decrot
Automate timelapse
Tue May 21, 2013 3:15 pm
Is there a way to run a bash script without having a user logged in via the raspi itself or through ssh?
I wrote a bash script to take images every few seconds, and run it via ssh, but as soon as I close my putty window, the script stops. I want to be able have a battery pack and take the raspi to various places where lugging a keyboard/monitor is cumbersome and out of wifi range.
gusgriller
Re: Automate timelapse
Tue May 21, 2013 3:21 pm
I would use a cron job for this. It only has a granularity of a minute, but you could use it to check that the process is running, and if not, fire it up again.
sharix
Tue May 21, 2013 3:22 pm
Yes. Install package "at" and then run:
at now
> "code you want executed"
Ctrl+D
gusgriller
Tue May 21, 2013 3:25 pm
I was also considering whether there some way of starting scripts from an app on my Android phone, perhaps over bluetooth, but unsuccessful so far. The best I could find was to turn the Pi into a wireless access point and see if I can ssh in that way from my phone. But that would be a bit clunky.
Tue May 21, 2013 3:31 pm
Could you use screen to start up a new bash shell that runs continuously after you have logged out? (Just a guess)
“My wife said to me `...you’re not even listening`.
I thought, that’s an odd way to start a conversation.."
decrot
Tue May 21, 2013 3:32 pm
jamesh wrote:Could you use screen to start up a new bash shell that runs continuously after you have logged out? (Just a guess)
actually I want something I could write to rc.local to start on boot.
SirLagz
Tue May 21, 2013 3:34 pm
Or you could use a hotspot + a web page to run commands on the Pi ?
cronjob's @reboot could do that
then in the script, just tell it to run itself once it's finished running, or after a sleep of say 5 seconds
poing
Tue May 21, 2013 3:58 pm
SirLagz wrote:Or you could use a hotspot + a web page to run commands on the Pi ?
That's what I do. I also have a web page that refreshes with Ajax when a new image arrives (from an Eye-Fi card for now, but that will work with the PiCamera as well).
Nu7s
Tue May 21, 2013 5:12 pm
I created a .sh file with my code:
#!/bin/bash
sudo raspistill -w 1000 -h 500 -o test%d.jpg -t 18000000 -tl 60000
Made it executable:
chmod 777 test.sh
And ran it with the command:
. test.sh &
Runs perfectly fine in the background.
decrot
Wed May 22, 2013 4:50 am
Nu7s wrote:And ran it with the command:
. test.sh &
That's what I needed. Now another question, if I log out, how do I stop the script?
Nu7s
Wed May 22, 2013 4:58 am
You should be given a process id. You need to kill that process to stop the script.
Return to “Camera board”
