28646f75626c6529312c20666f726d61743d28477374466f726d6174294753545f464f524d41545f54494d452c20626173653d286775696e74363429302c206f66667365743d286775696e74363429302c2073746172743d286775696e74363429302c2073746f703d286775696e7436342931383434363734343037333730393535313631352c2074696d653d286775696e74363429302c20706f736974696f6e3d286775696e74363429302c206475726174696f6e3d286775696e7436342931383434363734343037333730393535313631353b223b00, 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 >
/GstPipeline:pipeline0/GstTCPServerSink:tcpserversink0.GstPad:sink: caps = application/x-gdp, streamheader=(buffer)< 01000100464e00000155ffffffffffffffff000000000000000000000000000000000000000000000000000000000000000000000000000000005d6700004773744576656e745365676d656e742c207365676d656e743d284773745365676d656e7429224773745365676d656e742c20666c6167733d284773745365676d656e74466c616773294753545f5345474d454e545f464c41475f4e4f4e452c20726174653d28646f75626c6529312c206170706c6965642d726174653d28646f75626c6529312c20666f726d61743d28477374466f726d6174294753545f464f524d41545f54494d452c20626173653d286775696e74363429302c206f66667365743d286775696e74363429302c2073746172743d286775696e74363429302c2073746f703d286775696e7436342931383434363734343037333730393535313631352c2074696d653d286775696e74363429302c20706f736974696f6e3d286775696e74363429302c206475726174696f6e3d286775696e7436342931383434363734343037333730393535313631353b223b00, 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 >
(gst-launch-1.0:4543): GStreamer-WARNING **: gstpad.c:3908:gst_pad_push_data:<gdppay0:src> Got data flow before stream-start event
(gst-launch-1.0:4543): GStreamer-WARNING **: gstpad.c:3677:gst_pad_chain_data_unchecked:<tcpserversink0:sink> Got data flow before stream-start event
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Any thoughts on what could be the issue?
Has anyone else had problems installing gstreamer on rPi? I've tried on two different Pi's and Raspbian builds (after doing an update) but keep getting this error:
Thanks.
pi@raspberrypi ~ $ sudo apt-get install gstreamer1.0
Reading package lists... Done
Building dependency tree
E: Unable to locate package gstreamer1.0
E: Couldn't find any package by regex 'gstreamer1.0'
@jarrah31
You need to add:
To /etc/apt/sources.list
And then run:
You need to add:
deb http://vontaene.de/raspbian-updates/ . main
And then run:
sudo apt-get update
Yes, my fault. I forgot I had another repo in my sources list which it was pulling it from, have updated the blog postjarrah31 wrote:Has anyone else had problems installing gstreamer on rPi? I've tried on two different Pi's and Raspbian builds (after doing an update) but keep getting this error:
Thanks.Code: Select all
pi@raspberrypi ~ $ sudo apt-get install gstreamer1.0 Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package gstreamer1.0 E: Couldn't find any package by regex 'gstreamer1.0'
http://pinet.org.uk
http://pinet.org.uk
works fine in my setup (wlan - internet (vpn) - macbookpro ) -> so i can watch what's going on at home from the internet.
I' tried out some other solutions (vlc-streaming) but this is the best.
h 720
w 1000
fps 12
cpu < 10%
h 720
w 1000
fps 12
cpu < 10%
I just wanted to let people know that I got audio streaming working as well by using a USB soundcard for audio input:
To stream:
Replace the clientIp with your computers ip address. Normally I just set the end to 255, so it can be received on every computer on the network, for instance I set mine to: 10.0.0.255.
You will properly have to install the following packages: "alsa-utils", "alsa-firmware", and "alsa-plugins".
Also replace 'Set' with the name of your soundcard. You can get that by running:
You can also use:
To get some more information about your soundcard.
You can set the default soundcard like so:
To adjust your setting use:
And then to store your settings:
To test the speakers run:
To receive the audio on your computer:
If you experience dropouts you might want to add "num-buffers=1000" at the server side, but in my experience it actually works better by not using it.
I will be working on muxing the signals toghether next
Btw you can test if your USB soundcard is working on the Raspberry Pi with the following command:
And this will loop back the audio from your microphone:
I also got streaming working via VLC:
Be sure to replace 10.0.0.9 with the ip address of your Raspberry Pi.
And then just open:
In VLC on your computer, but the latency is much much larger.
Hope this will be useful to someone
To stream:
gst-launch-1.0 alsasrc device=plughw:Set \
! mulawenc ! rtppcmupay ! udpsink host=clientIp port=5001
asoundconf list
cat /proc/asound/cards
aplay -l
asoundconf set-default-card cardname
alsamixer
sudo alsactl store
speaker-test -c 2
gst-launch-1.0 udpsrc port=5001 caps="application/x-rtp" \
! queue ! rtppcmudepay ! mulawdec ! audioconvert ! autoaudiosink sync=false
gst-launch-1.0 audiotestsrc ! alsasink
gst-launch-1.0 alsasrc device=plughw:Set ! alsasink
cvlc -vvv alsa://plughw:Set \
--sout '#transcode{acodec=mp2,ab=32}:rtp{dst=10.0.0.9,port=1234,sdp=rtsp://10.0.0.9:8085/stream.sdp}'
And then just open:
I wrote a little followup to my previous comment at my blog with a little more information.
Check it out http://blog.tkjelectronics.dk/2013/06/h ... o-latency/
Sorry to revive a year old thread, but I am having the same issue and can't find much info with my googling skills. I can get it to work with UDP but it doesn't seem to like TCP for some reason. Anyone know why we are having this issue?Rushy wrote:For some reason I cannot get this to work it freezes on Pipeline is Prerolling or I get an errorERROR: from element /GstPipeline:pipeline0/GstGDPDepay:gdpdepay0: Could not decode stream.
