bri857
image is horizontally flipped
Wed May 22, 2013 4:26 pm
New module, no problem connecting, but image is flipped.
Using raspistill -hf -o image.jpg shows a correct image.
Can the image be flipped to stay in correct orientation?
leol
Re: image is horizontally flipped
Wed May 22, 2013 4:30 pm
This is a known issue and I believe is fixed in the next release.
RaTTuS
Contact: Twitter YouTube
Wed May 22, 2013 4:38 pm
askully
I think it is vertically flipped so
-vf
will sort it ... ;)
Covfefe
bri857
Wed May 22, 2013 4:58 pm
leol wrote:This is a known issue and I believe is fixed in the next release.
Thanks for the info
jezmck
Wed May 22, 2013 6:14 pm
Mine is horizontally flipped (need `-hf` to fix it).
Sounds like it's different for different people - is that true?
jbeale
Wed May 22, 2013 7:27 pm
depends how you hold the camera! It is always "mirror image" but may also be upside down, if for example as on my installation, the cable goes up instead of down. So I need to rotate the image 180 as well as flip left-right. There isn't a "rotate by 180" option, but both operations can be done in one go with the vertical flip.
EDIT: JamesH points out below that the rotate 180 does exist; I looked for it and missed it... well it was very late last night.
Wed May 22, 2013 9:30 pm
jbeale wrote:depends how you hold the camera! It is always "mirror image" but may also be upside down, if for example as on my installation, the cable goes up instead of down. So I need to rotate the image 180 as well as flip left-right. There isn't a "rotate by 180" option, but both operations can be done in one go with the vertical flip.
There is a rotate by 180 option...you can do 90, 180, or 270.
“I own the world’s worst thesaurus. Not only is it awful, it’s awful."
Return to “Camera board”
