joantune
Re: Motion - MMAL camera
Fri Sep 20, 2013 9:17 am
Try making these changes to the .conf file, that lebleck posted:
Edit “stream_port” to: stream_port 0
Edit “webcontrol_port” to: webcontrol_port 0
PaoloUd
Fri Sep 20, 2013 2:41 pm
Thanks,
but doing so I can't receive a stream with my browser...
Paolo
cursor2000
Fri Sep 20, 2013 3:29 pm
Here's my .conf file which has been streaming fine for a few days now.
# motion-mmalcam.conf
# This config file was generated by motion mmaltest
# Daemon
# Start in daemon (background) mode and release terminal (default: off)
daemon off
#File to store the process ID, also called pid file. (default: not defined)
process_id_file /var/run/motion/motion.pid
# Basic Setup Mode
# Start in Setup-Mode, daemon disabled. (default: off)
setup_mode off
# Use a file to save logs messages, if not defined stderr and syslog is used. (default: not defined)
logfile /home/pi/motion.log
# Level of log messages [1..9] (EMR, ALR, CRT, ERR, WRN, NTC, ERR, DBG, ALL). (default: 6 / NTC)
log_level 5
# Filter to log messages by type (COR, STR, ENC, NET, DBL, EVT, TRK, VID, ALL). (default: ALL)
log_type all
# Capture device options
# Videodevice to be used for capturing  (default /dev/video0)
# for FreeBSD default is /dev/bktr0
videodevice /dev/video0
# v4l2_palette allows to choose preferable palette to be use by motion
# to capture from those supported by your videodevice. (default: 17)
# E.g. if your videodevice supports both V4L2_PIX_FMT_SBGGR8 and
# V4L2_PIX_FMT_MJPEG then motion will by default use V4L2_PIX_FMT_MJPEG.
# Setting v4l2_palette to 2 forces motion to use V4L2_PIX_FMT_SBGGR8
# instead.
# Values :
# V4L2_PIX_FMT_SN9C10X : 0  'S910'
# V4L2_PIX_FMT_SBGGR16 : 1  'BYR2'
# V4L2_PIX_FMT_SBGGR8  : 2  'BA81'
# V4L2_PIX_FMT_SPCA561 : 3  'S561'
# V4L2_PIX_FMT_SGBRG8  : 4  'GBRG'
# V4L2_PIX_FMT_SGRBG8  : 5  'GRBG'
# V4L2_PIX_FMT_PAC207  : 6  'P207'
# V4L2_PIX_FMT_PJPG    : 7  'PJPG'
# V4L2_PIX_FMT_MJPEG   : 8  'MJPEG'
# V4L2_PIX_FMT_JPEG    : 9  'JPEG'
# V4L2_PIX_FMT_RGB24   : 10 'RGB3'
# V4L2_PIX_FMT_SPCA501 : 11 'S501'
# V4L2_PIX_FMT_SPCA505 : 12 'S505'
# V4L2_PIX_FMT_SPCA508 : 13 'S508'
# V4L2_PIX_FMT_UYVY    : 14 'UYVY'
# V4L2_PIX_FMT_YUYV    : 15 'YUYV'
# V4L2_PIX_FMT_YUV422P : 16 '422P'
# V4L2_PIX_FMT_YUV420  : 17 'YU12'
v4l2_palette 17
# The video input to be used (default: -1)
# Should normally be set to 0 or 1 for video/TV cards, and -1 for USB cameras
input -1
# The video norm to use (only for video capture and TV tuner cards)
# Values: 0 (PAL), 1 (NTSC), 2 (SECAM), 3 (PAL NC no colour). Default: 0 (PAL)
norm 0
# The frequency to set the tuner to (kHz) (only for TV tuner cards) (default: 0)
frequency 0
# Rotate image this number of degrees. The rotation affects all saved images as
# well as movies. Valid values: 0 (default = no rotation), 90, 180 and 270.
rotate 180
# Image width (pixels). Valid range: Camera dependent, default: 352
width 640
# Image height (pixels). Valid range: Camera dependent, default: 288
height 480
# Maximum number of frames to be captured per second.
# Valid range: 2-100. Default: 100 (almost no limit).
framerate 2
# Minimum time in seconds between capturing picture frames from the camera.
# Default: 0 = disabled - the capture rate is given by the camera framerate.
# This option is used when you want to capture images at a rate lower than 2 per second.
minimum_frame_time 0
# URL to use if you are using a network camera, size will be autodetected (incl http:// ftp:// mjpg:// or file:///)
# Must be a URL that returns single jpeg pictures or a raw mjpeg stream. Default: Not defined
; netcam_url value
# Username and password for network camera (only if required). Default: not defined
# Syntax is user:password
; netcam_userpass value
# The setting for keep-alive of network socket, should improve performance on compatible net cameras.
# off:   The historical implementation using HTTP/1.0, closing the socket after each http request.
# force: Use HTTP/1.0 requests with keep alive header to reuse the same connection.
# on:    Use HTTP/1.1 requests that support keep alive as default.
# Default: off
netcam_keepalive off
# URL to use for a netcam proxy server, if required, e.g. "http://myproxy".
# If a port number other than 80 is needed, use "http://myproxy:1234".
# Default: not defined
; netcam_proxy value
# Set less strict jpeg checks for network cameras with a poor/buggy firmware.
# Default: off
netcam_tolerant_check off
# Path to file containing raw captured YUV frames from which to read input
; filecam_path value
# Name of camera to use if you are using a camera accessed through OpenMax/MMAL
mmalcam_name vc.ril.camera
# Camera control parameters (see raspivid/raspistill tool documentation)
; mmalcam_control_params value
# Use the still camera output - limits frame rate, but can show more of frame
 Default: off
mmalcam_use_still off
# Path to file where raw dump of camera YUV capture will be written (for testing, profiling & debugging)
; mmalcam_raw_capture_file value
# Let motion regulate the brightness of a video device (default: off).
# The auto_brightness feature uses the brightness option as its target value.
# If brightness is zero auto_brightness will adjust to average brightness value 128.
# Only recommended for cameras without auto brightness
auto_brightness off
# Set the initial brightness of a video device.
# If auto_brightness is enabled, this value defines the average brightness level
# which Motion will try and adjust to.
# Valid range 0-255, default 0 = disabled
brightness 0
# Set the contrast of a video device.
contrast 0
# Set the saturation of a video device.
saturation 0
# Set the hue of a video device (NTSC feature).
hue 0
# Round Robin (multiple inputs on same video device name)
# Number of frames to capture in each roundrobin step (default: 1)
roundrobin_frames 1
# Number of frames to skip before each roundrobin step (default: 1)
roundrobin_skip 1
# Try to filter out noise generated by roundrobin (default: off)
switchfilter off
# Motion Detection Settings:
# Threshold for number of changed pixels in an image that
# triggers motion detection (default: 1500)
threshold 1500
# Automatically tune the threshold down if possible (default: off)
threshold_tune off
# Noise threshold for the motion detection (default: 32)
noise_level 32
# Automatically tune the noise threshold (default: on)
noise_tune on
# Despeckle motion image using (e)rode or (d)ilate or (l)abel (Default: not defined)
# Recommended value is EedDl. Any combination (and number of) of E, e, d, and D is valid.
# (l)abeling must only be used once and the 'l' must be the last letter.
# Comment out to disable
despeckle_filter EedDl
# Detect motion in predefined areas (1 - 9). Areas are numbered like that:  1 2 3
# A script (on_area_detected) is started immediately when motion is         4 5 6
# detected in one of the given areas, but only once during an event.        7 8 9
# One or more areas can be specified with this option. Take care: This option
# does NOT restrict detection to these areas! (Default: not defined)
; area_detect value
# PGM file to use as a sensitivity mask.
# Full path name to. (Default: not defined)
; mask_file value
# Dynamically create a mask file during operation (default: 0)
# Adjust speed of mask changes from 0 (off) to 10 (fast)
smart_mask_speed 0
# Ignore sudden massive light intensity changes given as a percentage of the picture
# area that changed intensity. If set to 1, motion will do some kind of
# auto-lightswitch. Valid range: 0 - 100 , default: 0 = disabled
lightswitch 0
# Picture frames must contain motion at least the specified number of frames
# in a row before they are detected as true motion. At the default of 1, all
# motion is detected. Valid range: 1 to thousands, recommended 1-5
minimum_motion_frames 1
# Specifies the number of pre-captured (buffered) pictures from before motion
# was detected that will be output at motion detection.
# Recommended range: 0 to 5 (default: 0)
# Do not use large values! Large values will cause Motion to skip video frames and
# cause unsmooth movies. To smooth movies use larger values of post_capture instead.
pre_capture 0
# Number of frames to capture after motion is no longer detected (default: 0)
post_capture 0
# Event Gap is the seconds of no motion detection that triggers the end of an event.
# An event is defined as a series of motion images taken within a short timeframe.
# Recommended value is 60 seconds (Default). The value -1 is allowed and disables
# events causing all Motion to be written to one single movie file and no pre_capture.
# If set to 0, motion is running in gapless mode. Movies don't have gaps anymore. An
# event ends right after no more motion is detected and post_capture is over.
event_gap 60
# Maximum length in seconds of a movie
# When value is exceeded a new movie file is created. (Default: 0 = infinite)
max_movie_time 30
# Always save images even if there was no motion (default: off)
emulate_motion off
# Image File Output
# Output 'normal' pictures when motion is detected (default: on)
# Valid values: on, off, first, best, center
# When set to 'first', only the first picture of an event is saved.
# Picture with most motion of an event is saved when set to 'best'.
# Picture with motion nearest center of picture is saved when set to 'center'.
# Can be used as preview shot for the corresponding movie.
output_pictures off
# Output pictures with only the pixels moving object (ghost images) (default: off)
output_debug_pictures off
# The quality (in percent) to be used by the jpeg compression (default: 75)
quality 75
# Type of output images
# Valid values: jpeg, ppm (default: jpeg)
picture_type jpeg
# FFMPEG related options
# Film (movie) file output, and deinterlacing of the video input
# The options movie_filename and timelapse_filename are also used
# by the ffmpeg feature
# Use ffmpeg to encode movies in realtime (default: off)
ffmpeg_output_movies off
# Use ffmpeg to make movies with only the pixels moving
# object (ghost images) (default: off)
ffmpeg_output_debug_movies off
# Use ffmpeg to encode a timelapse movie
# Default value 0 = off - else save frame every Nth second
ffmpeg_timelapse 0
# The file rollover mode of the timelapse video
# Valid values: hourly, daily (default), weekly-sunday, weekly-monday, monthly, manual
ffmpeg_timelapse_mode daily
# Bitrate to be used by the ffmpeg encoder (default: 400000)
# This option is ignored if ffmpeg_variable_bitrate is not 0 (disabled)
ffmpeg_bps 500000
# Enables and defines variable bitrate for the ffmpeg encoder.
# ffmpeg_bps is ignored if variable bitrate is enabled.
# Valid values: 0 (default) = fixed bitrate defined by ffmpeg_bps,
# or the range 2 - 31 where 2 means best quality and 31 is worst.
ffmpeg_variable_bitrate 0
# Codec to used by ffmpeg for the video compression.
# Timelapse movies are always made in mpeg1 format independent from this option.
# Supported formats are: mpeg1 (ffmpeg-0.4.8 only), mpeg4 (default), and msmpeg4.
# mpeg1 - gives you files with extension .mpg
# mpeg4 or msmpeg4 - gives you files with extension .avi
# msmpeg4 is recommended for use with Windows Media Player because
# it requires no installation of codec on the Windows client.
# swf - gives you a flash film with extension .swf
# flv - gives you a flash video with extension .flv
# ffv1 - FF video codec 1 for Lossless Encoding ( experimental )
# mov - QuickTime ( testing )
# ogg - Ogg/Theora ( testing )
ffmpeg_video_codec mpeg4
# Use ffmpeg to deinterlace video. Necessary if you use an analog camera
# and see horizontal combing on moving objects in video or pictures.
# (default: off)
ffmpeg_deinterlace off
# External pipe to video encoder
# Replacement for FFMPEG builtin encoder for ffmpeg_output_movies only.
# Bool to enable or disable extpipe (default: off)
use_extpipe off
# External program (full path and opts) to pipe raw video to
# Generally, use '-' for STDIN...
; extpipe value
# Snapshots (Traditional Periodic Webcam File Output)
# Make automated snapshot every N seconds (default: 0 = disabled)
snapshot_interval 0
# Text Display
# %Y = year, %m = month, %d = date,
# %H = hour, %M = minute, %S = second, %T = HH:MM:SS,
# %v = event, %q = frame number, %t = thread (camera) number,
# %D = changed pixels, %N = noise level, \n = new line,
# %i and %J = width and height of motion area,
# %K and %L = X and Y coordinates of motion center
# %C = value defined by text_event - do not use with text_event!
# You can put quotation marks around the text to allow
# leading spaces
# Locate and draw a box around the moving object.
# Valid values: on, off, preview (default: off)
# Set to 'preview' will only draw a box in preview_shot pictures.
locate_motion_mode off
# Set the look and style of the locate box if enabled.
# Valid values: box, redbox, cross, redcross (default: box)
# Set to 'box' will draw the traditional box.
# Set to 'redbox' will draw a red box.
# Set to 'cross' will draw a little cross to mark center.
# Set to 'redcross' will draw a little red cross to mark center.
locate_motion_style box
# Draws the timestamp using same options as C function strftime(3)
# Default: %Y-%m-%d\n%T = date in ISO format and time in 24 hour clock
# Text is placed in lower right corner
text_right %Y-%m-%d\n%T-%q
# Draw a user defined text on the images using same options as C function strftime(3)
# Default: Not defined = no text
# Text is placed in lower left corner
; text_left value
# Draw the number of changed pixed on the images (default: off)
# Will normally be set to off except when you setup and adjust the motion settings
# Text is placed in upper right corner
text_changes off
# This option defines the value of the special event conversion specifier %C
# You can use any conversion specifier in this option except %C. Date and time
# values are from the timestamp of the first image in the current event.
# Default: %Y%m%d%H%M%S
# The idea is that %C can be used filenames and text_left/right for creating
# a unique identifier for each event.
text_event %Y%m%d%H%M%S
# Draw characters at twice normal size on images. (default: off)
text_double on
# Text to include in a JPEG EXIF comment
# May be any text, including conversion specifiers.
# The EXIF timestamp is included independent of this text.
; exif_text value
# Target Directories and filenames For Images And Films
# For the options snapshot_, picture_, movie_ and timelapse_filename
# you can use conversion specifiers
# Quotation marks round string are allowed.
# Target base directory for pictures and films
# Recommended to use absolute path. (Default: current working directory)
target_dir /home/pi
# File path for snapshots (jpeg or ppm) relative to target_dir
# Default: %v-%Y%m%d%H%M%S-snapshot
# Default value is equivalent to legacy oldlayout option
# For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-snapshot
# File extension .jpg or .ppm is automatically added so do not include this.
# Note: A symbolic link called lastsnap.jpg created in the target_dir will always
# point to the latest snapshot, unless snapshot_filename is exactly 'lastsnap'
snapshot_filename %v-%Y%m%d%H%M%S-snapshot
# File path for motion triggered images (jpeg or ppm) relative to target_dir
# Default: %v-%Y%m%d%H%M%S-%q
# For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-%q
# Set to 'preview' together with best-preview feature enables special naming
# convention for preview shots. See motion guide for details
picture_filename %v-%Y%m%d%H%M%S-%q
# File path for motion triggered ffmpeg films (movies) relative to target_dir
# For Motion 3.0 compatible mode choose: %Y/%m/%d/%H%M%S
# File extension .mpg or .avi is automatically added so do not include this
# This option was previously called ffmpeg_filename
movie_filename %v-%Y%m%d%H%M%S
# File path for timelapse movies relative to target_dir
# Default: %Y%m%d-timelapse
# Default value is near equivalent to legacy oldlayout option
# For Motion 3.0 compatible mode choose: %Y/%m/%d-timelapse
# File extension .mpg is automatically added so do not include this
timelapse_filename %Y%m%d-timelapse
# Global Network Options
# Enable or disable IPV6 for http control and stream (default: off)
ipv6_enabled off
# Live Stream Server
# The mini-http server listens to this port for requests (default: 0 = disabled)
stream_port 8081
# Quality of the jpeg (in percent) images produced (default: 50)
stream_quality 50
# Output frames at 1 fps when no motion is detected and increase to the
# rate given by stream_maxrate when motion is detected (default: off)
stream_motion off
# Maximum framerate for streams (default: 1)
stream_maxrate 1
# Restrict stream connections to localhost only (default: on)
stream_localhost off
# Limits the number of images per connection (default: 0 = unlimited)
# Number can be defined by multiplying actual stream rate by desired number of seconds
# Actual stream rate is the smallest of the numbers framerate and stream_maxrate
stream_limit 0
# Set the authentication method (default: 0)
# 0 = disabled
# 1 = Basic authentication
# 2 = MD5 digest (the safer authentication)
stream_auth_method 0
# Authentication for the stream. Syntax username:password
# Default: not defined (Disabled)
; stream_authentication value
# HTTP Based Control
# TCP/IP port for the http server to listen on (default: 0 = disabled)
webcontrol_port 8080
# Restrict control connections to localhost only (default: on)
webcontrol_localhost off
# Output for http server, select off to choose raw text plain (default: on)
webcontrol_html_output on
# Authentication for the http based control. Syntax username:password
; webcontrol_authentication value
# Tracking (Pan/Tilt)
# Type of tracker (0=none (default), 1=stepper, 2=iomojo, 3=pwc, 4=generic, 5=uvcvideo, 6=servo)
# The generic type enables the definition of motion center and motion size to
# be used with the conversion specifiers for options like on_motion_detected
track_type 0
# Enable auto tracking (default: off)
track_auto off
# Serial port of motor (default: none)
; track_port value
# Motor number for x-axis (default: 0)
track_motorx 0
# Set motorx reverse (default: off)
track_motorx_reverse off
# Motor number for y-axis (default: 0)
track_motory 0
# Set motory reverse (default: off)
track_motory_reverse off
# Maximum value on x-axis (default: 0)
track_maxx 0
# Minimum value on x-axis (default: 0)
track_minx 0
# Maximum value on y-axis (default: 0)
track_maxy 0
# Minimum value on y-axis (default: 0)
track_miny 0
# Center value on x-axis (default: 0)
track_homex 128
# Center value on y-axis (default: 0)
track_homey 128
# ID of an iomojo camera if used (default: 0)
track_iomojo_id 0
# Angle in degrees the camera moves per step on the X-axis
# with auto-track (default: 10)
# Currently only used with pwc type cameras
track_step_angle_x 10
# Angle in degrees the camera moves per step on the Y-axis
track_step_angle_y 10
# Delay to wait for after tracking movement as number
# of picture frames (default: 10)
track_move_wait 10
# Speed to set the motor to (stepper motor option) (default: 255)
track_speed 255
# Number of steps to make (stepper motor option) (default: 40)
track_stepsize 40
# External Commands, Warnings and Logging:
# You can use conversion specifiers for the on_xxxx commands
# %f = filename with full path
# %n = number indicating filetype
# Both %f and %n are only defined for on_picture_save,
# on_movie_start and on_movie_end
# Do not sound beeps when detecting motion (default: on)
# Note: Motion never beeps when running in daemon mode.
quiet on
# Command to be executed when an event starts. (default: none)
# An event starts at first motion detected after a period of no motion defined by event_gap
; on_event_start value
# Command to be executed when an event ends after a period of no motion
# (default: none). The period of no motion is defined by option event_gap.
; on_event_end value
# Command to be executed when a picture (.ppm|.jpg) is saved (default: none)
# To give the filename as an argument to a command append it with %f
; on_picture_save value
# Command to be executed when a motion frame is detected (default: none)
; on_motion_detected value
# Command to be executed when motion in a predefined area is detected
# Check option 'area_detect'. (default: none)
; on_area_detected value
# Command to be executed when a movie file (.mpg|.avi) is created. (default: none)
; on_movie_start value
# Command to be executed when a movie file (.mpg|.avi) is closed. (default: none)
; on_movie_end value
# Command to be executed when a camera can't be opened or if it is lost
# NOTE: There is situations when motion don't detect a lost camera!
# It depends on the driver, some drivers dosn't detect a lost camera at all
# Some hangs the motion thread. Some even hangs the PC! (default: none)
; on_camera_lost value
# Common Options for database features.
# Options require the database options to be active also.
# Log to the database when creating motion triggered image file  (default: on)
sql_log_picture on
# Log to the database when creating a snapshot image file (default: on)
sql_log_snapshot on
# Log to the database when creating motion triggered movie file (default: off)
sql_log_movie off
# Log to the database when creating timelapse movie file (default: off)
sql_log_timelapse off
# SQL query string that is sent to the database
# Use same conversion specifiers has for text features
# Additional special conversion specifiers are
# %n = the number representing the file_type
# Create tables :
# Mysql
# CREATE TABLE security (camera int, filename char(80) not null, frame int, file_type int, time_stamp timestamp(14), event_time_stamp timestamp(14));
# Postgresql
# CREATE TABLE security (camera int, filename char(80) not null, frame int, file_type int, time_stamp timestamp without time zone, event_time_stamp timestamp without time zone);
# Default value:
# insert into security(camera, filename, frame, file_type, time_stamp, text_event) values('%t', '%f', '%q', '%n', '%Y-%m-%d %T', '%C')
sql_query sql_query insert into security(camera, filename, frame, file_type, time_stamp, event_time_stamp) values('%t', '%f', '%q', '%n', '%Y-%m-%d %T', '%C')
# Database Options
# database type : mysql, postgresql, sqlite3 (default : not defined)
; database_type value
# database to log to (default: not defined)
; database_dbname value
# The host on which the database is located (default: not defined)
database_host localhost
# User account name for database (default: not defined)
; database_user value
# User password for database (default: not defined)
; database_password value
# Port on which the database is located (default: not defined)
# mysql 3306 , postgresql 5432 (default: not defined)
database_port 0
# Video Loopback Device (vloopback project)
# Output images to a video4linux loopback device
# The value '-' means next available (default: not defined)
; video_pipe value
# Output motion images to a video4linux loopback device
; motion_video_pipe value
# Thread config files - One for each camera.
# Except if only one camera - You only need this config file.
# If you have more than one camera you MUST define one thread
# config file for each camera in addition to this config file.
; thread /usr/local/etc/thread1.conf
joantune
Fri Sep 20, 2013 3:48 pm
PaoloUd wrote:Thanks,
Paolo
Most likely you were choosing either:
- ports that were already taken by other apps (keep in mind XBMC and whatnot do have web interfaces)
- ports below 1024 with a non root user.
To find out which ports are already taken, and by which processes, do:
 netstat -anp
To easily get a port under 1024 running, run motion as root (dunno if security advisable, and dunno if you cannot just run the first instance as root, and then 'downgrade' the user, I'm sure that can be done somehow, otherwise apache would be run as root)
PaoloUd
Mon Sep 23, 2013 6:07 am
I've changed the ports and it works...
Thanks to everybody.
Paolo
with ice cream
Mon Sep 30, 2013 9:07 am
Motion JPEG (MJPG) as it is used to display the stream in the web interface is no longer supported in Mobile Safari and also desktop browser seem to have issues with it (e.g. I can't view the stream in an iframe, I think Midori also has problems with it). Has anyone come up with a better solution?
SteveDee
Mon Sep 30, 2013 7:14 pm
with ice cream wrote: I think Midori also has problems with it...
On RPi use gmotionlive.
On Android I use CamBuddy (...maybe there is an Apple equivalent)
raind33r
Mon Oct 07, 2013 12:49 pm
When I start motion from home/pi with ./motion -c motion-mmalcam.conf the CSi camera LED goes on immediately and stays on.
I set the timeout to 30 seconds in the conf file.
I have set my fps to 25. When watching the stream from another pc it is extremely laggy.
Is this normal? Any way to speed it up?
madrian
Tue Oct 15, 2013 8:17 pm
Currently 2fps is the max what we can get at 1280x720 or 1024x768?
jbeale
Wed Oct 16, 2013 3:31 am
madrian wrote:Currently 2fps is the max what we can get at 1280x720 or 1024x768?
I believe that is correct, at least that is what I was able to do.
If we could get the motion algorithm running on the GPU, it should be able to do quite a bit better. Not being familiar with either the motion program, or GPU techniques, I'm not sure if OpenGL ES 2.0 is useful for that work.
LustigePerson
Tue Oct 22, 2013 6:32 pm
I have a question.
If I set the resolution to 960x720 e.g. I noticed that the image is "cropped".
This means I don't see the whole image like if I take a picture via "raspistill -w 960 -h 720".
So not just the resolution but also the angle is changing.
Can I somehow avoid this?
EDIT:
Sorry, found it. It is the "mmalcam_use_still" parameter.
But I think is I use it I don't get the right framerate.
But another problem: I a "dark" room images a blurred, because of long exposure time. Can I somehow force a short exposure time?
catzi
Wed Oct 30, 2013 8:47 pm
Hello, I'm using Motion-MMAL to keep an eye on my oil tank, generating still images. The view the camera has is around two thirds ground and one third sky/trees. When I start the daemon, I get great pictures but within two minutes they become far too dark. None of the mmal_control_params aleviate this. I believe the similar problem with raspistill has been fixed - are there any plans to fix Motion-MMAL or perhaps release the source? I really prefer the still image option as the wider angle suits my purpose. Many thanks for the great effort so far.
dozencrows
Sat Nov 02, 2013 5:55 pm
Just wanted to let you know I'm working on the still image exposure problem - it looks like the raspistill fix works for motion-mmal on the first run, but there's something else not right as subsequent runs only yield black images.
Rebooting the Pi makes it work again... probably something about shutting down the camera in raspistill code I haven't spotted yet.
In case anyone is interested, the fix is to hook up the camera component's preview output port to a "null sink" component, so that preview images are generated and used to calculate exposure.
The downside to using the still mode is that you will likely only get good results with a low frame rate, to allow the camera to work out the exposure properly.
Christer
Tue Nov 05, 2013 9:15 am
Have motion mmal on two Raspberry PI and starts them with cron. The problem is that the cams shuts down itself off after 7-8 hours. Is there a built-in limit in motion mmal or is some temp-file full?
bietiekay
Tue Nov 05, 2013 6:08 pm
@dozencrows: so you got a fix for the Black Images using the still parameter in motion-mmal? Can you make the binary or code available please?
jbeale
Tue Nov 05, 2013 7:29 pm
Christer wrote:Have motion mmal on two Raspberry PI and starts them with cron. The problem is that the cams shuts down itself off after 7-8 hours. Is there a built-in limit in motion mmal or is some temp-file full?
I've had motion-mmal running for months at a time, so the program itself is not the problem. Check your disk space, and your log files in /var/log/ and see if there's anything useful there. Or could be a network issue (eg. wifi shutting down, or DHCP lease not renewed, etc.) You can avoid DHCP issues, if that's a problem, by setting up a static IP.
catzi
Thu Nov 07, 2013 1:00 pm
@dozencrows : Great to hear you're working on a fix for the still mode exposure, your hard work is much appreciated.
RobsterCraw
Thu Nov 07, 2013 4:50 pm
I've been trying to get this working for several days now and have had a simply abysmal time of it. Right now the log file is telling me this:
mmalcam_start: MMAL Camera thread starting... for camera (vc.ril.camera) of 1280 x 720 at 2 fps
mmalcam_start: MMAL Camera using video capture
however, the camera doesn't appear to be powered (red LED off) and nothing is recorded.
Does anyone know what could be wrong?
vtjung
Fri Nov 08, 2013 8:53 am
how can i use a notification at start of motion? example send mail or send video after end of motion?
have anyone example from the configuration file or is it possible at all?
Thanks..
Christer
Wed Nov 13, 2013 9:24 am
Motion mmal works fine on my computers. I finally manage to set the sensitivity to an acceptable level. Have only two problems left to solve. It must be possible to start with cron / ssh and it should be turned off whenever I want. As it is, it turns off when it gets dark and must be rebooted to restart. I want to make it a little easier to solve, because it takes so long to find the settings that cause the error.
If someone wants to share a working raspian image.I would be grateful.
My email is:
befrielse@gmail.com
jbeale
Wed Nov 13, 2013 3:07 pm
Christer wrote: As it is, it turns off when it gets dark and must be rebooted to restart.
You aren't by chance using "-ex verylong" are you? That is known to hang up the camera as soon as the exposure exceeds 1/3 second.
I have motion-mmal running and it does not turn off at night. Here is my config file:
# Daemon
daemon off
# File to store the process ID, also called pid file. (default: not defined)
# Basic Setup Mode
setup_mode off
logfile /home/pi/mmal/motion.log
# Level of log messages [1..9] (EMR, ALR, CRT, ERR, WRN, NTC, INF, DBG, ALL). (default: 6 / NTC)
log_level 5
log_type all
#videodevice /dev/video0
# instead.
# Values :
v4l2_palette 17
# Tuner device to be used for capturing using tuner as source (default /dev/tuner0)
# This is ONLY used for FreeBSD. Leave it commented out for Linux
; tunerdevice /dev/tuner0
input -1
norm 0
frequency 0
rotate 0
width 1024
#width 640
height 576
#height 480
framerate 2
minimum_frame_time 1
;netcam_url http://127.0.0.1/cgi-bin/raspicam.sh
# Default: off
# Default: off
auto_brightness off
brightness 0
contrast 0
saturation 0
hue 0
# File "camera" support - read raw YUV data from a file
#filecam_path /home/pi/test-cap/motion-mmal.capture
# OpenMax/MMAL camera support for Raspberry Pi
mmalcam_control_params -mm matrix -ex sports
# Switch this setting to "on" to use the still image mode of the Pi's camera
# instead of video. This gives a wider field of view, but requires
# a much slower frame-rate to achieve exposure stability
# (e.g. 0.25 fps or slower). You can use the minimum_frame_time
# parameter above to achieve this
roundrobin_frames 1
roundrobin_skip 1
switchfilter off
threshold 6000
threshold_tune off
noise_level 32
noise_tune on
#despeckle_filter EedDl
; area_detect value
; mask_file value
smart_mask_speed 5
# area that changed intensity. Valid range: 0 - 100 , default: 0 = disabled
lightswitch 0
pre_capture 0
post_capture 0
event_gap 10
max_movie_time 20
emulate_motion off
# Image File Output
# output_pictures on
output_pictures best
quality 85
picture_type jpeg
# Film (movies) file output, and deinterlacing of the video input
ffmpeg_timelapse 0
ffmpeg_bps 500000
# Timelapse mpegs are always made in mpeg1 format independent from this option.
ffmpeg_video_codec msmpeg4
# (default: off)
# SDL Window
# Number of motion thread to show in SDL Window (default: 0 = disabled)
#sdl_threadnr 0
use_extpipe off
;extpipe mencoder -demuxer rawvideo -rawvideo w=320:h=240:i420 -ovc x264 -x264encopts bframes=4:frameref=1:subq=1:scenecut=-1:nob_adapt:threads=1:keyint=1000:8x8dct:vbv_bufsize=4000:crf=24:partitions=i8x8,i4x4:vbv_maxrate=800:no-chroma-me -vf denoise3d=16:12:48:4,pp=lb -of   avi -o %f.avi - -fps %fps
snapshot_interval 0
# Text Display
# leading spaces
; text_left CAMERA %t
text_left Pi5-cam
#text_changes off
text_changes on
text_double on
;exif_text %i%J/%K%L
target_dir /home/pi/mvideo
#snapshot_filename %v-%Y%m%d%H%M%S-snapshot
snapshot_filename %Y%m%d%H%M%S-snapshot
#picture_filename %v-%Y_%m%d_%H%M_%S-%q
picture_filename %Y_%m%d_%H%M_%S
#movie_filename %v-%Y_%m%d_%H%M_%S
movie_filename %Y_%m%d_%H%M_%S
timelapse_filename LAPSE_%Y%m%d
# Enable or disable IPV6 for http control and stream (default: off )
ipv6_enabled off
stream_port 8081
stream_quality 50
stream_motion off
# Maximum framerate for stream streams (default: 1)
stream_maxrate 1
stream_limit 0
# 0 = disabled
; stream_authentication username:password
webcontrol_localhost on
; webcontrol_authentication username:password
track_type 0
track_auto off
;track_port /dev/ttyS0
;track_motorx 0
# Set motorx reverse (default: 0)
;track_motorx_reverse 0
;track_motory 1
# Set motory reverse (default: 0)
;track_motory_reverse 0
;track_maxx 200
;track_minx 50
;track_maxy 200
;track_miny 50
;track_homex 128
;track_homey 128
track_iomojo_id 0
track_move_wait 10
track_speed 255
track_stepsize 40
quiet on
on_picture_save /home/pi/mmal/psave.sh %f %i %J %K %L
# Options require database options to be active also.
# Log to the database when creating motion triggered picture file  (default: on)
; sql_log_picture on
; sql_log_snapshot on
; sql_log_movie off
# Log to the database when creating timelapse movies file (default: off)
; sql_log_timelapse off
# Default value:
# Create tables :
# Mysql
# Postgresql
; sql_query insert into security(camera, filename, frame, file_type, time_stamp, event_time_stamp) values('%t', '%f', '%q', '%n', '%Y-%m-%d %T', '%C')
# Database Options
# The host on which the database is located (default: localhost)
; database_host value
; database_port value
# Database Options For SQLite3
# SQLite3 database (file path) (default: not defined)
; sqlite3_db value
; video_pipe value
# Remember: If you have more than one camera you must have one
# thread file for each camera. E.g. 2 cameras requires 3 files:
# This motion.conf file AND thread1.conf and thread2.conf.
# Only put the options that are unique to each camera in the
# thread config files.
; thread /usr/local/etc/thread2.conf
; thread /usr/local/etc/thread3.conf
; thread /usr/local/etc/thread4.conf
The images and movie clips are put into /home/pi/mvideo and you'll note, I have another script in /home/pi/mmal/psave.sh which takes the corner locations of the detected motion area from motion-mmal and uses Imagemagick tools to generate a thumbnail of just the area of interest and put it in /home/pi/mvideo/thumbs/ ...then I have another script /home/pi/putcam0 to upload file to an external ftp site.
#!/bin/bash
XT=`expr $2 / 2`
XO=`expr $4 - $XT`
YT=`expr $3 / 2`
YO=`expr $5 - $YT`
convert $1 -crop $2x$3+$XO+$YO -resize 200x200 /home/pi/mvideo/thumbs/${1#/home/pi/mvideo/}
cd /home/pi/mvideo
/home/pi/putcam0 ${1#/home/pi/mvideo/}
/home/pi/putcam0 thumbs/${1#/home/pi/mvideo/}
Cole_Trickle
Thu Nov 14, 2013 1:17 am
jbeale wrote:@PeterN: I'm not much of an expert really, just using what 'dozencrows' has made for us. By the way, the JPEG images are fine and viewable by anything, but the AVI files generated by this motion-mmal + ffmpeg combination seem to be nonstandard in some way. VLC does not always show them properly; you may see just the first frame, or nothing at all. But Windows Media Player on my old WinXP box does play them, as does VirtualDub 1.9.11 (also WinXP).
I want to view the images and video from outside my home LAN, but I don't want the security issues of running a public-facing webserver from home. So what I do is use another program 'sitecopy' (sudo apt-get install sitecopy) on the Pi to upload new files in my mmal images directory to an account on a commercial webhost. I view and/or download them from a browser pointing to that site.
If you want to use the Pi as a webserver too, of course you could do that, I have not tried it. I think there are several how-to documents for setting up various webservers.
@peewee2: The camera defaults to video mode at 30 fps. If you have 50 Hz power this may give you flickering under fluorescent lighting. Try setting -fps 25 in the mmalcam_control_params line in the config file, this may help. See also: http://www.raspberrypi.org/phpBB3/viewt ... 90#p350434
you can use a VPN client to access your home LAN, rather then loading your file off Premise.
ask me about Cisco....
andies
Thu Nov 14, 2013 8:57 pm
I am a newbie to Linux and PiRaspberry. I got motion up and running (with a Pi NoIR camera: http://www.raspberrypi.org/archives/5128) thanks to these descriptions, I really appreciate your work guys! I have one question and one remark:
1) I would like to add a "boot script" so that motion is started when the Pi boots up. Where do I look for that? Just now I am starting motion with ssh-login and leave the terminal window open.
2) Also, I am using a dropbox upload (https://github.com/andreafabrizi/Dropbo ... /README.md) which is great because I can trigger other events that way (https://ifttt.com/dashboard). I will use a cronjob that runs the uploader and erase all files after that. If the device is stolen (I am using it as IPCam in my house) only a geek should be able to recover the files.
raspberry B, Noir camera, Mac Book Air, iPhone, Bezzera
Christer
Fri Nov 15, 2013 8:18 am
Both the raspberry PI have different starting points, but closed exactly at 16:15:03 but cron is set to 20:00. Do not understand what is wrong? Surely some setting, but which one?
Christer
Sun Nov 17, 2013 6:05 am
Update: Finaly got things working! I'm waiting for a couple of days and then i post my working config here. Thanks for your support!
Return to “Camera board”
