MPikkemaat
Camera streaming with negligible delay
Wed May 22, 2013 9:32 pm
Hello all,
I've been searching for a way to stream video without delay, and although I found some examples, I had problems getting it right, until I found the following commands to make it happen with gstreamer. Thought I would share it here:
on the pi:
/opt/vc/bin/raspivid -t 999999 -h 720 -w 1080 -fps 25 -b 2000000 -o - | gst-launch-0.10 -v fdsrc ! h264parse ! rtph264pay config-interval=1 pt=96 ! gdppay ! tcpserversink host=192.168.1.44 port=5000
on a pc or laptop (this was using ubuntu 12.10)
gst-launch-0.10 -v tcpclientsrc host=192.168.1.44 port=5000  ! gdpdepay !  rtph264depay ! ffdec_h264 ! autovideosink sync=false
Best of luck with it,
Marnix
fbutler
Re: Camera streaming with negligible delay
Thu May 23, 2013 1:09 pm
MPikkemaat wrote:Hello all,
on the pi:
I'm trying something based on this with Gstreamer 1.0 from a Pi to a Pi with a slightly modified command on the receiver side.
The Commands I am using are:
Sender:
raspivid -t 999999 -h 720 -w 1080 -fps 25 -b 2000000 -o - | gst-launch-1.0 -v fdsrc ! h264parse ! rtph264pay config-interval=1 pt=96 ! gdppay ! tcpserversink host=192.168.1.101 port=5000
Receiver:
gst-launch-1.0 -v tcpclientsrc host=192.168.1.101 port=5000  ! gdpdepay !  rtph264depay ! h264parse ! omxh264dec ! videoconvert ! autovideosink sync=false
Although the video displays there is significant lag and the following types of warnings are continuously and repetitively being produced in great numbers on both the sender and the receiver:
(gst-launch-1.0:10272): GStreamer-WARNING **: gstpad.c:3908:gst_pad_push_data:<gdppay0:src> Got data flow before stream-start event
(gst-launch-1.0:10272): GStreamer-WARNING **: gstpad.c:3677:gst_pad_chain_data_unchecked:<tcpserversink0:sink> Got data flow before stream-start event
Has anyone got any thoughts on how to modify the pipelines to prevent/correct these warnings?
HansSanitizer
Tue Nov 04, 2014 5:58 am
Here's the fastest pipelines I've been able to manage:
PI:
gst-launch-1.0 rpicamsrc ! 'video/x-h264, width=1280, height=720, framerate=30/1,profile=high' ! queue ! rtph264pay ! udpsink host=192.168.0.8 port=5000
Client:
gst-launch-1.0.exe udpsrc port=5000 caps="application/x-rtp,media=(string)video,clock-rate=(int)90000,encoding-name=(string)H264" ! rtph264depay ! decodebin ! autovideosink
Sorry I should probably show where to get the rpicamsrc element:
https://github.com/thaytan/gst-rpicamsrc
codestar02
Fri Nov 07, 2014 12:27 am
HansSanitizer wrote:Here's the fastest pipelines I've been able to manage:
PI:
Client:
This method works great! Best streaming I have tried so far.
One question:
One Pi shows a regular oriented preview, but the other pi shows it flipped. I am not sure how to flip the feed of the receiver pipeline. Any suggestions?
Thanks!
EDIT:
I tried using videoflip and it noticeably slows down the stream. The only way I can make the original two commands running lag-free is for one to be upside down....
Fri Nov 07, 2014 7:59 am
Try flipping the camera end instread...
6by9
Fri Nov 07, 2014 8:15 am
jamesh wrote:Try flipping the camera end instread...
Sounds like a plan.
Hack at https://github.com/thaytan/gst-rpicamsr ... iew.c#L112 to set param.transform to an appropriate enum from MMAL_DISPLAYTRANSFORM_T (https://github.com/raspberrypi/userland ... deo.h#L109), and or MMAL_DISPLAY_SET_TRANSFORM into param.set.
As long as you are only flipping (not transposing), that'll enable a near zero-cost transform on displaying at the transmit end. It won't change the orientation of the data that is streamed. If you want to do that then it looks like there is a command-line option on gst-rpicamsrc to set up h & v flips (again zero cost as those are actually done on the sensor).
dharasty
Thu Jul 28, 2016 8:30 pm
Thank you so much for this thread, these examples, and the pointer to rpicamsrc.
Questions:
1) Can you explain (or point to docs) what the purpose of the second segment of that pipe does? (Beginning with "video/x-h264".)
2) Is that the right place to reduce the transmitted width, height? Or should I use an argument to "rpicamsrc"?
3) I find that the "client" has to be started first. Then I can start, stop, restart the camera side as often as I want. But if I start the client (display) after the camera (or stop-and-restart the display), it doesn't display. I tried fiddling with "keyframe-interval" in the source stream, but that didn't seem to help.)
4) Can you point to an example use of GST that allows me to show this stream on the RPi? (The "client" example works for me on Ubuntu, but crashes on the RPi. Do I need OpenGL on the RPi or something?)
Thanks!
Return to “Camera board”
