fireblade900rr
Automatically start raspivid to rtsp streaming
Wed May 22, 2013 7:36 pm
Hi !
Im not very familar with linux...
i tried to start the command
raspivid -o - -t 9999999 -w 1280 -h 720 --hflip | cvlc -vvv stream:///dev/stdin --sout '#rtp{sdp=rtsp://:8080/}' :demux=h264
automatically at startup using a script in /etc/init.d/
I think its working cause the camera led is on for a second at boot up but then it turns off and there's no transmission.
How do i keep it running ?
Trav
Re: Automatically start raspivid to rtsp streaming
Thu May 23, 2013 8:57 am
I can't answer your question directly, but if you can get a bit of information from the start up kernel messages then the Linux community here will be able to offer more suggestions.
After rebooting, from a terminal session type "dmesg" (without quotes). This will scroll a large amount of infromation past you, but you should be able to scroll back and look for references to raspivid and/or cvlc. If you copy and paste all these lines, plus one or to before and after, into a reply here we can perhaps suggest a solution, or at least a few more things to try.
1st Batch Model B (256M) running Raspbian, Pibrow case, with RaspiCam.
Model A (256M) running Raspbmc, caseless.
RaTTuS
Contact: Twitter YouTube
Thu May 23, 2013 9:06 am
put the command in /etc/rc.local
and use full paths for the instructions
that is how I would do it
Covfefe
fireblade900rr
Thu May 23, 2013 7:27 pm
dmesg has no messages containing raspivid or vlc
i've put it in the rc.local with full path, but that doesnt work too.
Its always the same the led switches on for a second and turns out...
is it that hard to execute a command line after boot ?
Trav
Thu May 23, 2013 9:14 pm
A script in /etc/init.d must have the execution bit set e.g. sudo chmod +x scriptname
If you paste the command into /etc/rc.local, you have to do the same for rc.local i.e. sudo chmod +x /etc/rc.local otherwise the system will ignore them. The fact that there is no mention in dmesg indicates that the script is not being run rather than failing.
fireblade900rr
Fri May 24, 2013 12:25 pm
The scripts are executable an theyre starting, if put the line
7 times in a scipt the led at the camera board will turn on 7 times...but just for a second...
the only problem is to keep it running...
walolinux
Sat Jul 20, 2013 7:38 pm
I had the same problem but runnig ffmpeg, i solved it putting the full path to the bynary:
raspivid -t 9999999 -w 960 -h 540 -fps 25 -b 500000 -o - | /usr/local/bin/ffmpeg -i - -vcodec copy -an -metadata title="Streaming desde raspberry pi" -f flv rtmp://ip/live/web
http://www.alvarolara.com/2013/07/20/em ... pberry-pi/
In your case, put the path to cvlc and tell me if it is running, you can execute:
whereis cvlc
Return to “Camera board”
