Gbaman
Streaming lag free 1080p 25fps video. Gstreamer
Sat May 25, 2013 5:21 pm
Only for Mac OS and Linux
Over the past week after receiving my camera, I have been trying to set up a method to stream lag free video from my robot. It has to be lag free for the robot as it is going to be remote controlled from the live feed.
I have just posted a guide on my blog explaining how to do it for mac OS, should be very similar for linux based OSs.
The guide can be found at http://pi.gbaman.info/?p=150
Currently I don't see an easy way to do this on windows, I believe it requires gstreamer 1.0 and may not work with 0.10. If anyone finds a way, do let me know
Lead developer of PiNet, a free and opensource centralised user accounts and file storage system for Raspberry Pi classrooms used in over 200 schools across the world.
http://pinet.org.uk
pmdelpino
Re: Streaming lag free 1080p 25fps video. Gstreamer
Sat May 25, 2013 7:37 pm
Works nice! much better than other options with VLC.
I have about 0,5s lag instead of 3-4 seconds.
Thank you!
towolf
Sat May 25, 2013 11:50 pm
You get gst-launch-0.10 when you download the GStreamer SDK for Windows.
As how you use a command line on Windows, I have no idea.
Rushy
Mon May 27, 2013 3:16 pm
For some reason I cannot get this to work it freezes on Pipeline is Prerolling or I get an error
ERROR: from element /GstPipeline:pipeline0/GstGDPDepay:gdpdepay0: Could not decode stream.
fbutler
Mon May 27, 2013 5:05 pm
Gbaman wrote:The guide can be found at http://pi.gbaman.info/?p=150
Hi Gbaman,
This pipeline doesn't work when I try it. Here's what I am seeing when attempting to use the sender pipe with no modifications other than using the IP address of the sending Pi:
pi@raspi1 ~ $ raspivid -t 999999 -h 720 -w 1080 -fps 25 -hf -b 2000000 -o - | gst-launch-1.0 -v fdsrc ! h264parse !  rtph264pay config-interval=1 pt=96 ! gdppay ! tcpserversink host=192.168.1.101 port=5000
Setting pipeline to PAUSED ...
/GstPipeline:pipeline0/GstTCPServerSink:tcpserversink0: current-port = 5000
Pipeline is PREROLLING ...
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, width=(int)1080, height=(int)720, parsed=(boolean)true, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)0164001fffe1000f2764001fac2b402202df2f00f1226a01000528ee025cb0
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0.GstPad:src: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, sprop-parameter-sets=(string)"J2QAH6wrQCIC3y8A8SJq\,KO4CXLA\=", payload=(int)96, ssrc=(uint)924457899, timestamp-offset=(uint)3503283303, seqnum-offset=(uint)43364
/GstPipeline:pipeline0/GstGDPPay:gdppay0.GstPad:sink: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, sprop-parameter-sets=(string)"J2QAH6wrQCIC3y8A8SJq\,KO4CXLA\=", payload=(int)96, ssrc=(uint)924457899, timestamp-offset=(uint)3503283303, seqnum-offset=(uint)43364
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0.GstPad:sink: caps = video/x-h264, width=(int)1080, height=(int)720, parsed=(boolean)true, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)0164001fffe1000f2764001fac2b402202df2f00f1226a01000528ee025cb0
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0: timestamp = 3503283303
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0: seqnum = 43364
/GstPipeline:pipeline0/GstGDPPay:gdppay0.GstPad:src: caps = application/x-gdp, streamheader=(buffer)< 01000100464e00000155ffffffffffffffff000000000000000000000000000000000000000000000000000000000000000000000000000000005d6700004773744576656e745365676d656e742c207365676d656e743d284773745365676d656e7429224773745365676d656e742c20666c6167733d284773745365676d656e74466c616773294753545f5345474d454e545f464c41475f4e4f4e452c20726174653d28646f75626c6529312c206170706c6965642d726174653d28646f75626c6529312c20666f726d61743d28477374466f726d6174294753545f464f524d41545f54494d452c20626173653d286775696e74363429302c206f66667365743d286775696e74363429302c2073746172743d286775696e74363429302c2073746f703d286775696e7436342931383434363734343037333730393535313631352c2074696d653d286775696e74363429302c20706f736974696f6e3d286775696e74363429302c206475726174696f6e3d286775696e7436342931383434363734343037333730393535313631353b223b00, 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 >
/GstPipeline:pipeline0/GstTCPServerSink:tcpserversink0.GstPad:sink: caps = application/x-gdp, streamheader=(buffer)< 01000100464e00000155ffffffffffffffff000000000000000000000000000000000000000000000000000000000000000000000000000000005d6700004773744576656e745365676d656e742c207365676d656e743d284773745365676d656e7429224773745365676d656e742c20666c6167733d284773745365676d656e74466c616773294753545f5345474d454e545f464c41475f4e4f4e452c20726174653d28646f75626c6529312c206170706c6965642d726174653d28646f75626c6529312c20666f726d61743d28477374466f726d6174294753545f464f524d41545f54494d452c20626173653d286775696e74363429302c206f66667365743d286775696e74363429302c2073746172743d286775696e74363429302c2073746f703d286775696e7436342931383434363734343037333730393535313631352c2074696d653d286775696e74363429302c20706f736974696f6e3d286775696e74363429302c206475726174696f6e3d286775696e7436342931383434363734343037333730393535313631353b223b00, 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 >
(gst-launch-1.0:4543): GStreamer-WARNING **: gstpad.c:3908:gst_pad_push_data:<gdppay0:src> Got data flow before stream-start event
(gst-launch-1.0:4543): GStreamer-WARNING **: gstpad.c:3677:gst_pad_chain_data_unchecked:<tcpserversink0:sink> Got data flow before stream-start event
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
The last two warnings then repeat continuously until I interrupt it. These warnings occur before even starting the receiver.
Any thoughts on what could be the issue?
jarrah31
Tue May 28, 2013 1:45 pm
Has anyone else had problems installing gstreamer on rPi? I've tried on two different Pi's and Raspbian builds (after doing an update) but keep getting this error:
pi@raspberrypi ~ $ sudo apt-get install gstreamer1.0
Reading package lists... Done
Building dependency tree
E: Unable to locate package gstreamer1.0
E: Couldn't find any package by regex 'gstreamer1.0'
Thanks.
Lauszus
Tue May 28, 2013 2:05 pm
@jarrah31
You need to add:
deb http://vontaene.de/raspbian-updates/ . main
To /etc/apt/sources.list
And then run:
sudo apt-get update
Gbaman
Tue May 28, 2013 2:31 pm
jarrah31 wrote:Has anyone else had problems installing gstreamer on rPi? I've tried on two different Pi's and Raspbian builds (after doing an update) but keep getting this error:
Thanks.
Yes, my fault. I forgot I had another repo in my sources list which it was pulling it from, have updated the blog post
http://pinet.org.uk
fke
Wed May 29, 2013 8:41 am
works fine in my setup (wlan - internet (vpn) - macbookpro ) -> so i can watch what's going on at home from the internet.
I' tried out some other solutions (vlc-streaming) but this is the best.
h 720
w 1000
fps 12
cpu < 10% :D
Lauszus
Mon Jun 03, 2013 1:31 pm
I just wanted to let people know that I got audio streaming working as well by using a USB soundcard for audio input:
To stream:
gst-launch-1.0 alsasrc device=plughw:Set \
! mulawenc ! rtppcmupay ! udpsink host=clientIp port=5001
Replace the clientIp with your computers ip address. Normally I just set the end to 255, so it can be received on every computer on the network, for instance I set mine to: 10.0.0.255.
You will properly have to install the following packages: "alsa-utils", "alsa-firmware", and "alsa-plugins".
Also replace 'Set' with the name of your soundcard. You can get that by running:
asoundconf list
You can also use:
cat /proc/asound/cards
aplay -l
To get some more information about your soundcard.
You can set the default soundcard like so:
asoundconf set-default-card cardname
To adjust your setting use:
alsamixer
And then to store your settings:
sudo alsactl store
To test the speakers run:
speaker-test -c 2
To receive the audio on your computer:
gst-launch-1.0 udpsrc port=5001 caps="application/x-rtp" \
! queue ! rtppcmudepay ! mulawdec ! audioconvert ! autoaudiosink sync=false
If you experience dropouts you might want to add "num-buffers=1000" at the server side, but in my experience it actually works better by not using it.
I will be working on muxing the signals toghether next :)
Btw you can test if your USB soundcard is working on the Raspberry Pi with the following command:
gst-launch-1.0 audiotestsrc ! alsasink
And this will loop back the audio from your microphone:
gst-launch-1.0 alsasrc device=plughw:Set ! alsasink
I also got streaming working via VLC:
cvlc -vvv alsa://plughw:Set \
--sout '#transcode{acodec=mp2,ab=32}:rtp{dst=10.0.0.9,port=1234,sdp=rtsp://10.0.0.9:8085/stream.sdp}'
Be sure to replace 10.0.0.9 with the ip address of your Raspberry Pi.
And then just open:
In VLC on your computer, but the latency is much much larger.
Hope this will be useful to someone :)
Lauszus
Tue Jun 04, 2013 8:37 pm
I wrote a little followup to my previous comment at my blog with a little more information.
Check it out http://blog.tkjelectronics.dk/2013/06/h ... o-latency/ :)
oddballbutler
Fri May 23, 2014 12:34 am
Rushy wrote:For some reason I cannot get this to work it freezes on Pipeline is Prerolling or I get an error
Sorry to revive a year old thread, but I am having the same issue and can't find much info with my googling skills. I can get it to work with UDP but it doesn't seem to like TCP for some reason. Anyone know why we are having this issue?
Return to “Camera board”
